Member and Staff Blogs Open-Source Cardiography Signal Measuring Device
  • Author Author: milosrasic98
  • Date Created: 26 Oct 2024 11:01 PM Date Created
  • Views 2248 views
  • Likes 15 likes
  • Comments 16 comments
milosrasic98
milosrasic98
26 Oct 2024
Hi!
I started writing on E14 in January of 2018 when I was first year of college, 6 and a half years later and around 70 blogs here later, I've finally gotten my Master's degree in Electrical Engineering! This site was a crucial part of that journey because I gained more relevant, practical experience by reading other member's blogs and working on my projects than through classes! I've made my Master's thesis project open-source, as the name of the project implies, it's a device for measuring and analyzing cardiography signals. I'll do a video or a long blog about everything on E14 as well, but until then, if someone wants to check it out, here is the GitHub repo: https://github.com/MilosRasic98/OpenCardiographySignalMeasuringDevice/tree/main
My goal with this project was to experiment with blood pressure measurement algorithms where I might have added a few more things along the way! So the device measured the air pressure in the arm cuff, ECG, PPG, and signals from a stethoscope that I've converted into a digital one. Through all of my research, the main thing I found is that commercial blood pressure monitors don't have a standard way of being tested, like an apparatus, their results are just compared to previous devices. The gold standard in 2024 for non-invasive blood pressure measurements is still the manual method with a hand pump and a stethoscope!
Below are a few pictures of the device as well as the GUI I developed for it.
P.S. If you are reading the GitHub and have any questions or comments (or if translation is needed somewhere, pictures still in Serbian) feel free to write to me!
Kind regards.
Milos
  • milosrasic98
    milosrasic98 over 2 years ago in reply to DAB
    Thank you! I had a few internships and jobs along the way, and since the work there would be much more interesting and practical, it was really hard to force myself to go back to books and theory! In a battle between writing Fourier transformations on paper and working on a drone, Fourier doesn't stand a chance!
  • milosrasic98
    milosrasic98 over 2 years ago in reply to colporteur
    Thanks! That feature required a lot of filament changes and gluing, but I love how it turned out in the end!
  • milosrasic98
    milosrasic98 over 2 years ago in reply to javagoza
    Thank you, glad you like the project! Wanted to make it open-source, since I hit so many roadblocks when I tried playing around with blood pressure measurement for a Design Challenge here without going into research papers, so I wanted to open it up to anyone curious (I'll also for sure be doing more in detail stuff on the topics covered in the project itself, either through blogs or videos).
  • milosrasic98
    milosrasic98 over 2 years ago in reply to michaelkellett
    Thank you! Glad you like the project, most of the ones I've seen are purely theoretical, but I really wanted to have something physical and be able to design a PCB for it!
  • milosrasic98
    milosrasic98 over 2 years ago in reply to Jan Cumps
    Thanks!
