Member's Forum How can you manage to damage a soldering iron like this?
  • Replies 30 replies
  • Subscribers 598 subscribers
  • Views 3257 views
  • soldering tips
  • soldering iron
  • soldering
cstanton
cstanton over 6 years ago
My first thought is, perhaps it's corrosion, from high or excess heat, these are disposable parts after all, but what really contributes to this kind of wear, and is there anything that can be done to prevent it being so sudden or so soon?
Often I find the soldering tips in the workstation to be bent, or the end of the tip looking like it's snapped off.
What're your thoughts?
How long do tips last for you or how often do you replace them?
What do you use to take care of your soldering iron?
    shabaz over 6 years ago +9
    I was going to say I've used the same tips for maybe 6+ years, but then I was reminded of 'Trigger's broom' : ) www.youtube.com/watch
  • rsc
    rsc over 6 years ago +8
    That tip may have started out that short, they come in many different shapes and sizes. I have three different sizes I use: Short and fat = higher wattage. (usually) or someone has been cleaning the tip…
  • Gough Lui
    Gough Lui over 6 years ago +7
    That looks like a tip from a Tenma hot air rework combination station (rebadged Atten). I would know ... because I have one, along with a spare soldering iron assembly when element14 last had it on special…
  • 14rhb
    14rhb over 6 years ago in reply to cstanton
    That's serious damage for such a short period of time. Like fellow members have elluded to, perhaps being careless over a many years could result in some tip wear, but one month !
    dougw over 6 years ago in reply to fmilburn
    Ahhhh….the mystery tip.... To tell the truth, I don't recall why I bought that tip. I have a vague recollection that it was included in a bargain pack of tips where I was interested in the other tips.
    (I didn't show my collection of spare tips that have not been used)
    It might be good at removing SMT parts with that dimension, but I really don't know what it is was designed for.
    It looks like I heated it up at least once, however it certainly hasn't been used much.
    I sometimes buy bargain tips to see if they will work and fortunately I have a couple of metal sleeves that adapt various inner tip diameters to the heater diameter so they usually work okay.
    That collection is all the tips I've used in the last 15 years. (except for my 2 older uncontrolled irons that served me for the previous 3 decades)
    dougw over 6 years ago in reply to cstanton
    Wow, I didn't make the connection that they were the same tip and it was only a month.
    That really looks like someone cleans their tip with a file.
    Judging by the condition of the barrel, the comment about acid core solder also looks valid.
    It might be worth posting a little sign with soldering "tips and instructions" on it.
    dougw over 6 years ago in reply to 14rhb
    You might as well spill the beans - I don't know what that tip was designed for...image
    shabaz over 6 years ago in reply to dougw
    Weird tip! I'm going to guess at either some SMD passives, or surface-mount LEDs (e.g. for LED strip rework), or it could be for wood burning (i.e. craft stuff) for parallel lines, or for heat-sealing bags
  • 14rhb
    14rhb over 6 years ago in reply to dougw
    I assumed it was for working with simple SMT devices, as shabaz and you have elluded to: most probably for desoldering such components.
    Or in the hands of someone at cstanton makerspace...perhaps it could be converted to a standard tip in a few weeks image
    • Vote Up +5 Vote Down
  • rusgray
    rusgray over 6 years ago in reply to shabaz
    You're correct. The notched tip is for desoldering passives. You can get different sized notches for different component sizes (0603, 0805, etc.) As an example, here's what Metcal offers for their MX-series irons: SMTC Series Slot new
  • gam3t3ch
    gam3t3ch over 6 years ago
    I have one soldering iron like that its seen more use then just soldering works great for melting plastic and well whatever I don't want to use my good iron on.   I have been using the same tips on my soldering station for almost 10 years now prior I bought cheap irons and well they would only last a few months to a year.  So I was surprised when my current one has lasted so long.  Proper cleaning and storage and using it just for what it's meant for seems to do the trick.  lol
  • cstanton
    cstanton over 6 years ago in reply to gam3t3ch
    I hear you, I returned to this soldering iron after leaving it out for 2 weeks to find... the tip was slightly sheered again and had been bent. I think someone's used it as a stabbing implement.
    hmmm using a soldering iron as a pry bar. I hope it saved somebody's life, otherwise it might illicit some criticism. Where is the emoji for sarcasm?
