Member and Staff Blogs Experimenting with Op Amps: Input Offset Voltage
  • Author Author: jc2048
  • Date Created: 27 May 2020 1:42 PM Date Created
  • Views 8708 views
  • Likes 16 likes
  • Comments 16 comments
  • op177
  • experimenting
  • op amp
  • op27
  • offset_voltage
  • tl081
  • jc2048
  • icl7611
jc2048
jc2048
27 May 2020
When we are taught about op amps, the usual starting point is a perfect op amp. That amplifier
has infinite gain, infinite input resistance on the two inputs, zero output resistance, and so
forth. That's done so that the focus can be on understanding the basic operation and how the
feedback operates with the various common circuit configurations, without all the messy real-
world details that apply to an actual physical circuit. Although real op amps can be very,
very good (exceptionally so compared to what most of us would end up with if we tried to
design one with discrete parts), inevitably they fall short of perfection, so we need to
understand those imperfections and how much real effect they have in order to design with
them.
One such imperfection is input offset voltage. An ideal op amp would have zero offset voltage.
That is, the difference in voltage between the two inputs would be zero to get zero at the
output. In practice the manufacturer can't achieve that. That might be because of small
differences between the characteristics of the input transistors, or it might be because the
internal circuit isn't perfectly balanced leading to a slight offset by design. The net result
of that offset, from our point of view as designers is that it's as though the perfect op amp
has a small voltage generator in series with one input. That then upsets the operation of our
circuits a little bit. For precision work, we may want to pay more for a precision op amp that
has much tighter specs for input offset voltage.
So how to look at it and measure it? This was going to be easy, I thought. Dredged up from the
rank depths of my memory was a circuit that would show me not only the input voltage offset
but also the open-loop gain and how close to the rails the outputs could get. I don't know
where I might have seen it and can't find it now. It might have been a book, an application
note, or maybe even online. Or maybe I imagined it.
The circuit was something like this
and the result would be along these lines:
The input is a triangle wave and is simply attenuated by a factor of approximately 1000 by the
resistors, giving better control of the mV-level signal at the input.
I should have thought a bit harder about what the result might be but, in a fit of enthusiasm,
I quickly repurposed one of my old test pcbs
and tried it on some of the odd selection of op amps I've accumulated over the last couple of
years.
Here are the results
TL081
OP177
ICL7611 [powered from +8v, -8V rails]
OP27
They look plausible but there's a snag. I can't show you because I didn't save a trace of it,
but the output always lagged the input zero-crossing point, irrespective of whether the input
was on the ramp up or the ramp down. If it represented the offset, it would have lead one way
and lagged the other. So what am I looking at? A further clue is the rounded corner where the
output starts to move. I'm looking at how the op amp output behaves when it comes out of
limiting at the rail, and it doesn't hurry, does it? The plots do show me how close the
outputs can get to the rail, so it wasn't a total fail as an experiment. The results are fine
for showing how the parts behave as comparators [not too good, if you like fast and snappy],
but the offset is quite overshadowed by the slow recovery.
At that point I decided to change course and rewired the board like this
Now the op amp is simply amplifying the offset voltage and I can read it on a bench meter. Here
are the results for the same four op amps
TL081 FET-input bipolar. Typ: 3mV Max: 15mV Reads: 576uV
OP177 Precision bipolar. Typ: 20uV Max:60uV Reads 22uV
ICL7611 CMOS Typ: Not Given Max: 15mV Reads: 138uV (Iq was set to 1mA)
OP27 Precision bipolar. Typ: 30uV Max: 100uV Reads: 25uV
The reading on the meter is 1000 times the offset.
(More or less: strictly the gain is 1001, the resistors are only 5%, and there must be a small
contribution to drive the output to the measured voltage, though it won't be very much. So all in all
a little approximate, but good enough for a quick blog.)
The precision parts [OP27 and OP177] lived up to their billing, being close to their typical
figures. The FET-input TL081 was worst, but well within spec and better than might have been
expected [it has offset pins, so could be trimmed closer, though, with a lot of the
applications it gets used for, it wouldn't be an issue anyway]. The CMOS part was a lot better
than the datasheet allows for - so it looks like I got lucky with that one too.
What would be interesting would be to look at the spread on a group of similar parts, but
unfortunately I don't have a lot of op amps so that will have to wait for another day.
If you found this interesting and would like to see more blogs I've written, a list can be found here:
jc2048 Blog Index
References
[1] User's Guide to Applying and Measuring Operational Amplifier Specifications
Ray Stata, Analog Devices Application Note AN-356
Note that that derives from something published in1967, so the methods that manufacturers use now may be much more spohisticated.
    jw0752 over 6 years ago +5
    Hi Jon, Thanks for another interesting area of exploration. I will have to set up and run some tests. Since I salvage lots of components from boards I have several types where there are quantities. Please…
    Hi Jon, Tonight I ran your offset experiment with various stock numbers and a quantity of each. I had quite a time as I initially set the experiment up on a single supply. Things didn't go well and I was…
  • ralphjy
    ralphjy over 6 years ago +5
    Wow, brings back a lot of memories. I just realized that the 741 passed its 50th anniversary. I think I first used one back in 1971. I remember the TI versions had better offset than the Fairchild ones…
  • fmilburn
    fmilburn over 6 years ago +5
    Hi Jon, Great post. By coincidence I have been playing with an op-amp I built from discrete parts a week or two back and experimenting with it. It was to be a 1day experiment but due to unexpected complexity…
    DAB over 6 years ago +4
    Yes, there are many aspects about opamps that every engineer should know and explore, but usually do not. Thanks for taking a look into one of them. DAB
    genebren over 6 years ago +3
    Very interesting blog. You have a knack for taking on some interesting topics and bringing a lot of interesting lessons to the readers. Thanks!
  • Andrew J
    Andrew J over 6 years ago +3
    Very interesting Jon. I’m creating a prototype PCB at the moment with an Opx192. Actually, two of them and they both have a spare unit. What I could do is wire these up to run a similar test, in two different…
  • jc2048
    jc2048 over 6 years ago in reply to Andrew J +3
    Hello Andrew. It might be interesting to see how it compares with precision bipolar parts [they get a CMOS part that good and consistent by trimming it at the test stage]. But I think you're going to have…
  • jc2048
    jc2048 over 6 years ago in reply to fmilburn +3
    That sounds interesting. Look forward to reading more.
    Jan Cumps over 6 years ago in reply to jw0752 +3
    I found an ST LM324N quad opamp. 100R is 115R 100K is 95K 47 nF = 56 nF Vcc = +- 15V Tested on a breadboard, but I tried to mitigate noise: zeroed the measurements at breadboard before starting the measurements…
    Hi Jon,
    Tonight I ran your offset experiment with various stock numbers and a quantity of each. I had quite a time as I initially set the experiment up on a single supply. Things didn't go well and I was about to ask you some questions when I realized my mistake by looking at your circuit board. Once the experiment was set up properly things went a little smoother. With the exception of one stock number (LT1006) I was amazed at how the off sets varied from one chip of the same stock number to the next. I even ran tests on a set of TL2142 Dual Op Amps. Along with the offsets I also noted the quiescent current of the chips. Here is my Data:
    LT1006   Quiescent Current  .35 to .43 mA  Offsets noted:    -57uV    57uV    59uV    10uV    -43uV   This was the most consistent of the stock numbers tested
    LM741     Quiescent Current   1mA +- .2mA  Offsets noted    544uV   330uV    -1190uV    -292uV
    LF411     Quiescent Current   2mA               Offsets noted      69uV    151uV    -422uV    581uV
    LF351     Quiescent Current     2mA          Offsets noted          -3179uV    2950uV    -540uV
    TL2142 Dual OP Amp Quiescent Current  7mA          Offsets noted:     100uV    -54uV    -300uV    -110uV    -36uV   -185uV    -69uV    -126uV    2.1uV   336uV    107uV    277uV
    I have learned a lot tonight about op amps. I like your technique for measuring the offset and it should come in useful for selecting chips for important and critical circuits in the future. Fortunately I do not have these applications very often. Your technique has also given me a crude way to measure micro volts, a capacity that my lab has not had before.
    • Vote Up +5 Vote Down
    Hi Jon,
    100R is 115R
    100K is 95K
    47 nF = 56 nF
    Vcc = +- 15V
    zeroed the measurements at breadboard before starting the measurements.
    Measurement integrates over 5 mains power cycles, thereby (theoretically) eliminating power lines induced noise.
    Then taking 100 measurements for reasonable stats.
    (edit: after a few goof-ups)
    OpAmp 1:
    Average = 481 mV
    Gain = 95K / 115R = 826
    -> 582.3 µV
    OpAmp 2:
    -> 754.3 µV
    OpAmp 3:
    -> 700.9 µV
    OpAmp 4:
    -> 904.4 µV
  • jc2048
    jc2048 over 6 years ago in reply to jw0752
    Hello John. Thanks for that - it's interesting seeing the variation.
    The technique isn't mine - I'm not that clever! - it comes from an old app note. I've added a link at the end of the blog post.
    The datasheet for the LT1006 has this bar graph of the distribution.
    That's from two separate fab runs - you can sort of see some evidence there for two overlapping normal distributions. The datasheet lists two parts, one with better specs, so you were probably lucky to find the one measuring 10uV. [The better spec part would tend to hollow-out the middle of the distribution, though if they were getting more premium parts than they could sell they'd just mix them up with the others].
