Member and Staff Blogs What's new in fairy tech?
  • Author Author: scottiebabe
  • Date Created: 16 Nov 2023 1:35 AM Date Created
  • Views 2863 views
  • Likes 12 likes
  • Comments 19 comments
scottiebabe
scottiebabe
16 Nov 2023
The first set of fairy lights I purchased a few years ago had a very rudimentary embodiment. Just two AA batteries, an on/off switch, and a string of miniature LEDs on enamel wire.
I love the simplicity of the design... The design works well enough with disposable alkaline batteries. However recharge cells don't work very well on their own, as their combided state of charge voltage very quickly drops below the forward voltage of the white LEDs.
Fairy Tech 2.0
Browsing at the dollar store today, I found some new fairy lights which included some circuitry on a PCB. What could it be?
image image
Same general look and feel as before.
Now included is a three position switch!
The mysterious PCB
No sign of an inductor anywhere Disappointed. Just a
- 8-pin MCU?
- Watch crystal
- SPDT Slide switch
Fairy Tech 3.0
I can upgrade this new set of fairy lights with a boost converter module capable of operating of a single alkaline/Ni-MH cell
Module based on ME2188 https://file.elecfans.com/web2/M00/64/78/poYBAGMHOg-APsG0AAge4TQOpd0961.pdf
I bought a value pack awhile back thinking I would receive a selection of different output voltages. Nope, I got a bag of identical modules and each has a nominal output voltage of 5V. So, I added an additional 50 Ohm series resistor to limit the current to approximately 40 mA.
I am taking a bit of a gamble assuming the MCU is 5V rated. If it gives up the ghost, I'll replace it too.
All for now.
    beacon_dave over 3 years ago in reply to scottiebabe +1
    Out of the box they can also sometimes be a bit too bright for fast lenses with wide open apertures. Arducam do a low-cost F1.6 C-Mount lens which can be used with the likes of a R-Pi HQ camera for bokeh…
    Looks like you are all set for some bokeh photography now Slight smile
    https://www.nikonusa.com/en/learn-and-explore/a/tips-and-techniques/bokeh-for-beginners.html
    I let Xmas cheer get the better of me last year and ended up with some USB powered light strings.
  • scottiebabe
    scottiebabe over 3 years ago in reply to beacon_dave
    That's wonderful! I can try, but LEDs don't have quite the same wonderful colors as the old tungsten mini-lights with painted glass.
    I have some neopixel fairy lights that might make some warm colors...
    Arducam do a low-cost F1.6 C-Mount lens which can be used with the likes of a R-Pi HQ camera for bokeh work for video as well as still photography.
    https://www.arducam.com/product/arducam-35mm-f1-6-mirrorless-c-mount-lens-for-raspberry-pi-hq-camera-with-c-cs-adapter-ln052/
    https://www.amazon.com/live/video/3fe10de00abf4e848156572658f5f50a?ref_=dp_vse_lbvc_2
  • scottiebabe
    You're a natural! That looks awesome! You have inspired me to give it a try!
  • scottiebabe
    I'll randomly choose colors from this color palate and write them to my neopixel fairy string
    # Christmas spirit for beacondave
    import machine, neopixel
    import time
    import random
    # h degrees
    # RGB 0 - 255
    def hsv2rgb(h, s, v):
        h /= 360
        if s == 0.0:
            return v, v, v
        i = int(h * 6.0)
        f = (h * 6.0) - i
        p = v * (1.0 - s)
        q = v * (1.0 - s * f)
        t = v * (1.0 - s * (1.0 - f))
        i = i % 6
        v = int(v*255)
        t = int(t*255)
        p = int(p*255)
        q = int(q*255)
        if i == 0:
            return v, t, p
        if i == 1:
            return q, v, p
        if i == 2:
            return p, v, t
        if i == 3:
            return p, q, v
        if i == 4:
            return t, p, v
        if i == 5:
            return v, p, q
    # Neopixel string with 50 pixels
    np = neopixel.NeoPixel(machine.Pin(28), 50)
    np.fill((0,0,0))
    np.write()
    time.sleep(1)
    xmascolors = ((46,67/100,1),(15,96/100,89/100),(334,100/100,84/100),(2,96/100,77/100),
                  (76,70/100,78/100),(127,92/100,56/100),(191,85/100,31/100),(36,46/100,84/100))
    for i in range(50):
        rgb = hsv2rgb(*random.choice(xmascolors))
        np[i] = rgb
    np.write()
  • scottiebabe
    scottiebabe over 3 years ago in reply to scottiebabe
    WS2812Bs don't reproduce colors quite as well as I would hope...
    I wonder if there are HD neopixels...
    I bought this handsome dude at the dollar store too
    Perhaps I should choose a smaller figurine...
    Nice work. Very bokeh ! Slight smile
    You could perhaps try the Santa nutcracker with the small Xmas tree in the distance with its lights on.
    Perhaps using an infinity mirror or a fibre optic lamp as the background light source could produce an interesting result.
    In the past I've pondered about skeleton tree/leaf type structures with LEDs inserted at the ends so that in real life they aren't overwhelming but when you take the bokeh photograph it suddenly pops out at you.
    I'm not sure the best material to use however. I was thinking of perhaps microbore copper plumbing pipe ranging from 4-10mm outside diameter but not sure that you get Ts or reducing Ts at those sort of diameters. Also got to make it possible to thread a wire through it to the LED.
    I think it might call for a a micro brazing torch and a lot of patience.
    LED-wise then perhaps something similar to the dLUX-dLITE shaped LEDs to diffuse the light.
     https://www.adafruit.com/search?q=dLUX-dLITE
     I've seen skeleton lamps done with 1/2" plastic pipe and 40W golf ball lamps but was envisioning something a bit more intricate.
  • scottiebabe
    I have seen a few light-up bare tree that look pretty jazzy
  • scottiebabe
    Yes, they would be interesting to photograph.
    What I had in mind was something similar to this sort of branch-like framework structure
    (images from a Vectorworks 3D modelling CAD tutorial by Luis M Ruiz)
    On the left would be more like the real-life design with the pea-sized LEDs at the end of the branches (pretend the larger circle outlines aren't there) but then when you took the bokeh photograph, the light from the LEDs would then de-focus into the larger soft circles as seen on the right in the final render.
    Being able to sculpt the framework would give control over the shape and distribution of the bokeh effect in the photograph.
