Engineering Life
Engineering Life
Forum Magnetic Radiation
Join Engineering Life to participate - click to join for free!
  • Replies 33 replies
  • Subscribers 42 subscribers
  • Views 7679 views
  • electro magnetic engineers
Magnetic Radiation
lescolliershustoke@virginmedia.com
lescolliershustoke@virginmedia.com over 9 years ago
Hi
     a question :>
I have a solenoid and it has a certain range to it, i.e. the magnetic field does not go on fro ever for practical purposes.
I can adjust the design to gain more range, I can wind more turns on the armature but this won't extend the range if the core material saturates out. I can up the voltage and hence the current, but this creates more heat that I have to dissipate, and I want to power from a battery at the end of the day. So I am trying to get the longest range I can from 10 to 14 volts.
Does anyone have an answer on which parameter to try moving first assuming the range I have is not good enough.
regards
Les C
    michaelkellett over 9 years ago in reply to rachaelp +2
    Can you draw a diagram of what you are trying to do, or at least explain it better. Generally speaking magnetism is not a long range phenomenon (ie it's pretty weak once you are separated from the source…
    jw0752 over 9 years ago in reply to lescolliershustoke@virginmedia.com +2
    Hi Les, The magnetic field lines, that are being generated by a specific amount of power (Amps times Volts), are part of a magnetic circuit that by convention comes out of the north pole and loops around…
  • D_Hersey
    D_Hersey over 9 years ago +2
    Frequently Used Equations – The Physics Hypertextbook Radiation – The Physics Hypertextbook
  • gdstew
    gdstew over 9 years ago in reply to lescolliershustoke@virginmedia.com
    All methods to do what you want do do have already been mentioned on this thread as of at least a day ago. All options to increase the range of the solenoid
    by increasing the reach of the magnetic field (in this case this is what it should really be called) will require an increase in power, it's the law. At this point since
    you are the only one that knows what you are actually trying to do (although you have been asked twice now to better explain it) and all the options have been
    on the table for a while, no one else can add much to the discussion about your specific case or come to any kind of reasonable conclusion as to what would
    probably be the best thing to do. So at this point it's up to you to figure out which method you want to use, or provide more information on what you are trying
    to do so the others that may have a better understanding of magnetics can provide further guidance.
  • lescolliershustoke@virginmedia.com
    lescolliershustoke@virginmedia.com over 9 years ago in reply to gdstew
    Hello Everyone
                             can I start by thanking you all so much for your contributions I have plenty to go at.
    I am sorry I have been a bit cagy with details My patent agent said that I must not divulge anything about the device as it may prejudice my patent application which I will make in due course. That's not for one minute inferring that you might want to copy the idea, just simply that if you did not know the content you could not have been the one to spill the beans, does that make sense, I hope so and please please do not take offence. Non intended.
    I will come back when I done some more work and let you know how I got on. Untill  then Many thanks for the input. Sufficient to say that if I am successful we may have collectively saved a life.
    Regards
    Les Collier
    DAB over 9 years ago in reply to lescolliershustoke@virginmedia.com
    Hi Les,
    Thanks for clarifying your post.
    I understand, having been through the patent process, I fully understand the intense level of secrecy involved.
    Good luck with your idea and I am very interested in what you end up with.
    Please keep us informed and let us know if you need more support.
