Member's Forum Old CooCox Embedded Pi - What can I do with it?
  • Replies 14 replies
  • Subscribers 626 subscribers
  • Views 1484 views
muman
muman over 1 year ago
Greetings from Switzerland! A first post, to see what happens...
I recently acquired a CooCox Embedded Pi (nice STM32F103 MCU) for almost nothing.
The box has element14.com written on it, so I ended up here.
But it seems that CooCox no longer exists (I did find their old github archive, though).
Should I bin it, or is it worth playing with? (Remembering that life is short ;-)
Anyone done any nice projects with it?
Best Regards,
Matt
https://muman.ch
  • muman
    muman over 1 year ago in reply to radu7
    ... let me know how it goes...
  • muman
    But maybe kmikemoo was right, "I'm going to recommend putting your energies into newer toys."
    It's fun though!
    <i think he meant 'target practice' - ed>
  • radu7
    radu7 over 1 year ago in reply to muman
    Excellent writeup Muman!  I've dug my old embedded pi board out and will try your process to program them soon.  I have a couple of other CooCox boards as well that I'll see if I can do something with while I'm at it.
    Thanks for the inspiration!
  • cstanton
    cstanton over 1 year ago in reply to muman
    muman said:
    Is this too big for an element14 post
    Not at all.
    muman said:
    or the upcycling competition?
    I believe we don't currently have an upcycling competition active, unfortunately, but we do have a spring clean competition!
  • muman
    muman over 1 year ago in reply to kmikemoo
    OK! Here (after many adventures and rabbit holes) is my 'upcycling' exposé.
    The Embedded Pi works well with the Arduino IDE and with MS Visual Studio.
    But you do need an ST-LINK box for debugging and downloading.
    Unfortunately the post is rather big, so it's only here for now...
    https://muman.ch/muman/index.htm?muman-embedded-pi.htm
  • muman
    Hello again, Sorry for the delay. Everything works, CooCox Embedded is programmable with the Arduino IDE and with Microsoft Visual Studio. One or two "problems" though. I've added an [over-detailed] exposé of the CooCox board to my blog. No sure if I'm allowed to put links in the replies, but I'll give it a try...
    Is this too big for an element14 post or the upcycling competition? I suspect it is...
  • radu7
    I'd certainly be intersted in a post detailing the process you came up with to get board up and running using Visual Studio, etc...
  • muman
    Everything works! USB CDC too :-) The only problem is the 3V3 regulator is max. 150mA - it doesn't say that in the docs, but I have a solution.
  • kmikemoo
    kmikemoo over 1 year ago in reply to muman
    muman  Laughing So you chose the red pill.  Good on you!  It's always rewarding to breathe new life into some of the older toys. Thumbsup
    From time to time, the e14 Community will have a competition on upcycling or reusing some older equipment.  This may be your CooCox's destiny.  Just something to keep in the back of your mind as you continue to work with this board.
  • muman
    Hi kmikemoo. You are probably right! But I quite like the logic level translators on the CooCox board which allow it to work with 3.3V or 5V shields, nice for experimentation. And it has two sets of I/O pins - Arduino Standard + many of the other STM32F103 pins on parallel connectors. Other than that, the board is very similar to the STM32F103 Nucleo-64 board.
    I managed to get it working with Visual Studio + Visual Micro with full debug support and also with the Arduino IDE, via an old ST-LINK/V2 box, but I had to make an SWD adapter for it (I mislaid the ST-LINK cables in the mists of time). The STM32 Arduino libraries for the "STM32F103 Generic" device seem to work too, with some minor adjustments for the pin numbering.
    So maybe I won't bin it after all...
    If anyone is interested I could make a post with all the details.
