Member's Forum New and Exciting
  • Replies 73 replies
  • Subscribers 588 subscribers
  • Views 5885 views
  • exciting technology
New and Exciting
dougw
dougw over 2 years ago
What is the most exciting technology you discovered or rediscovered this year?
This is not a question about significant leading edge technologies, it is just about what you currently find exciting.
Are you into VR? Like Meta Quest 3 or Apple Vision Pro
Are you into computers? Like Raspberry Pi 5 or Apple iMac M3
Are you into e-bikes - a massive trend
Are you into Machine Learning? Like Huskylens
Are you into RISK V or FPGAs? Like BeagleV Fire
Are you into AI? Like CHATGPT
Are you into robots and automation? Like commercial drone applications or self-driving cars
Are you into communications technology? Like SDR
Are you into gaming technology? (and games)
Re you into retro electronics? Like vinyl audio or tube amps
Are you into test instrumentation? and setting up a great lab
Are you into software/firmware? Like RTOS or real-time LINUX on microcontrollers
Or all of the above?
What turns your crank these days?
What is on your wish list?
What courses do you need to take?
  • baldengineer
    baldengineer over 2 years ago +4
    This year, I started to learn how to use edge machine learning beyond face and voice recognition. Currently, I'm working on a small project that uses vibration to determine if a motor is running. (and…
  • stanto
    stanto over 2 years ago +4
    dougw said: Are you into VR ? Yeah, I bought a HTC Vive, original, back when bitcoin originally boomed some years ago, and this year since everyone's picking up the Quest 3 I was able to afford a Vive…
  • anniel747
    anniel747 over 2 years ago in reply to beacon_dave +4
  • scottiebabe
    scottiebabe over 2 years ago in reply to scottiebabe
    Also loved seeing the ESD sandals
  • beacon_dave
    beacon_dave over 2 years ago in reply to scottiebabe
    Handy for reducing static build-up whilst on vacation at the beach. Slight smile
    dougw over 2 years ago in reply to stanto
    I think of it like a Swiss Army Knife. Individual features may not be as good as dedicated instruments, but if you tried to buy a separate instrument to cover each feature, you would spend much more than the cost of this instrument. The questions are - do you need all of the features and are they good enough?
    dougw over 2 years ago in reply to dang74
    Humans will still take credit for advances by AI's...Relaxed
    At least until AI's get rights.
  • BigG
    BigG over 2 years ago in reply to stanto
    If you apply and get selected for the roadtest then it will cost you nothing other than the time taken to write up a report documenting what you learnt.
    Otherwise, if your requirements are within the spec of the product then, IMHO, you will get good use out of this or similar product (e.g. a similar product was roadtested earlier: /products/roadtest/rt/roadtests/619/sign_up_to_roadtest_2#pifragment-4106=9&pifragment-4100=4)
    The key benefit from this type of product is its portability as these type of measurement/analyser devices connect directly to your laptop/computer or even your phone, it opens up new avenues for data capture and analysis that was not always possible, or was quite complex to achieve, with a fully-fledged desktop oscilloscope.
    As said, it all depends on your application.
  • stanto
    stanto over 2 years ago in reply to BigG
    I appreciate encouragement for applying for the RoadTest program, it's nice to receive support. The RoadTest program wants people that can demonstrate the product and put it through its paces, that isn't something for a novice learning the ropes. I'll pass and casually look for other options Slight smile
    Determining that is a bit out my knowledge reach at the moment Slight smile
  • stanto
    stanto over 2 years ago in reply to electronicbiker
    electronicbiker said:
    I find it quite amusing to see all the info scrolling across the display on the car radio while the thin weedy voices try to sing louder than the shellac-induced snaps crackles and pops!
    Something about it is kinda satisfying, especially with how more modern sound systems try to handle noises it doesn't expect Slight smile
    about the only thing I can think of that could do that is the slightly increased load on the motor each time the 'sensor' for the velocity-trip mechanism is moved
    I suspect it's not entirely sat flush/level correctly and a part of it is causing friction, I took it apart and applied some grease to the plate the vinyl record sits on and it was reduced, but it'd take some effort to un-warp that chunk of metal. At least it reduced the volume of it significantly enough that it only showed up as a minor regular occurrence on the spectrograph.
  • ggabe
    ggabe over 2 years ago
    Making AI write your code. It helps me to focuses on what matters:
    • writing reusable tests
    • happily reorganize code
    • get moving again after stuck or procrastinating because of huge volume of code I’m missing or the code is just boilerplate
  • dang74
    dang74 over 2 years ago in reply to dougw
    LOL.  We will have to invent a word for a person that gets credit for the work carried out by entities under their control.  Wait a minute we already have manager.  Wink
  • iker46
    iker46 over 2 years ago
    For me it's ZigBee. I do have a propietary hub but i'm trying to buy compatible components even from other vendors. I have created really useful automations for my home
