Member's Forum Question of the Month: How often do you use a Handheld Oscilloscope?
  • Replies 43 replies
  • Subscribers 589 subscribers
  • Views 102282 views
  • Handheld oscilloscope
  • oscilloscope
  • question of the month
vivekvelusamy
vivekvelusamy over 1 year ago
e14 Question of the Month
Engineers are on the go. Gone are the days when engineers do most of their work in the lab or on the bench. They use test equipment in the facility or at a job site, that is, out of the ordinary locations. For these settings, engineers need handheld, portable equipment to make precise, accurate measurements. Handheld oscilloscopes are the focus of this month's Question of the Month: How often do you use a Handheld Oscilloscope?
    dougw over 1 year ago +3
    Some pros and cons for hand-held scopes: Hand-held Pros Portable - can be used in mobile applications Isolated - useful when you don't want the instrument grounded to mains ground Small - useful…
    Jan Cumps over 1 year ago in reply to Instructorman +3
    How would you define reasonably capable? The one I have, is comparable to a 100 MHz 2 channel bench scope like the Rigol 1102 for generic use and usability (including screen resolution). Except for elaborate…
  • obones
    obones over 1 year ago +2
    As a hobbyist, I have somewhat limited resources so between the antique CRT based unmovable Telequipment D1011 scope and the DSO Shell 150, I find myself using the latter more often that not.
  • dang74
    dang74 over 1 year ago
    I only used a hand held scope once or twice.  I bought a super cheap one online.  I think it was under $30.  I didn't realize until afterwards that the bandwidth was only 100kHz which really limits its use cases.
  • strb
    strb over 1 year ago
    I don't have a handheld scope at home and neither at work, until now I've always used bench scopes and I don't feel the need for a portable one now.
  • Gough Lui
    Gough Lui over 1 year ago
    I'd have to say "practically never" since I haven't had a need for one and the ones I have seen were not particularly exciting in terms of capability and specifications.
    Higher-end USB oscilloscopes connected to a laptop is the primary way I work when away from the lab.
    - Gough
  • BigG
    BigG over 1 year ago
    I really like using a scope that connects to a laptop, or tablet (typically via USB). You get a great UI and data analytics capability with this option.
  • Christopher678
    Christopher678 over 1 year ago
    I Never
    genebren over 1 year ago
    My DSO-TC2 is my only handheld scope.  I have only used it a few times as a scope but use it quite frequently as a component identifier as I build up PCBs and have tiny SMD components (mostly unmarked capacitors) fall off the PCB or get send flying during tweezer placement.
    DAB over 1 year ago
    I have never used a handheld Oscilloscope.
    Though back was I was an electronics technician, I would have probably used it a couple of times/week.
  • rsc
    rsc over 1 year ago
    My Rigol scope is about as portable as I need for now.  I'd like to get a handheld spectrum analyzer some day.
  • manojroy123
    manojroy123 over 1 year ago
    Depends upon project to project
    dougw over 1 year ago in reply to rsc
    A spectrum analyzer and a VNA would be nice....Relaxed
