Member's Forum N64 Portable Problem (Please Help)
  • Replies 14 replies
  • Subscribers 631 subscribers
  • Views 1860 views
  • newbie question
  • help!!
  • ben heck
  • nintendo 64
  • help!
adamsoileau1
adamsoileau1 over 8 years ago
I am working on N64 portable right now, and like Ben Heck, I am having problems. I rewired the cartridge slot, and it worked great. Then I started to wire the batteries to the N64, and I had problems. On many N64 portables on Instrucatables, they use a Texas Instruments WAS PTH12050 chip, to bump the 7.4 - 12 volts from the batteries to 3.3 for the N64, (because the N64 needs 3.3 volts and 7.4-12 volts). I am using 4 18650 batteries, in parallel and series. So around 7.4 volts with double the amps. It ended up being about 8.4 volts, but when I wired it to the power converter, the output, instead of being 3 volts was 0.5 volts. (This does include the 100 uF capacitor and the 2k resistor that the pages required). This did not work, so then I tried to wire the batteries directly to the board, and 3 volts from another source. This still did not work, but the indicator light was on. I did make sure that the N64 worked with the usual connector, and it worked off the wall. Any tips? I have been stumped on this for a few weeks. I included the wire diagram I used, the circuit I wired, and the link to the page. Any help would be useful.
  • hardeng
    0 hardeng over 8 years ago in reply to jw0752
    Yes that's correct. The pin in between positive input and ground should
    also be connected to the positive input.
    Nathan
    0 jw0752 over 8 years ago in reply to adamsoileau1
    adamsoileau1  wrote:
    Thank you so much for responding! The output is not even a full volt. It does run at 12 volts, but the YouTube videos and instrucatbles pages say that it should run at 7.4 volts. Should I just buy a boost converter? Last week I screwed up the polarities, and it started smoking, but I did not notice any damage. The input is 8.4 volts.
    Sent from my iPhone
    Hi Adam,
    If it was hooked up reverse polarity for even a short period of time it has probably been damaged. You may not be able to see physical damage as it is often subtle and internal. Best to get a new module. In this business the best lessons are taught with smoke and occasionally some sparks. I have certainly seen my share.
  • adamsoileau1
    0 adamsoileau1 over 8 years ago in reply to hardeng
    The pin at the top left corner, I have ground, because of the white streak on the capacitor. Pin 3 on the left I have positive. And the pin in the top right corner is output. So the pin in between the negative and positive on the left should also be positive?
    Sent from my iPhone
  • hardeng
    0 hardeng over 8 years ago in reply to adamsoileau1
    You still need to tie the track signal to the input if you are not using
    tracking otherwise the output will stay low. If you do this and set the
    input to 12v then it will work.
    Nathan
  • hardeng
    Vin+ means the positive pin of the input. The other input pin is ground. In
    your pic on the left hand side where your input is and capacitor,  pin 2 is
    the second one from the top. On the first pin you have connected Vin+.
    Nathan
  • adamsoileau1
    So if wire this so that the input instead of 8.4 would be 12 for the converter, it would work?
  • adamsoileau1
    Which pin is pin 2. And Vin is positive right?
    Sent from my iPhone
  • hardeng
    If your source is 7.4V and you want 3.3V out then you want a buck that can
    operate with an input lower than 7.4V. But the input must be maintained
    greater than 3.3V. Or you can use a buck boost. When the input is lower
    than the output it will operate in boost and when the input is greater than
    the output it will operate in buck mode.
    Nathan
  • adamsoileau1
    0 adamsoileau1 over 8 years ago in reply to jw0752
    It is a 1.8 k resistor. It uses a 1.8 - 2 k resistor.
    Sent from my iPhone
  • adamsoileau1
    Sent from my iPhone
