Member's Forum Does AI plagiarize and take credit for work of others ?
  • Replies 18 replies
  • Subscribers 625 subscribers
  • Views 1784 views
robogary
robogary over 1 year ago
I was surfing the web for advice on remedies for python error "module missing" and then for example code to compare to.
Later I did the same google on my cell phone, which AI wants first shot to answer. It told me " here is code from AI" , which looks exactly like example code from an older webpage.
I was thinking , Mr AI if you found this code in cyberspace, why didn't you give the originator get credit ? It's not like they asked you for money.
I wonder if AI does the same for recipes. ......
    shabaz over 1 year ago in reply to BigG
    I'm using JetBrains IDEs, and just noticed they have a Gemini plug-in, I'll have to give it a try too.
    Occasionally AI has been quite helpful with arrays such as the ones you show; I tend to 'force' my desired encoding for the first few values, and then it figures out the pattern from there, and continues it (not always successfully, but enough to help save time overall).
    I'm also finding I'm commenting my code a lot better than pre-AI, since that acts as a guide too.
  • BigG
    BigG over 1 year ago in reply to shabaz
    This mostly happens when using Gemini Code Assist in VS Code. It highlights potential issues re licensing.
    In my opinion, the best way around some of this minefield, is to place an acknowledgement in the header stating that the code was AI generated etc.
    DAB over 1 year ago
    With the internet, the issues of plagiarism are becoming impossible to discover and prove.
    With the way AI is trained using the internet as sources of information, unless the AI programmers include having reference information as a priority, there is no way to include such information in any AI response.
    This is one of the many reasons that I do not trust any AI response.
    Perhaps when they include an option where I can ask Why the AI came up with its response, so that I can double check the information and its sources, then I might use it.
    Here's a function, done with an AI that revealed zero sources throughout.
    I used AI to help me write this function last night. And, obviously, I guided it throughout the process to ensure I wasn't copying anyone else, so as not to violate other people's licenses.
    It's my work. With the benefits of AI. I'd be very curious if any human being can conclude it is not original work, provided they can give at least some evidence that it may have been copied from other people's work (I'll settle for just fair plausibility, I'm not looking for extreme "beyond reasonable doubt" level of evidence). It shouldn't be too hard, there are several MAX7219 libraries on GitHub that AI might have copied from (or that humans could have directly copied from pre-AI).
    void Max7219::setRamPixel(uint16_t x, uint16_t y, uint8_t pixelvalue) {
        uint16_t idx;
        uint8_t bitIdx;
        uint16_t linx, liny;
        // x position is 0..(8*mHorizQty - 1), y position is 0..(8*mVertQty - 1)
        if (mDisplayData == nullptr) return; // Ensure display data is initialized
        if (x >= 8 * mHorizQty || y >= 8 * mVertQty) return; // Validate x and y positions
        // each byte in mDisplayData represents a row of 8 pixels
        // transformation:
        // linx and liny represent the positions if the modules were all in a sigle line
        linx = (((mVertQty-1)-(y/8))*mHorizQty*8) + x;
        liny = (y % 8);
        // now do the calculations using the transformed linx and liny, i.e.
        // as if all modules were on a single 8x8 line
        idx = (linx/8) + (liny * mQty); // Calculate RAM byte index in the display data
        bitIdx = (uint8_t)(7 - (linx % 8)); //Calculate bit index within the byte, where most significant bit is at position 0
        if (pixelvalue) {
            mDisplayData[idx] |= (1 << bitIdx); // Set the pixel
        } else {
            mDisplayData[idx] &= ~(1 << bitIdx); // Clear the pixel
    And, incidentally, I can give fair evidence that it is my work (just so that the challenge is balanced, I'm not asking for anything unreasonable!).
    shabaz over 1 year ago in reply to dang74
    In your example, the student chose not to copy the name.
    What if AI had printed all names/sources alongside the generated content? A user could still decide to ignore the license terms at those sources. In other words, those who want to plagiarize will do it anyway.
    There really is no difference. Those same people would have done it pre-AI and post-AI, so why the hang-up that a user needs to make some effort to locate the sources if he/she makes the decision to use content?
    The decision and repercussions (and clearly liability!) always rests with them and the firms that accepted the content into their codebase, no-one is suggesting anyone can be excused for getting it wrong, just because AI might have not provided sources (or might have provided incorrect sources).
  • dang74
    dang74 over 1 year ago in reply to shabaz
    I won't be able to persuade you further... but I leave you with this... "It's unfair to say the student cheated on the entire exam.  After all he didn't need to peer over anyone's shoulder when he was writing his name."
    Some of the arguments that suggest IP violation are unreasonable, because some of the AIs do not regurgitate verbatim; they instead try to generate output that suits your own coding style and function prototypes. I think it's fair game to learn from publicly available content if it's retold in different words/syntax. Humans do that each time they read a copyrighted article in a newspaper and then tell their friends about what's going on. No-one suggests they are violating IP.
    It may well turn out that some AI's will never be able to cite all sources for their generative output. Maybe we need to change our perspective on things, because it's pragmatic that some of that responsibility will still be in the user's hands for now, not AI.
  • dang74
    Although I began my last response asking that we set aside the responsibilities of the individual user aside for a moment, I do agree with you that the user does have a responsibility for due diligence... and yes, I think for the most part big tech shouldn't be liable for any negative outcomes from search results or AI generated code.... but I still don't think they should be let off the hook for violating intellectual property.
    I agree it's not ideal, I just don't think it's as big an issue as some people think, because engineers still need to consider their sources, and they needed to do that pre-AI too. If it was such a big issue, people wouldn't be using it.
    I acknowledge the limitations, but equally I believe people should and do work around it in a moral way, same as engineers did pre-AI (well, at least the normal engineers; there are the immoral ones like those responsible for emissions scandal, dodgy firms that won't care about laws regardless, and so on).
    Has life become harder for an engineer to discover the sources? Maybe, but that's a decision the engineer has completely under their own control, because they are not obligated to use AI output, or they could choose to restrict their AI usage to (say) tasks that are not going to form part of their product, and their are plenty of those sorts of tasks to benefit from using AI as well.
    Today the responsibility (and liability) lies with the engineer and the firm that accepted the code to a large extent. Would that responsibility change even if AI provided a thorough list of sources? Probably not, for two reasons:
    Firstly, because AI is not 100% accurate, the engineer would be expected to check regardless.
    Secondly, practically speaking, I cannot imagine governments allowing individuals and firms to sue AI companies for unbounded amounts of mistakes, because AI companies cannot be expected to anticipate all repercussions. An analogy is one's mobile phone data connection going offline. If that occurs when someone wanted to make a stock transaction and they lose millions, they could try taking the phone company to court, and the case would get thrown out, because it's completely impractical for commerce if the phone company could be liable for this. Today it's much easier for the user to "do something" to reduce risk, than it is for the AI firm or phone company respectively.
  • dang74
    If we set the responsibilities of individual users aside for a moment it does seem from examples provided by obones that the AI algorithms are playing fast and loose with intellectual property and stripping out the credits or conditions for using a specific code snippet... and that doesn't quite sit right in my opinion.
