Member's Forum Sanyo (Panasonic) Ni-MH Battery Charger Teardown
  • Subscribers 626 subscribers
  • Views 2088 views
scottiebabe
scottiebabe over 2 years ago
2 minute teardown.
I bought a starter kit of eneloop Ni-MH batteries and a wall charger (NC-MQN06U) circa 2010-2011.
HR-3UTGA 1.2V, min 1900 mAh, Made in Japan.
At the time they were all the rage: https://en.wikipedia.org/wiki/Eneloop
Today there are more high-capacity low self-discharge Ni-MH manufactures available.
The wall charger, charges cells in pairs at an advertised rate of 300 mA for AAs and 150 mA for AAAs.
Popping the cover open
A self-oscillating flyback provides and isolated and regulate 4 VDC supply to the charging circuitry.
Charging is managed with an 8-bit MCU EM78P259N
https://www.alldatasheet.com/datasheet-pdf/view/118218/EMC/EM78P259N.html
Charging current is regulated with a pair of ballast resistor providing an equivalent resistance of 3.57 Ohms
The charger briefly pauses charging and samples the cell voltages with the ADC input on the MCU.
When charging AAA cells, the charger PWM modulates the charging current at 50%, to achieve an average charging current of 150 mA.
Gough Lui’s teardown shows an even simpler Ni-MH charger. https://goughlui.com/2013/12/22/review-teardown-sanyo-eneloop-batteries-charger-nc-mqn04a/
  • scottiebabe
    If you try to charge an already charged set of cells, the charger terminates after ~20 minutes (I missed measuring the cell voltage).
    Once charging is complete, the charger floats the cells at ~1.47V, and periodically briefly charging to achieve a small trickle current.
  • scottiebabe
    scottiebabe over 2 years ago in reply to Jan Cumps
    It appears this MCU is very similar to low end PICs
    https://en.wikipedia.org/wiki/PIC_instruction_listings#ELAN_Microelectronics_clones_(13_bit)
    It has the ability to add packed BCD numbers, never had the need to do that... https://www.righto.com/2023/01/understanding-x86s-decimal-adjust-after.html
    Jan Cumps over 2 years ago
    Those "as cheap as possible" devices are provoking, aren't they?
    They use components that we often never heard about. Controllers and tool chains that most of us don't want to touch. Old school single side trough hole components.
    Yet they beat all other challengers.
    It's an interesting part of our economy.
    • Vote Up +5 Vote Down
    DAB over 2 years ago
    That design should keep the batteries from overheating.
