    • Avnet Boards Community
Member's Forum ChatGPT designs an Audio Amplifier
  • Replies 48 replies
  • Subscribers 531 subscribers
  • Views 2570 views
  • audio
  • ai
scottiebabe
scottiebabe 7 months ago
It is getting smarter every day, the schematic made me smile.
You said:
draw a schematic of circuit
ChatGPT said:
ChatGPT
Could you clarify what type of circuit you'd like? For example:
  1. Type of Circuit: Oscillator, amplifier, power supply, etc.
  2. Specific Components: Op-amp, microcontroller, 555 timer, etc.
  3. Voltage Levels: Supply voltage and expected output.
  4. Purpose: Any specific functionality you'd like to achieve.
Let me know, and I can create a schematic tailored to your needs!
You said:
audio amplifier
ChatGPT said:
ChatGPT
Here’s a simple schematic for a basic audio amplifier using a common operational amplifier like the LM386, which is popular for audio applications:
Components:
  1. IC: LM386
  2. ...
  3. Power Supply: 9V DC
Circuit Description:
  1. Input: Audio signal is fed through a coupling capacitor (C1) to remove any DC component.
  2. ...
  3. Decoupling: A capacitor (C3) filters noise in the power supply.
Would you like me to refine this or provide the actual schematic drawing?
You said:
actual drawing
ChatGPT said:
Here is the schematic diagram of the simple audio amplifier circuit using the LM386 IC. Let me know if you need any modifications or additional details!
  • rsc
    rsc 7 months ago +5
    It’d make a cool t-shirt.
    michaelkellett 7 months ago +5
    Thanks for this - I feel I have job security as long as I need it ! MK
  • scottiebabe
    scottiebabe 5 months ago +5
    ChatGPT, March 28, 2025, getting closer...
    Jan Cumps 1 month ago in reply to scottiebabe
    OK. Explain C3, ChatGPT
    michaelkellett 1 month ago in reply to scottiebabe
    Eventually the web will be so polluted by bad AI circuits that it will be impossible to find out how to use simple parts like the LM386.
    We'll have to go back to data sheets in books or sent by post to be sure we are getting good information.
    I suppose I should check, you haven't spent the last 6 months trying to get your LM386 to work, have you ?
    Relaxed
  • scottiebabe
    scottiebabe 1 month ago in reply to Jan Cumps
    I tried this,
    eventually used up free tier queries
  • scottiebabe
    scottiebabe 1 month ago in reply to michaelkellett
    after seeing the datasheet it got even more confused Slight smile
  • kmikemoo
    kmikemoo 1 month ago in reply to scottiebabe
    Wow!  It got worse.
    genebren 1 month ago in reply to scottiebabe
    ChatGPT must be sponsored by the capacitor companies, those 250 uF caps are not cheap (also probably higher than necessary).  It seems kind of wrong to isolate the input so completely from the amplifier.
  • kmikemoo
    kmikemoo 1 month ago in reply to genebren
    Joy Laughing  It's capacitive coupling.
  • beacon_dave
    beacon_dave 1 month ago in reply to genebren
    Also sponsored by the Noise Abatement Society ?
