Member's Forum New clone on the block
  • Replies 38 replies
  • Subscribers 626 subscribers
  • Views 7697 views
scottiebabe
scottiebabe over 3 years ago
While browsing for low cost EVBs, I noticed that some of the ADS1115 (4-channel 16-bit delta-sigma i2c adc) are being fitted with an IC marked ADX111A.
Which turns out to be at least on paper nearly identically to the ADS1115.
https://datasheet.lcsc.com/lcsc/2302211830_analogysemi-ADX111AQFN10_C5359372.pdf
TI ADS111x
https://www.ti.com/lit/ds/symlink/ads1114.pdf
I'm not against competition. But the dark/dangerous side is when someone laser marks the chip as being TI's part, and sells it as a genuine TI part, when it most certainly isn't.
Glass half-full, glass half-empty....
  • scottiebabe
    scottiebabe over 3 years ago in reply to scottiebabe
    Tight squeeze for the 9V battery, but it should be okay...
  • Christopher678
    Christopher678 over 3 years ago
    This is not good you can't be a copy cat make up your own work
  • scottiebabe
    My DUT is sampling at 860.41 Hz at its fastest sample rate, the SGM58031 doesn't list that as a possible sample rate
    So my DUT with questionable laser markings most likely isn't this IC.
  • scottiebabe
    Opps, I missed one. The SGMICRO SGM58031
    At least they didn't blatantly copy the TI datasheet. Appears to be very similar but not identical.
    They also have a legitimate website!
    https://www.sg-micro.com/uploads/soft/20230515/1684143352.pdf
    Edit, there are two flavors of this IC. The non B suffix part is supposed to operate up to VDD=5.5V
  • scottiebabe
    Measuring a shorted input referenced to the EVBs local ground yields favorable results:
    Not too far off for still being on a breadboard
  • scottiebabe
    It would appear most of the ADS1115 breakout boards include their own common-mode noise generators....
    Common-mode noise generated across FB2
    The signal return path for I2C communication is through FB2.
    When I put this EVB into a test box, I will replace the ferrite bead with a zero ohm resistor.
  • scottiebabe
    Hold onto your hats boys and girls, this ADC is flying at a whopping 8 Sa/s...
    Applying a 1 Cycle/s test tone.
    Thanks ADI, neat demonstration and evaluation tool.
  • scottiebabe
    What a rabbit hole...
    https://github.com/analogdevicesinc/iio-oscilloscope
    https://wiki.analog.com/resources/tools-software/linux-software/iio_oscilloscope
  • scottiebabe
    This works too:
    #! /usr/bin/python
    import time, iio
    ctx = iio.LocalContext()
    ctrl = ctx.find_device('ads1015')
    voltages = ['voltage0', 'voltage1', 'voltage2', 'voltage3']
    for id in voltages:
        chan = ctrl.find_channel(id)
        print("{0}: {1}".format( chan.id, chan.attrs['raw'].value) )
    Credit: https://stackoverflow.com/questions/48565894/using-the-iio-python-package
    Maybe iio is the way to go...
  • scottiebabe
    I have no clue how to use Industrial IO (https://www.kernel.org/doc/html/v4.12/driver-api/iio/index.html) but it appears to work, if that's you're thing.
    I followed this guide: https://wiki.seeedstudio.com/4-Channel_16-Bit_ADC_for_Raspberry_Pi-ADS1115/
    I followed this guide for a bit, but then it quickly went beyond me https://elinux.org/images/b/ba/ELC_2017_-_Industrial_IO_and_You-_Nonsense_Hacks%21.pdf
    This as far as I got:
    But I can read data out of the sysfs interface:
    I don't know why I would use a low-speed ADC this way, but I guess I could if I wanted to...
    Update: I needed to load the hr timer module:
    Now following this guide as appropriate to the ads1115 works for 1 channel:
