Member's Forum New product
  • Replies 23 replies
  • Subscribers 624 subscribers
  • Views 3613 views
New product
Rik
Rik over 3 years ago
I am an inventor I had a perfect idea so I designed and made it work the kinks out of it and has been operating now two years. It's time to get out here is my problem I have no clue how or even the finance to do anything
  • bradfordmiller
    bradfordmiller over 3 years ago
    You might look into taking a class in entrepreneurship. It will give you an overview of what it takes to start a business and run it during it's early phases.
  • ggabe
    ggabe over 3 years ago
    I like the idea!  However, I'm not an investor-kind, so I'd rather point you to a resource to help you to tackle the investor-kind. They would all want a pitch deck, something like described here: https://www.uschamber.com/co/run/business-financing/terms-to-know-before-pitching-investors
  • bidrohini
    bidrohini over 3 years ago
    Here are some funding platforms for projects:
    www.electronics-lab.com/.../
    Jan Cumps over 3 years ago in reply to anniel747
    This design, that involves groundwork, cabling, installation and adaption to local (and regularly evolving) garbage can counts and sizes, may be better suited for local business.
    It's a great idea and well executed. I don't think there's unique invention that can be patented and then monetised.
  • anniel747
    anniel747 over 3 years ago in reply to Rik
    These days if you want to sell you must think global.
  • Rik
    Rik over 3 years ago in reply to anniel747
    It doesn't snow here mate but there always a fix for that good point Point up️
  • anniel747
    Wouldn't that pump freeze in cold climate? Is the lid heated to prevent ice accumulation?
  • Rik
    Rik over 3 years ago in reply to cstanton
    In Australia the  lift on a bin truck will max out at 75kg will lift 85kg so I did upgrade the whole system to lift 1500kg. The hydraulic systems runs a 5000kg ram yes it over kill but I did have the same concern most people do the right thing but there all ways one.
  • cstanton
    cstanton over 3 years ago in reply to michaelkellett
    michaelkellett said:
    my thoughts on what to do in the UK may be of limited use.
    As a person also in the UK I looked at it and thought "That's going to struggle when the brown bin is full of soil and the recycle bin is full of glass, and the black bin is also full of glass because people have filled the other bin".
  • Rik
    Rik over 3 years ago in reply to javagoza
    There is a lip about 25mm higher than the ground level and Case of extreme weather there is a sump that pumps water out but after two years of heavy rain it's not failed
