Member's Forum Does AI plagiarize and take credit for work of others ?
  • Replies 18 replies
  • Subscribers 592 subscribers
  • Views 1260 views
robogary
robogary 10 months ago
I was surfing the web for advice on remedies for python error "module missing" and then for example code to compare to.
Later I did the same google on my cell phone, which AI wants first shot to answer. It told me " here is code from AI" , which looks exactly like example code from an older webpage.
I was thinking , Mr AI if you found this code in cyberspace, why didn't you give the originator get credit ? It's not like they asked you for money.
I wonder if AI does the same for recipes. ......
  • dang74
    dang74 9 months ago in reply to shabaz +2
    I won't be able to persuade you further... but I leave you with this... "It's unfair to say the student cheated on the entire exam. After all he didn't need to peer over anyone's shoulder when he was writing…
  • BigG
    BigG 10 months ago +1
    I rather like Gemini, and to date have not noticed this sort of thing. But just to be sure, I asked... Not bad for an AI response. https://g.co/gemini/share/6dc95911917d
  • BigG
    BigG 10 months ago in reply to robogary +1
    Ha, I think it's simply learnt how to bluff, by ensuring that it is 100% confident in all the answers given.
  • dang74
    dang74 10 months ago in reply to shabaz
    Although I began my last response asking that we set aside the responsibilities of the individual user aside for a moment, I do agree with you that the user does have a responsibility for due diligence... and yes, I think for the most part big tech shouldn't be liable for any negative outcomes from search results or AI generated code.... but I still don't think they should be let off the hook for violating intellectual property.
    shabaz 10 months ago in reply to dang74
    Some of the arguments that suggest IP violation are unreasonable, because some of the AIs do not regurgitate verbatim; they instead try to generate output that suits your own coding style and function prototypes. I think it's fair game to learn from publicly available content if it's retold in different words/syntax. Humans do that each time they read a copyrighted article in a newspaper and then tell their friends about what's going on. No-one suggests they are violating IP.
    It may well turn out that some AI's will never be able to cite all sources for their generative output. Maybe we need to change our perspective on things, because it's pragmatic that some of that responsibility will still be in the user's hands for now, not AI.
  • dang74
    I won't be able to persuade you further... but I leave you with this... "It's unfair to say the student cheated on the entire exam.  After all he didn't need to peer over anyone's shoulder when he was writing his name."
    shabaz 9 months ago in reply to dang74
    In your example, the student chose not to copy the name.
    What if AI had printed all names/sources alongside the generated content? A user could still decide to ignore the license terms at those sources. In other words, those who want to plagiarize will do it anyway.
    There really is no difference. Those same people would have done it pre-AI and post-AI, so why the hang-up that a user needs to make some effort to locate the sources if he/she makes the decision to use content?
    The decision and repercussions (and clearly liability!) always rests with them and the firms that accepted the content into their codebase, no-one is suggesting anyone can be excused for getting it wrong, just because AI might have not provided sources (or might have provided incorrect sources).
    shabaz 9 months ago
    Here's a function, done with an AI that revealed zero sources throughout.
    I used AI to help me write this function last night. And, obviously, I guided it throughout the process to ensure I wasn't copying anyone else, so as not to violate other people's licenses.
    It's my work. With the benefits of AI. I'd be very curious if any human being can conclude it is not original work, provided they can give at least some evidence that it may have been copied from other people's work (I'll settle for just fair plausibility, I'm not looking for extreme "beyond reasonable doubt" level of evidence). It shouldn't be too hard, there are several MAX7219 libraries on GitHub that AI might have copied from (or that humans could have directly copied from pre-AI).
    void Max7219::setRamPixel(uint16_t x, uint16_t y, uint8_t pixelvalue) {
        uint16_t idx;
        uint8_t bitIdx;
        uint16_t linx, liny;
        // x position is 0..(8*mHorizQty - 1), y position is 0..(8*mVertQty - 1)
        if (mDisplayData == nullptr) return; // Ensure display data is initialized
        if (x >= 8 * mHorizQty || y >= 8 * mVertQty) return; // Validate x and y positions
        // each byte in mDisplayData represents a row of 8 pixels
        // transformation:
        // linx and liny represent the positions if the modules were all in a sigle line
        linx = (((mVertQty-1)-(y/8))*mHorizQty*8) + x;
        liny = (y % 8);
        // now do the calculations using the transformed linx and liny, i.e.
        // as if all modules were on a single 8x8 line
        idx = (linx/8) + (liny * mQty); // Calculate RAM byte index in the display data
        bitIdx = (uint8_t)(7 - (linx % 8)); //Calculate bit index within the byte, where most significant bit is at position 0
        if (pixelvalue) {
            mDisplayData[idx] |= (1 << bitIdx); // Set the pixel
        } else {
            mDisplayData[idx] &= ~(1 << bitIdx); // Clear the pixel
    And, incidentally, I can give fair evidence that it is my work (just so that the challenge is balanced, I'm not asking for anything unreasonable!).
    DAB 9 months ago
    With the internet, the issues of plagiarism are becoming impossible to discover and prove.
    With the way AI is trained using the internet as sources of information, unless the AI programmers include having reference information as a priority, there is no way to include such information in any AI response.
    This is one of the many reasons that I do not trust any AI response.
    Perhaps when they include an option where I can ask Why the AI came up with its response, so that I can double check the information and its sources, then I might use it.
  • BigG
    BigG 9 months ago in reply to shabaz
    This mostly happens when using Gemini Code Assist in VS Code. It highlights potential issues re licensing.
    In my opinion, the best way around some of this minefield, is to place an acknowledgement in the header stating that the code was AI generated etc.
    shabaz 9 months ago in reply to BigG
    I'm using JetBrains IDEs, and just noticed they have a Gemini plug-in, I'll have to give it a try too.
    Occasionally AI has been quite helpful with arrays such as the ones you show; I tend to 'force' my desired encoding for the first few values, and then it figures out the pattern from there, and continues it (not always successfully, but enough to help save time overall).
    I'm also finding I'm commenting my code a lot better than pre-AI, since that acts as a guide too.
