Member's Forum New clone on the block
  • Replies 38 replies
  • Subscribers 595 subscribers
  • Views 6372 views
scottiebabe
scottiebabe over 2 years ago
While browsing for low cost EVBs, I noticed that some of the ADS1115 (4-channel 16-bit delta-sigma i2c adc) are being fitted with an IC marked ADX111A.
Which turns out to be at least on paper nearly identically to the ADS1115.
https://datasheet.lcsc.com/lcsc/2302211830_analogysemi-ADX111AQFN10_C5359372.pdf
TI ADS111x
https://www.ti.com/lit/ds/symlink/ads1114.pdf
I'm not against competition. But the dark/dangerous side is when someone laser marks the chip as being TI's part, and sells it as a genuine TI part, when it most certainly isn't.
Glass half-full, glass half-empty....
  • anniel747
    anniel747 over 2 years ago in reply to Andrew J +4
    Evaluation Board.
  • scottiebabe
    scottiebabe over 2 years ago in reply to scottiebabe +4
    Hold onto your hats boys and girls, this ADC is flying at a whopping 8 Sa/s... Applying a 1 Cycle/s test tone. Thanks ADI, neat demonstration and evaluation tool.
  • scottiebabe
    Tight squeeze for the 9V battery, but it should be okay...
  • anniel747
    Evaluation Board.
    michaelkellett over 2 years ago
    I  think its important that we should not confuse counterfeit parts with clone or plug in compatible parts.
    Industry has a long history of plug in compatible manufacture and I think that on balance it has always been a good thing. If Gene Amdahl and others had not challenged IBM I suspect that the computer industry would look very different from the way it is now.
    In the heyday of Silicon Valley it grew not least because all its secrets were so open.
    Not all clones or work-alike chips are bad - I have  a lot of experience with Giga Devices processors which are work-alikes (not clones) of ST chips - and cheap and available when ST parts were on 50+ weeks lead time.
    The ADX113 isn't passing itself off as a TI or AD part (I have no idea of its legality in other respects).
    It (or rather parts in the same family) looks cheap on the LCSC website but everything does. There isn't a UK distributor.
    The only way to know if it is really any good is to test it.
    I like to see real competition.
  • anniel747
    anniel747 over 2 years ago in reply to michaelkellett
    If prices look too good to be true...
    michaelkellett over 2 years ago in reply to anniel747
    The Analogy Semi parts look to be about half the price of the equivalent TI part based on 100 off from Farnell UK (for TI) and LCSC for AS.
    That's in the difficult region where you are not quite sure if it's too  good to be true or not.
    If Analogy are reading and care to send me as sample then I'll test it  (although it's not a part I use ...)
  • scottiebabe
    scottiebabe over 2 years ago in reply to michaelkellett
    Of course when you purchase from our corporates overlords (thanks Newark & Avnet for running this site) its not an issue to be too concerned about. You can be fairly certain you are getting genuine parts.
    Analogy blatantly copying the TI datasheet word for word and diagram for diagram isn't great.
    Then the follow on is then someone either remarks or buys bare dies and laser marks them with the TI device code
    Someone else adds the TI logo... Is that Analogy fault, no, but they are likely aware of it and encourage it.
    michaelkellett over 2 years ago in reply to scottiebabe
    True - Giga Devices have changed every single pin and register bit name in their data sheets. The silicon works exactly the same (as ST),(as far as I can tell.).
    It's a bit odd - making the mask set must be much harder than re-working a data sheet. In the UK copyright law is used to documents and gives quite good protection.
    In the end buying from a trusted distributor is the best protection in small volumes.
    But it does cut down your options because some quite good manufacturers have no major distribution presence in the UK (and I assume elsewhere).
  • misaz
    misaz over 2 years ago in reply to michaelkellett
    Their silicon do not work exactly the same. They fixed issues from ST errata. Slight smile
    michaelkellett over 2 years ago in reply to misaz
    Rats !
    They won't work with our work-arounds.
  • anniel747
    At least LCSC is not on the list. ustr.gov/.../2022 Notorious Markets List (final).pdf
  • scottiebabe
    Bit-banging I2c over rs232 in 2002, good job TI.
