Member's Forum Help to source a motor
  • Answers 2 answers
  • Subscribers 631 subscribers
  • Views 512 views
flar
flar over 9 years ago
Hi and Help
Could anyone help in sourcing a motor.
We live in the UK. Some years ago my father was in the US and purchased an interesting clock.
It was made by Kinetico Studies in Arkansas please check out either gordonbradt.com or search 7 man clock on youtube
Unfortunately the driving motor/gearbox failed and the clock no longer works.
The motor manufacturer is Autotrol
The model number is 500
The variant is 0138
ie Autotrol 500-0138
This should relate to a motor spec of 230V synchronous with an output of 4 revs/min
Please note this is 4 rev/min when connected to the 60hz in the USA
This will give 3 1/3 in the UK but the clock has cleverly been regeared by Kinetico to operate correctly on the UK 50 Hz
Autotrol only sell 200off min quantity
Kinetico are service only no spares
My father is 85 and has terminal cancer and has expressed the wish to seeing the clock working once again
Obviously purchase, shipping and time can be compensated
If anyone can help it would be much appreciated
Thank you for reading
    0 mcb1 over 9 years ago
    Do you know which part has failed, ie the motor or the gearbox.
    Most of these seem to be the same with different gears inside.
    I did see that they use a capacitor between some of the windings.
    Knowing how these dry out, is it possibly the phasing capacitor from preventing it working.?
    Have you approached them with your situation ?? ... you never know.
    mark
  • koudelad
    0 koudelad over 9 years ago
    I tried to search for this on Google and eBay and it seems to be so old and rare that it is not available.
    I see at least four options here:
    1) Let someone open your current motor chassis and try to fix the gearing / motor. The damage might not be irreparable.
    2) Regularly search on auction portals. (It might take a long time...)
    3) If you don't want to wait for some auction etc., one solution could be to buy a stepper motor with the same shaft diameter that is on your broken engine, so you can change the gear on the shaft. Making a motor driver that drives the motor with 3 1/3 RPM is definitely possible to make. (Of course, it won't have the original motor and power supply and there will be some electronic circuit needed to be hidden...)
    4) Order the repair at Kinetico, which seems to be $ 850 (their website says they have some engines). This might require additional power converter from 110 V 60 Hz to 230 V 50 Hz.
    David
