Member's Forum New and Exciting
  • Replies 73 replies
  • Subscribers 588 subscribers
  • Views 5842 views
  • exciting technology
New and Exciting
dougw
dougw over 2 years ago
What is the most exciting technology you discovered or rediscovered this year?
This is not a question about significant leading edge technologies, it is just about what you currently find exciting.
Are you into VR? Like Meta Quest 3 or Apple Vision Pro
Are you into computers? Like Raspberry Pi 5 or Apple iMac M3
Are you into e-bikes - a massive trend
Are you into Machine Learning? Like Huskylens
Are you into RISK V or FPGAs? Like BeagleV Fire
Are you into AI? Like CHATGPT
Are you into robots and automation? Like commercial drone applications or self-driving cars
Are you into communications technology? Like SDR
Are you into gaming technology? (and games)
Re you into retro electronics? Like vinyl audio or tube amps
Are you into test instrumentation? and setting up a great lab
Are you into software/firmware? Like RTOS or real-time LINUX on microcontrollers
Or all of the above?
What turns your crank these days?
What is on your wish list?
What courses do you need to take?
  • baldengineer
    baldengineer over 2 years ago +4
    This year, I started to learn how to use edge machine learning beyond face and voice recognition. Currently, I'm working on a small project that uses vibration to determine if a motor is running. (and…
  • stanto
    stanto over 2 years ago +4
    dougw said: Are you into VR ? Yeah, I bought a HTC Vive, original, back when bitcoin originally boomed some years ago, and this year since everyone's picking up the Quest 3 I was able to afford a Vive…
  • anniel747
    anniel747 over 2 years ago in reply to beacon_dave +4
  • stanto
    dougw said:
    Are you into VR?
    Yeah, I bought a HTC Vive, original, back when bitcoin originally boomed some years ago, and this year since everyone's picking up the Quest 3 I was able to afford a Vive Wireless Adapter second hand, so now I also enjoy VR wireless! (except for a battery bank). It's required a little bit of modification because the adapter overheats! It seems intel and htc originally designed it only to handle the throughput of the original Vive, but with technology moving along as it is, the battery can run it for longer and it can push a higher resolution, so to handle it, it gets very, very hot. 80degC+ and it shuts off. With a bit of 3D printing and an active fan, 30-50degC. It's pretty good, I always preferred the tracking of the Vive ecosystem. I managed to get the Valve Index hand controllers too, which have full hand and digit tracking. I've tried tinkering with the leap motion for hand tracking, but the 'drivers' to get it to work aren't fully there, and most VR interfaces expect you to have buttons on the controllers, where as you don't for your hands.
    I picked up a couple of Pi 5's, I intend on using the PCIe output to then use a PCIe to PCI adapter and either plug in an old PCI graphics card, maybe a Voodoo 1 for laughs, or a PCI soundcard which no longer has supported drivers on Windows, such as an old Soundblaster Live 5.1 which has a pretty good sound chip on. Something to play with. And the additional one will likely upgrade my PiHole come proxy and DNS server.
    dougw said:
    Are you into AI?
    I went all in and bought a GeForce 4080 with the ethereum I mined on my 3080, then sold off the 3080 and found that hey, I can run stable diffusion pretty well on it! I've also tried to run my own LLM locally, which kinda works, but doesn't entirely in a way that's like OpenAI's ChatGPT, the guides that are available out there kinda suck and it's confusing. I'd frankly like to train my own dataset to use in stable diffusion or an LLM a like but again, there's no real decent tutorials on making the training sets, which is annoying, I'd like to create art from my own styles like some music videos do.
    I ashamedly have a stockpile of SDR like tech that I haven't picked up yet, I have a HAM Radio shield for an Arduino, a HackRF, and a ChipWhisperer, along with some RTL-SDRs that I'd like to make antenna for to receive satellite signals, it's a mixture of not quite having the energy to work with them and not having my HAM Radio license yet, getting it has been quite awkward.
    I've been having fun with the Steam Deck. I've been learning and having a bit of a hard time reverse engineering the BIOS for it, which is on a winbond flash chip, and decompiling and rebuilding its UEFI BIOS, to mixed success. It's annoying because the BIOS is a proprietary InsydeH2O BIOS and the open source UEFI Tools software doesn't quite support it because it's "too new". Valve Software removed functionality from the BIOS, such as being able to set RAM timings and the GPU and CPU clock frequencies with hidden form browsers that were unlocked, but have now removed from recent BIOS versions, and I'm trying to work out how to put them back in. It's very much a dark black box, and people who have worked out how to work with it gatekeep the information. It's also been fun to benchmark it and analyse its thermals, because it's an 'embedded system' kinda like working with the Pi, it has a very fixed scope for optimisation and getting the most out of it.
    I recently repaired my Vinyl record player, though I still need to determine why it has intermittent interference that seems to be on every revolution of the turntable. I did at least manage to remove a lot of the noise being produced to have a cleaner signal, and record from it into Audacity using a mixture of USB soundcards, but having to use a battery powered laptop to prevent some kind of ground loop interference. I'm a stickler for audio.
    I'd like a decent oscilloscope, along with a small training course on how to use *that oscilloscope*. I want to be able to observe and reverse engineering communications protocols, or be able to replicate them / emulate them on microcontrollers, I'm thinking handshakes that some games consoles do for their games controllers.
    HAM Radio courses, I would probably benefit from some kind of electronics course, but also programming assembly to be able to better decode and understand BIOS/firmware hex dumps.
    dougw over 2 years ago in reply to stanto
    I am curious if VR headsets cause you any discomfort - like dizziness?
  • stanto
    stanto over 2 years ago in reply to dougw
    Only in certain circumstances, such as:
    - The refresh rate is lower than 90hz
    - The frame rate is lower than 90fps
    - I'm dehydrated
    - The rendering suddenly stops and the rendered frames freeze, it is very disorientating
    When the frame timings are a mess, and the refresh rate and render rate isn't 90hz and 90fps, then sometimes when I remove the headset I have an after-effect of motion sickness where I have a dull headache and I feel nauseous, which lasts with me for a while.
    Typically though I'm perfectly fine and I can use it for hours on end.
    dougw over 2 years ago in reply to rsjawale24
    The emergence of low-cost SDRs  and low-cost VNAs really opens the door for us to indulge in this field.
    dougw over 2 years ago in reply to DAB
    My play list also exceeds my play time, but at least I won't run out of things to do.
    dougw over 2 years ago in reply to robogary
    Your mobile rig is quite something....
    dougw over 2 years ago in reply to strb
    What is your next priority lab acquisition?
    dougw over 2 years ago in reply to baldengineer
    That doesn't sound so small. Pretty tricky to get speed from vibration if the system is well balanced.
  • beacon_dave
    beacon_dave over 2 years ago
    Currently rediscovering Q-SYS control systems. I have just taken delivery of some of their core processors and signed off on a project that uses it at the core,  so time to figure out how to make best use of it and learn the quirks.
    It uses Lua as its scripting language so I will need to get more familiar with that.
    Q-SYS are now starting to bring in aspects of machine vision to their systems for better camera tracking and control automation. I guess automated theme parks are about to get more fun soon.
    Jan Cumps over 2 years ago
    These days: learning. 2 things:
    1. I re-found the joy of looking at good analogue designs, trying to understand them, master them.
    Meanwhile collect datasheets, manuals, blogs related to that. Read. Until I know what's happening.
    2. Learn to solder any* surface mount component reliably.
    *any!
