Member's Forum shared ground
  • Subscribers 631 subscribers
  • Views 591 views
  • xlr
  • power supply
  • psu
  • voltage
shared ground
loliampol
loliampol over 10 years ago
so i wanted to make a universal power supply for my "pc room" and i wanted to do it with XLR, because it's round, it has sturdy cable's and it has three pins. So my plan was to have one 5v, one 12v pin, and one shared ground pin. but will this work? or wil it set my house on fire?
  • loliampol
    0 loliampol over 9 years ago in reply to jw0752
    thanks for the good answer!
  • loliampol
    0 loliampol over 9 years ago in reply to michaelkellett
    that's not a problem, because i don't and am not planning to get any xlr equipment
    0 jw0752 over 10 years ago
    Hi Pol,
    The shared ground should not be a problem but just keep in mind that the wire to the ground must be able to carry the current of both the 5 volt and 12 volt rails.
    0 michaelkellett over 10 years ago
    XLR connectors are for audio and signal, using them for power makes expensive accidents more likely.
    There are many other connector types you could consider but if you NEVER use XLRs for anything else they would be OK.
    If you use the 4 pole XLR plugs and sockets accidents are less likely. The Neutrik ones are rated at 10A but cheaper ones don't quote a current rating.
