Member's Forum QUESTION OF THE MONTH : What Soldering tool would you like next to add to your Workbench?
  • Replies 33 replies
  • Subscribers 592 subscribers
  • Views 3313 views
  • poll
  • QOM
vijeth_ds
vijeth_ds 11 months ago
e14 Question of the Month
Soldering components is a necessary skill for any prototyping maker or engineer. But the right soldering tool you need depends on what you are going to do. A standard soldering station may work for soldering through-hole components to a PCB, but soldering surface mount devices needs a different tool. What are you thinking about purchasing next?
  • kmikemoo
    kmikemoo 10 months ago in reply to shabaz +2
    shabaz I like the idea of try before you buy. I used a Project14 prize cart to pick up a desoldering gun. Unless I'm "harvesting", I default to soldering wick or the pencil/solder sucker combo tool. The…
  • anniel747
    anniel747 10 months ago in reply to Andrew J +2
    dougw 10 months ago +2
    I might like a fast heating iron/station. Mine take a while to heat up. I might use a reflow oven once in a while if I had one.
  • Mr.Hyde
    Mr.Hyde 9 months ago
    Soldering station variable heat control hot air station and built in power supply for those projects
  • COMPACT
    COMPACT 9 months ago
    A solder fountain for wave soldering and mass desoldering, a Hybrid SMD workstation (like ERSA HR 600/2 ) to be able to remove and replace BGAs and alike, and high quality SMD reflow oven.
  • COMPACT
    Have any of you seen MI:The Final Reckoning film? Have a look at Luther soldering - he is really in need of a new soldering iron tip. His couldn't be more oxidised if one tried. LOL
