Member's Forum why jumpstarter and not a cable boost
  • Replies 21 replies
  • Subscribers 550 subscribers
  • Views 1320 views
  • boost converter
  • battery
colporteur
colporteur over 1 year ago
I tried jump starting my aunts car and failed. What did start the care was my cousins nektech jumpstart device. Why one and not the other?
I'm on vacation so test equipment is in short supply. The dead car wouldn't even provide dash lights when connected to boost vehicle. I figured it should have started on cable boost or at least get lights. I'm thinking ratty booster cables.
It seems reasonable a cable boost or jumpstart work the same way. Curious minds want to know.
  • colporteur
    colporteur over 1 year ago +4
    I had to go back and try to determine why it didn't work. The picture is the connections of the four ends of the jumper cables. The cable is robust but the insulation wasn't stripped away before they were…
    shabaz over 1 year ago +3
    Hi! I think you're right, probably poor-quality jumper cables. Some have thin copper but thick insulation, and others have their wire ends folded over the insulation, and then a single crimp around the…
  • robogary
    robogary over 1 year ago +3
    maybe a bad clip connection to the battery post in the first try
  • anniel747
    anniel747 over 1 year ago in reply to Jan Cumps
    Mine melted the same way, the insulation they used is not heat resistant. Properly crimped they lasted a few years.
