Member's Forum As a designer, how do you make choices?
  • Replies 23 replies
  • Subscribers 547 subscribers
  • Views 2042 views
  • LED driver
  • designer choices
dougw
dougw 3 months ago
A very common practice when designing with MCUs is to dedicate at least one MCU pin to drive a diagnostic or indicator LED.
There are several simple circuits that can accomplish this function. I am curious to know if  most designers use the same circuit, and if not, why not?
Edit by cstanton : I liked this post so much I decided to elevate it to Question of the Month for August (Close enough for UK time zone anyway!)
Leave a comment that explains how it came about that you use a particular circuit.
  • rsc
    rsc 3 months ago +4
    I usually have a 2-pin header(s) somewhere for power supply(s) voltage(s) that I can put a LED jumper with a resistor on it. That way I don't have to have a LED on all the time, just for diagnostics.
  • scottiebabe
    scottiebabe 3 months ago +2
    modern leds are blindingly bright with just a few mA.
    genebren 3 months ago +1
    I have been using NeoPixel Mini 3535 RGB LEDs as my go to indicator on my boards. At < $0.20 in quantity of 100, it is cheap enough, and the RGB capability gives me a bit more flexibility.
  • Celin
    Celin 2 months ago
    Bjt with LED allows to drive also optocoupler (ie optotriac) for output signal and to supply then with different sources.
    dougw 1 month ago
    I totally screwed this up - I clicked on "New" but it simply replaced my last question...
    You may need to adjust your vote.
    The new question is here:
    (+) Is the "imminent" availability of sodium ion batteries affecting your decision of when to switch to an EV or solar house? - element14 Community
    I'm not sure why it over wrote the question above about LED drive circuits.
    michaelkellett 1 month ago in reply to dougw
    We forgive you !
