Member's Forum QUESTION OF THE MONTH: Do you use reference designs to develop your PCB designs?
  • Replies 10 replies
  • Subscribers 625 subscribers
  • Views 1623 views
  • element14members
  • question of the month
  • PCB designs
vijeth_ds
vijeth_ds over 2 years ago
e14 Question of the Month
An electronic reference design is a full circuit PCB design for a particular use or application. Some examples of reference designs are DC-DC converter, battery charger, BLDC motor control, gate driver, inverter, and many more. Many manufacturers create reference designs that employ one of their new components or category of components. The element14 Community's parent company, Avnet, Inc., has an extensive library of reference designs called the "Design Hub".  A key benefit of a reference design is that it can not only speed up the design time, but also it can includes a BOM, which saves time sourcing components.
  • acdc90
    acdc90 over 1 year ago
    I am in the service industry repairing electronics so dont have time for design work
  • VishalSoni00
    VishalSoni00 over 1 year ago in reply to Shockwave69
    nice go for easy eda as beginner
  • Shockwave69
    Shockwave69 over 1 year ago
    I am learning pcb designing
  • embeddedguy
    embeddedguy over 1 year ago
    I do not know about Reference designs that Avnet has called "Design Hub" but I use the vendors own reference design. For example if I am making something with ESP32 microcontroller, I would have a look at their specifications and reference designs provided in technical reference documents.
    Other than that it is sometimes not a good practise to follow a reference designs without knowing the details of the design itself.
  • meera_hussien
    meera_hussien over 1 year ago
    It is always the best reference to consult, especially when handling the chip for the first time. This becomes even more important when dealing with the communication aspect
  • battlecoder
    battlecoder over 1 year ago
    Absolutely! They are essential. The first thing I always do when using a new component is checking the reference design, and it always becomes the base for whatever part of the circuit is relevant to its application.
  • vmate
    vmate over 1 year ago in reply to michaelkellett
    While the reference layouts are not suitable as-is in a lot of cases, they serve as a good starting point, even if multiple components are different.
    dougw over 1 year ago
    Further to what Michael is saying, when I say reference design, I am mostly referring to schematics - although the suggested layout for power supply chips can also be useful. Both are found in datasheets.
    michaelkellett over 1 year ago
    I might well look at a reference design (if you include the manufacturers data sheet I always look) when designing with a new chip.
    The  PCB CAD data for a reference design is rarely of much use - PCB CAD data is only portable if you have the same software as was used in the reference.
    For some parts the PCB layout hints are important (although the best manufacturers put this stuff in the data sheet.)
    The BOM will often use parts that are not convenient for one reason or another.
    But even though I might not specify the parts in the reference design BOM it may still be useful in indicating the type of parts that are known to work.
    In conclusion, reference designs and design examples are an important part of the support documentation for an electronic component.
    Reference designs are always useful. The first time using a new chip I often clone at least part of the reference design.
