Member's Forum As a designer, how do you make choices?
  • Replies 23 replies
  • Subscribers 547 subscribers
  • Views 2027 views
  • LED driver
  • designer choices
dougw
dougw 3 months ago
A very common practice when designing with MCUs is to dedicate at least one MCU pin to drive a diagnostic or indicator LED.
There are several simple circuits that can accomplish this function. I am curious to know if  most designers use the same circuit, and if not, why not?
Edit by cstanton : I liked this post so much I decided to elevate it to Question of the Month for August (Close enough for UK time zone anyway!)
Leave a comment that explains how it came about that you use a particular circuit.
  • rsc
    rsc 3 months ago +4
    I usually have a 2-pin header(s) somewhere for power supply(s) voltage(s) that I can put a LED jumper with a resistor on it. That way I don't have to have a LED on all the time, just for diagnostics.
  • scottiebabe
    scottiebabe 3 months ago +2
    modern leds are blindingly bright with just a few mA.
    genebren 3 months ago +1
    I have been using NeoPixel Mini 3535 RGB LEDs as my go to indicator on my boards. At < $0.20 in quantity of 100, it is cheap enough, and the RGB capability gives me a bit more flexibility.
  • dang74
    dang74 3 months ago
    I use an NPN BJT... Resistors on the base and collector.... the emitter connected to GND.
  • obones
    obones 3 months ago in reply to dang74
    I replied "direct from the MCU pin" but that's because I use MCUs that are capable of outputing 20mA on a single pin. Else, I'd do the same as you, a good old 2N3904 and voila.
  • rsc
    rsc 3 months ago
  • scottiebabe
  • dang74
    dang74 3 months ago in reply to obones
    Thanks... I was feeling all alone for a while there.
    dougw 2 months ago in reply to bradfordmiller
    It wasn't worded very well... I was trying to get explanations of how designers elect to resolve design choices, but it is such a vague question, I needed a specific example to make it possible to provide an answer without writing a book.
    dougw 2 months ago in reply to dang74
    You are doing better than me - my normal method is sitting at 2%...Relaxed
    The transistor method has the additional advantage that it can run LEDs from unregulated DC which reduces the stress on the regulators.
    dougw 2 months ago in reply to rsc
    Good point. I only populate diagnostic LEDs on prototypes, unless it is part of some periodic self-diagnostic.
  • dang74
    dang74 2 months ago in reply to dougw
    I guess using a FET as opposed to a BJT imposes even less current on the MCU.
  • obones
    obones 2 months ago in reply to dang74
    You are right, but old habits die hard
