Member's Forum Question of the Month: What’s the most frustrating part of working with modern micro-controllers?
  • Replies 31 replies
  • Subscribers 547 subscribers
  • Views 2169 views
  • poll
  • QOM
  • question of the month
cstanton
cstanton 4 months ago
Micro-controllers are at the core of most embedded systems, but working with them isn’t always smooth. From confusing datasheets to fragmented tool-chains, even experienced engineers can hit roadblocks. This month, we want to know:
Bonus question:
What micro-controllers are you currently using? (and why that one?)
  • beacon_dave
    beacon_dave 4 months ago +7
    I'm probably just getting old, but like with a lot of modern technology, the built-in obsolescence factor. You spend a considerable amount of time digesting huge data sheets and getting comfortable with…
  • balajivan1995
    balajivan1995 4 months ago +3
    Using VS code with Arduino extension has ruined the idea of using IDE to build applications. I hate installing a new IDE which is just another port of eclipse IDE and comes bloated with BSP of some MCU…
  • robogary
    robogary 4 months ago in reply to beacon_dave +3
    Hear Ye Hear Ye Ole IDE. Next year is the major anniversary of my 1st and only official software programming class.........in Fortran 4 - WatFor. I must be getting old too :-)
  • ntewinkel
    ntewinkel 4 months ago in reply to robogary
    robogary said:
    I bought dozens of clones years ago
    I did a similar thing with Wemos D1 mini esp8266. Not quite the deal you got, but most of my projects are wifi IoT, and those boards were still under $3 each iirc .
    And as others have said, the continual learning curves are generally just not worth it for the hobby projects I do. I did also buy a few esp32 boards, but haven’t done anything with them yet. But at least the IDE and general usage remains the same.
    But then once in a while something new and cool comes along and i can’t help but jump in - Raspberry Pi and Pi Pico for example. And that AI chip for the Save the Bees contest is amazing (but not quite at the same price point Laughing )
  • Instructorman
    Instructorman 4 months ago
    STM32F732.  Wanted to learn more about ARM processors.
  • mhenman
    mhenman 4 months ago
    I still use a lot of PIC16f series MCUs, mostly because I bought a ton of them years ago and have been slowly dwindling my stock.  My new goto MCU when I need more power is definitely the ESP32S3.  Amazing bang for the buck.
  • Chip
    Chip 4 months ago
    Dyslexic .  I got a copy and paste everything to enough app get read to me . Someone type the question why not just put the voice over the top as well
  • Robert Peter Oakes
    Robert Peter Oakes 4 months ago
    Reading all of this makes me think of a few things
    I've been programming and coding since 1976, starting with PDP8 and 11, 8080 in the form of an S100 bus system configured for industrial control and even a little cobol on the company mainframe. since then probably coded in dozens of languages over the years, mainly changing because the new job had X as the standard, I think if you know how to design a good program it becomes easier to code it for a specific MCU/CPU
    Even after over 50 years I still drop to C++ as my goto with C# when targeting MS platforms.
    I like the abstraction from hardware to user code of things like the arduino IDE, its hard to say the board is an arduino anymore but I really like the code abstraction, 99% or more of applications dont need the speed of assembly or other direct platform written code and were you need a bit more power you can switch out the hardware with little change to you actual code, were you do then drop to C++ or something.
    on the STM development environment I love the configurator/mapper that allows internal function blocks to be configured and or mapped to external pins in some cases almost any pin, that's awesome and can aid in pcb layout tremendously i think.
    Distributed computing / environment is the way to go for all but the simpler systems, even now with 3D printing or other CNC/motion control type solutions there are apps like Klipper that abstract the G Code interpretation and hans of just motion control to one or more MCU's for the various parts of in my canse the 3D printer.
    I am building 2 right now, a Voron Trident and a Voron V2 R2.4, both have a PI or equivalent for the master controller and then in my case a RPI2040 based head controller for hotend temp, filament flow, cooling fans and the like, then another RPI2040 running the A/B motors for the core XY motion platform, then an ST32xxx based board running the heated bed, 3 or 4 Z motors , system cooling and various other things. The PI is also providing web interface and local display / controls.
    That's all for just a 3D printer but it keeps everything simple, the environment is abstracted but highly optimized for near real time control of those motors (Gotta make sure those circles are actually round :) ) and it supports loads of different MCU's and hardware interfaces.
    I could go on but I digress, I will be creating posts for the 3D printer builds in detail soon but thats were im at for now with coding and building.
    Oh... yes im old too Slight smile
    DAB 4 months ago in reply to Robert Peter Oakes
    No Peter, you are still a youngster.
    I am old, I started with vacuum tubes.
  • rsc
    rsc 4 months ago in reply to DAB
    I still have a few 572B's and 811A's in the basement.......
  • rsc
    rsc 4 months ago
    My SOP is to have at least one of everything..... just in case......I think the RPis are self-replicating in the cabinet....
  • ralphjy
    ralphjy 4 months ago in reply to rsc
    I have the same MO.  It got particularly bad when there were part shortages.  I bought a lot of stuff whenever it became available even when I didn't need it.
    That's one reason that I like the Seeed Xiao.  I have 9 different MCU types in the same footprint so that it is easier to try different MCUs for the same project.
    I also have all the RPi and Pico variants.
  • FreeBird
    FreeBird 3 months ago in reply to robogary
    I think when I took that class it was Threetran :)
