Member and Staff Blogs Mystery Project #1 - Pi Pico HID Volume Controller
  • Author Author: dougw
  • Date Created: 5 Apr 2025 2:00 PM Date Created
  • Views 5782 views
  • Likes 12 likes
  • Comments 51 comments
  • mystery project
  • pi pico volume controller
  • volume controller
dougw
dougw
5 Apr 2025
Intro
This is the opening salvo in my 4 project push. Rather than simply presenting a chronological documentary or a report format with objectives and dry design documents, I wanted to make it a bit more interactive, so I presented pictures of the system for viewers to creatively deduce what they were looking at. This added a lot of interesting ideas to the blog comments. This blog is now updated, including a new title (to make the blog more searchable) and information identifying what the project does. I would like to thank the commenters for making this simple project into a more interesting and entertaining blog.
This project was a result of my need for volume control of the speakers on my PC. The speakers have a volume control, but it is in an awkward location. I wanted something more convenient. My keyboard actually has function keys that can control volume, but I also find that an awkward method of volume control. It requires 2 keys to be pressed multiple times to reach a desired volume. The device shown here is an intuitive volume knob that can be positioned very conveniently. And I use it every day.
These are the clue images
  • this view does not show any cables....Relaxed
Here is the second image - showing an additional surface with the usual feline photobomber...
The next image will show the PCBs inside...
Okay - here is the exploded view....some of it should be quite recognizable...
Note how the main PCB slides into a slot making the set screw in the knob the only fastener in the system.
I had to play hockey this evening, so I didn't get around to a more complete description of the system, but I will try again tomorrow.
In the mean time - here is another picture of the assembled system....
Project Description
This device is a simple volume control for PC speakers.
It uses a Raspberry Pi Pico to read a mechanical rotary encoder and convert the rotation into HID keyboard volume control commands sent to a host PC via USB.
The Pi Pico is mounted on a custom PCB which simply provides connections between the Pico and the encoder.
Here is a schematic of the relevant connections:
Schematic
Firmware
# Pi Pico Volume Contrroller by Doug Wong 2025
# Pi Pico HID volume firmware
# This program reads a mechanica rotary encoder that generates a quadrature signal on 2 pins
#  the up or down pulses are sent to the host computer via a HID USB driver that emulates a keyboard
#  the HID commands are volume controol instructions
# import libraries
import usb_hid
import board
import digitalio
from adafruit_hid.keyboard import Keyboard
from adafruit_hid.keycode import Keycode
from adafruit_hid.consumer_control import ConsumerControl
from adafruit_hid.consumer_control_code import ConsumerControlCode
# Define pin numbers for the rotary encoder
CLK_PIN = board.GP16
DT_PIN = board.GP17
SW_PIN = board.GP18
# debouncing variables
clk_last = None
count = 0
keyboard = ConsumerControl(usb_hid.devices)
# Define Encoder pins
clk = digitalio.DigitalInOut(CLK_PIN)
clk.direction = digitalio.Direction.INPUT
dt = digitalio.DigitalInOut(DT_PIN)
dt.direction = digitalio.Direction.INPUT
sw = digitalio.DigitalInOut(SW_PIN)
sw.direction = digitalio.Direction.INPUT
# Define USB HID volume control commands
def ccw():
    print("CCW")
    keyboard.send(ConsumerControlCode.VOLUME_DECREMENT)
def cw():
    print("CW")
    keyboard.send(ConsumerControlCode.VOLUME_INCREMENT)
# Endless loop to read encoder and send volume commands
while(1):
    clkState = clk.value
    if(clk_last !=  clkState):
        if(dt.value != clkState):
            cw()
        else:
            ccw()
    clk_last = clkState;
Discussion
This volume control device is a very simple build that uses parts I already had lying around. Normally I probably wouldn't design a PCB board just to connect an encoder, but I had a PCB that already included the right connections. I enjoyed the simplicity of the build and I really enjoy the convenience it provides for a function I use every day. One thing I may do to improve this device is to replace the knob with a more massive knob that would allow it to be spun and have its momentum continue spinning until it is stopped.
Again, I would like to say I enjoyed the interesting comments in response to the mystery images.
Other Mystery Projects
Mystery Project #1
Mystery Project #2
Mystery Project #3
  • scottiebabe
    scottiebabe over 1 year ago in reply to beacon_dave
    Had to see what it looks like. No idea what to use it for though.
    beacon_dave over 1 year ago
    Looks like it may have been designed to fit over one of your endless supply of ice hockey pucks ?
    beacon_dave over 1 year ago in reply to scottiebabe
    I think you may be getting addicted to these eVapes... Smoking
    It's déjà vu all over again  Slight smile
    "I know what this is..."
    "It's an espresso machine..."
    "no no no, it's a snow cone maker..."
    "is it a water heater ?"
    https://www.youtube.com/watch?v=0vyQc2XUjn0&t=6s
    dougw over 1 year ago in reply to scottiebabe
    nope...but it has a microcontroller
