PCB Design, Prototyping and Production
PCB Forum Design your own PCB Antenna
Join PCB Design, Prototyping and Production to participate - click to join for free!
  • Subscribers 134 subscribers
  • Views 3465 views
scottiebabe
scottiebabe over 2 years ago
I have been experimenting with a free planar 3D E&M simulation tool called Sonnet.
https://www.sonnetsoftware.com/products/sonnet-suites/
The price of their lite version is just right at a price of free.
I have used the tool for a few hours and found the tool quite easy and intuitive to use.
Instead of following the suggested geometry in an application note for an inverted-F antenna or meandered inverted-F antenna, design it yourself!
Based on my limited understanding of the tool, it simulate in a metal box. So you need to make the geometry of the box large enough such that the metal side walls don't influence the circuit your trying to simulate.
So I made a big box and drew a basic inverted-F antenna adjacent to a large copper plane.
I set the stack up to have the antenna on an FR4 substrate with lots of air space above and below the antenna under test.
My box looks somewhat comical, perhaps in the future I should find some rules of thumb for dimensioning.
image image
I placed a differential measurement port (the box labeled: 1) right at the antenna's feedpoint
Setup an s-parameter simulation from 2GHz to 3GHz
This antenna as a low return loss from 2.4GHz to 2.5GHz
With some parametric analysis of the antenna's geometry we may be able able to improve the return loss in the 2.4GHz band. You could export the s-paramaters of the antenna to design a matching/filtering network for an even better match to 50 ohms.
I am really only scratching the surface here. I am quite impressed to say the least.
There are a few demo projects included with the tool
Pretty neat, glad I downloaded it.
    Jan Cumps over 2 years ago in reply to anniel747 +3
    They are. I have a DC-DC converter here with a 10 layer planar (blog: GaN Point of Load converter 48V to 1V 50A - part 1: Design Overview )
  • rsc
    rsc over 2 years ago +2
    TI has an Application Note for a similar antenna AN043. I've been working on trying to etch (and solder) these types of patterns with my laser engraver.
  • anniel747
    anniel747 over 2 years ago +1
    Deleted
  • rsc
  • anniel747
    [deleted]
  • scottiebabe
    scottiebabe over 2 years ago in reply to rsc
    Ohh that's really neat! I was hoping to just use an exacto knife and some copper tape to experiment. A laser engraver sounds perfect for the task!
    I watch a few videos about the tool and many time they import cad files
    https://www.youtube.com/watch?v=wAlIYOZXYjE
    I tried importing IFA_USB.dxf into sonnet and it looks like it worked...
    I will try simulating that later, thanks for the recommended app note.
  • scottiebabe
    scottiebabe over 2 years ago in reply to anniel747
    Especially when they are tiny...
    Triple transformer. This circuit is partially based on a transformer design shown in:
    "A 1-V 5-GHz CMOS Multiple Magnetic Feedback Receiver Front-End"
  • rsc
    rsc over 2 years ago in reply to anniel747
    I've made some small RFID antennas using wire-wrap wire glued flat to a pcb also.
