Member's Forum As a designer, how do you make choices?
  • Replies 23 replies
  • Subscribers 626 subscribers
  • Views 3058 views
  • LED driver
  • designer choices
dougw
dougw over 1 year ago
A very common practice when designing with MCUs is to dedicate at least one MCU pin to drive a diagnostic or indicator LED.
There are several simple circuits that can accomplish this function. I am curious to know if  most designers use the same circuit, and if not, why not?
Edit by cstanton : I liked this post so much I decided to elevate it to Question of the Month for August (Close enough for UK time zone anyway!)
Leave a comment that explains how it came about that you use a particular circuit.
    michaelkellett over 1 year ago in reply to dougw
    We forgive you !
    I totally screwed this up - I clicked on "New" but it simply replaced my last question...
    You may need to adjust your vote.
    The new question is here:
    (+) Is the "imminent" availability of sodium ion batteries affecting your decision of when to switch to an EV or solar house? - element14 Community
    I'm not sure why it over wrote the question above about LED drive circuits.
  • Celin
    Celin over 1 year ago
    Bjt with LED allows to drive also optocoupler (ie optotriac) for output signal and to supply then with different sources.
  • obones
    obones over 1 year ago in reply to dang74
    You are right, but old habits die hard
  • dang74
    dang74 over 1 year ago in reply to dougw
    I guess using a FET as opposed to a BJT imposes even less current on the MCU.
    dougw over 1 year ago in reply to rsc
    Good point. I only populate diagnostic LEDs on prototypes, unless it is part of some periodic self-diagnostic.
    dougw over 1 year ago in reply to dang74
    You are doing better than me - my normal method is sitting at 2%...Relaxed
    The transistor method has the additional advantage that it can run LEDs from unregulated DC which reduces the stress on the regulators.
    dougw over 1 year ago in reply to bradfordmiller
    It wasn't worded very well... I was trying to get explanations of how designers elect to resolve design choices, but it is such a vague question, I needed a specific example to make it possible to provide an answer without writing a book.
  • dang74
    dang74 over 1 year ago in reply to obones
    Thanks... I was feeling all alone for a while there.
  • scottiebabe
    scottiebabe over 1 year ago
    modern leds are blindingly bright with just a few mA.
