Member's Forum Text-based schematics?
  • Replies 13 replies
  • Subscribers 625 subscribers
  • Views 3390 views
neuromodulator
neuromodulator over 2 years ago
I frequently end up spending a lot of time trying to make my schematics look nice. There's the whole dilemma of when to wire pins and when to just label them. Then of course, you must also figure out the best way to organize everything, where to position the components and when to hierarchize parts. Also, creating new symbols many times requires much more than drawing a box with pins, and can also consume a fair amount of time. This kinda reminds me of LABview, where lot of time is spent on rearranging nodes and wires, when ideally you would want to focus on the logic itself. It feels like there should be a more efficient way to do all this. Maybe using some standardized language? What do you think?
  • wolfgangfriedrich
    wolfgangfriedrich over 2 years ago
    There are 2 commercial "solutions", their websites are full of BS bingo probably for VC reasons.
    https://www.jitx.com/
    Code to Electronics - atopile
    And there is a free Python module
    https://devbisme.github.io/skidl/
    None of those are able to explain the problem they are trying to solve.
  • Andrew J
    Andrew J over 2 years ago in reply to colporteur
    Yes you can but I don’t think the syntax is described anywhere.  Historically there have been a number of workarounds that involved changing the text files.
  • colporteur
    colporteur over 2 years ago in reply to Jan Cumps
    Is it possible to take an existing file and modify it without using the application and get acceptable results? I've never played in the files, I just recall they were discussed in a KiCAD course I did. It just seemed impossible that the text produced the graphic representation. That blew me a way.
    dougw over 2 years ago in reply to Jan Cumps
    Every designer has their preferences and their productivity. I always have a pause before a final check prior to sending a design to be manufactured. During that final check I clean up both inefficiencies and weaknesses in the design, even if they won't likely affect performance. Or I might add in more test points or more intuitive labels. I not sure exactly how important all this is in circuit functionality, but I do catch some errors and the results are high productivity with a high chance of the PCB working. Other designers have different methods and performance, but that doesn't mean they would have better (or worse) performance using my methods..
    Jan Cumps over 2 years ago in reply to colporteur
    yes, although the structures are intended to support the graphic tools, the workflow and the manufacturing files.
    I don't see those getting generated by a text based front end. (in an achievable way)
  • colporteur
    Doesn't KiCAD have some underlying text base?
    Jan Cumps over 2 years ago in reply to dougw
    dougw said:
    I can't resist cleaning up schematics to minimize corners and crossovers, even though it takes time.
    It takes self-challenge:
    "Am I doing this because I can't sleep if there are cross-overs that can be avoided" or
    "Is this diagram clear enough that my colleagues (or me in 7 years) will be able to understand it".
    Good Enough is a valid KPI for efficiency improvements.
    I think of E-CAD as "word processors" for electronic design and I have my own conventions to make schematics "readable". I can't imagine a text base description language that would be as clear or readable. CAD systems have many tools to minimize the work and show connectivity at a glance and there are a lot of tricks to making the design process quicker and more readable. There are some conventions like making signals flow from left to right and top to bottom, but you are right, to make a schematic into something easily readable takes work. I can't resist cleaning up schematics to minimize corners and crossovers, even though it takes time. I find many techniques used to reduce schematic clutter (such as connections made with labels instead of wires and busses shrunk to a single line) to be confusing and time consuming to decipher, so I only use labels when making connections to a new page. I would actually rather make a bigger page than add more pages.
  • dang74
    dang74 over 2 years ago in reply to michaelkellett
    You are not alone with this.  I too have used block diagrams for the very top level.  Sometimes when I am looking at the higher level hierarchical code developed by another person I will translate it into block form manually on piece of paper as a way to help commit the names of the blocks and signals to memory.
    michaelkellett over 2 years ago in reply to dang74
    I find the interconnect in HDLs completely incomprehensible.
    So I use a block diagram editor at the top level to hang all the blocks together but I find the HDL much better at describing the logic.
    I know that some other people find the opposite.
    I certainly can't imagine doing analogue design in text.
    I would post an example but I'm supposed to be getting a big design to work right now so no time Frowning2
