Member and Staff Blogs LCD MC21605C6W-BNMLWI-V2 I2C CODE ?
  • Author Author: oh3gdo
  • Date Created: 25 Jan 2022 4:35 PM Date Created
  • Views 1653 views
oh3gdo
oh3gdo
25 Jan 2022
I have looked Farnell I2C LCD MC21605C6W-BNMLWI-V2
It seems suitable, but I have not found any code in c-support.
I would use Microchip PIC18F27K40
I have used the CCS compiler from  chttp://www.ccsinfo.com/  for 30 years.
Any c-code is acceptable.
I have looked all Youtube codes and other places, but all the use PCF8574 interface, but not direct I2C
Regards
oh3gdo
  • oh3gdo
    oh3gdo over 4 years ago in reply to shabaz +1
    Thank you shabaz. I looked the code. It seems working. I have to translate it to CCS, but this is a small work. I would like to look lcd_init() function. It is the most important in every LCD codes.…
    shabaz over 4 years ago
    Hi,
    A lot of these displays are all the same, you can search for a slightly different model number and see if you can find code for that.
    These displays mostly use the traditional HD44780 instruction set, but just carried over I2C.
    For instance, I used a display with a ST70xx chip too, but a different part code, my C source code using I2C is on GitHub. It should be compatible with what you are using.
    Hi,
  • oh3gdo
    I have used LCD mote 40 years, but this I2C lcd is my first.
