Member's Forum What is likely to happen, if anything, if I try and export to the grid and import from the grid simultaneously?
  • Replies 29 replies
  • Subscribers 625 subscribers
  • Views 3137 views
Andrew J
Andrew J over 1 year ago
I have this scenario:  I want to export from a house battery to the grid during the period 23:30 to 01:00 at 3.6kW (until battery is empty.)  At the same time, I have my car plugged in charging at 7kW.  Would that have the net effect of pulling 3.4kW from the grid?  Is anything likely to fail?
As a basic summary, I can charge my house battery up at 7p from 23:30 to 05:30 and discharge it to the house during the rest of the day, thus I pay only 7p for electricity used.  I don't fully discharge the battery during this period so I can sell the remaining charge back to the grid at 15p before fully charging up again ready for the day.  However, I also need to charge my car up which I also do 23:30 to 05:30 - Note because of the tariff I am on I have NO control over when the charging actually occurs so I cannot configure it to avoid the time period where the house battery is discharging.  Re-configuring the battery to not discharge when I plug the car in is a laborious process which I want to avoid.  I only actually charge the car once or twice a week.
  • Andrew J
    Andrew J over 1 year ago in reply to Dunstan456
    Dunstan456 Thanks for the suggestion David, I've had a chance to take a look.  I was expecting a Home Automation integration for some reason not a standalone app - which would have been great for my purposes!  However, I have a Siggen Energy system not a Tesla Powerwall so it won't work for me.  Looks useful though. I have my installer back tomorrow and can get him to set up the ModBus feature on the Inverter so I should be able to connect to it from HA and can then see what I can/cannot do programmatically.
  • Andrew J
    The charger connection is being rearranged next week so the battery never sees it which will help.  Do you have a link to that app; Net Zero, in any form, is a popular search at the moment,
  • Dunstan456
    Dunstan456 over 1 year ago in reply to Andrew J
    Hi Andrew, it's not physically possible to import and export simultaneously so, as you observed, the battery discharges to the car first and then the grid takes over.
    Charging the car from your battery is not the best use of the energy (average round trip efficiency for battery charge and discharge will be about 87%). It's not a big issue, but you should be able to stop this happening with a bit of automation.
    In that regard I highly recommend an app called Netzero. I use this to stop my Powerwall from charging the car when Octopus schedule a charge outside the cheap rate window.
    Best of luck
    David
  • dang74
    dang74 over 1 year ago in reply to Andrew J
    Thanks for elaborating further.  It's very interesting but something I don't have experience with.
  • Andrew J
    Andrew J over 1 year ago in reply to obones
    Unfortunately the battery price wasn't broken out in my invoice, however looking back at emails, an 8kW pack cost £2350 and 5kW £1950.  This is ex-vat and doesn't include installation or other ancillary costs; also it was the price in January!
  • obones
    obones over 1 year ago in reply to Andrew J
    Would you care sharing a (rough) estimate of what the battery cost? I already have the solar panels, micro inverters and monitoring system, but as I'm looking at quotes for a battery, I'm wondering if the given price is in the right ballpark.
  • dang74
    dang74 over 1 year ago in reply to BigG
    I see what you mean by how if everyone started doing this...demand would go up during the overnight hours which would raise the rate.  I guess the other factor preventing this is that like anything promising savings on your utility bills, it takes a number of years to break even due to the upfront cost of the equipment.
  • Andrew J
    Andrew J over 1 year ago in reply to dang74
    It's not necessary to have an EV.  This is just part of a solar system that can be used to provide power to the house, with excess being sold off to the grid.  A battery helps support that by providing power (obtained at a cheaper, off-peak rate) during the night and winter months.  A battery can also provide power in the even of grid failure if provisioned properly.  My setup consists of 16kW of battery with approx 7.5kW of solar generation.  Having an EV gives me access to a tariff offering electricity at £0.07 otherwise I'd have to find an alternate that suited having this system plus an ASHP.   That gives me the ability to have all my electricity at £0.07 and sell excess back at £0.15.  In theory then my utility bill should drop to under 25% of what it would be without it.
    For an example of a house battery, check out the Tesla Powerwall.
  • BigG
    BigG over 1 year ago in reply to dang74
    Technically, yes, but inefficiencies nab you. I suspect that if it were a good deal more and more would do it, thereby balancing everything out and then it becomes more and more uneconomical, especially if buying a new battery just to do this.
    I've heard of a few using old EV batteries for this sort of thing; especially EV owners. That is, when the EV needs battery replacement to improve performance & efficiency they take the old battery and place in the home etc. Then it's a no-brainer as you've already paid for the battery.
  • Andrew J
    Andrew J over 1 year ago in reply to bradfordmiller
    It's guaranteed for 15 years to be 80% usable.  And I'm not sure what you mean by "that type of activity" - it's a battery that is meant to be charged up and then discharged over time.  None of this is particularly stressful or beyond what it has been designed for.  The whole system is expected to have a payback period of 7 - 8 years, although obviously that is predicated on electricity prices staying the same or going up.  There's a reasonable probability they will come down over that sort of time period.
