Member's Forum New clone on the block
  • Replies 38 replies
  • Subscribers 594 subscribers
  • Views 6373 views
scottiebabe
scottiebabe over 2 years ago
While browsing for low cost EVBs, I noticed that some of the ADS1115 (4-channel 16-bit delta-sigma i2c adc) are being fitted with an IC marked ADX111A.
Which turns out to be at least on paper nearly identically to the ADS1115.
https://datasheet.lcsc.com/lcsc/2302211830_analogysemi-ADX111AQFN10_C5359372.pdf
TI ADS111x
https://www.ti.com/lit/ds/symlink/ads1114.pdf
I'm not against competition. But the dark/dangerous side is when someone laser marks the chip as being TI's part, and sells it as a genuine TI part, when it most certainly isn't.
Glass half-full, glass half-empty....
  • anniel747
    anniel747 over 2 years ago in reply to Andrew J +4
    Evaluation Board.
  • scottiebabe
    scottiebabe over 2 years ago in reply to scottiebabe +4
    Hold onto your hats boys and girls, this ADC is flying at a whopping 8 Sa/s... Applying a 1 Cycle/s test tone. Thanks ADI, neat demonstration and evaluation tool.
  • scottiebabe
    Tight squeeze for the 9V battery, but it should be okay...
  • scottiebabe
    Robot Clone Wars Rocket
    I am somewhat disappointed I didn't receive the clone listed above.
    Perhaps I got a genuine TI part? Or a clone marked as a TI part? hmmm.
    The IC's top package texture and laser markings look suspect to me...
    Performance wise, it performs well enough, especially considering I am powering the EVB directly off VUSB for a quick sanity test.
    Having an all-in scale error of 0.0207%, isn't too bad...
    The residuals from a linear fit indicate this IC has an INL approximately +-1LSB.
    For now I will attribute the measurement outliers to noise in my breadboard rats nest test setup.
  • anniel747
    anniel747 over 2 years ago in reply to scottiebabe
    With sanding marks clearly visibles you can be certain you have a fake.
    Jan Cumps over 2 years ago in reply to anniel747
    I'm not convinced that those are sanding marks. My claim is that it's a genuine part.
  • scottiebabe
    scottiebabe over 2 years ago in reply to Jan Cumps
    lol *shurg* Well, I won't be decapping the IC, so all I can go off are empirical measurements. Haven't decided what the obvious genuine versus clone test would be. Perhaps its a digital test, the clone appears to have a more extensive register map, so maybe I should start with that...
  • scottiebabe
    scottiebabe over 2 years ago in reply to anniel747
    I am skeptical on its origins, but hopeful for equivalent performance!
  • anniel747
    anniel747 over 2 years ago in reply to Jan Cumps
    What would they be? Badly buffed mold? That would also be fakes.
    I think that calling it a fake needs evidence/proof.
  • anniel747
    No paperwork.
  • scottiebabe
    I have no clue how to use Industrial IO (https://www.kernel.org/doc/html/v4.12/driver-api/iio/index.html) but it appears to work, if that's you're thing.
    I followed this guide: https://wiki.seeedstudio.com/4-Channel_16-Bit_ADC_for_Raspberry_Pi-ADS1115/
    I followed this guide for a bit, but then it quickly went beyond me https://elinux.org/images/b/ba/ELC_2017_-_Industrial_IO_and_You-_Nonsense_Hacks%21.pdf
    This as far as I got:
    But I can read data out of the sysfs interface:
    I don't know why I would use a low-speed ADC this way, but I guess I could if I wanted to...
    Update: I needed to load the hr timer module:
    Now following this guide as appropriate to the ads1115 works for 1 channel:
  • scottiebabe
    This works too:
    #! /usr/bin/python
    import time, iio
    ctx = iio.LocalContext()
    ctrl = ctx.find_device('ads1015')
    voltages = ['voltage0', 'voltage1', 'voltage2', 'voltage3']
    for id in voltages:
        chan = ctrl.find_channel(id)
        print("{0}: {1}".format( chan.id, chan.attrs['raw'].value) )
    Credit: https://stackoverflow.com/questions/48565894/using-the-iio-python-package
    Maybe iio is the way to go...
