Member's Forum question on standard resistor values
  • Subscribers 626 subscribers
  • Views 736 views
  • learning
  • electronics
jamesw2965
jamesw2965 over 1 year ago
Hey all,
I'm getting back into my electronics and I'm wondering if anyone knows where i can find a chart with standard resistor values. Also does anyone know where I can get a resistor Value chart. I know you can get all this online, but I'm looking for a chart i can take with me encase i'm offline and don't have the ability to be online.
  • beacon_dave
    beacon_dave over 1 year ago in reply to dougw
    dougw said:
    Music uses a similar relationship
    Twelve-tone equal temperament does... Notes
    other temperaments are available though Scream
    dougw over 1 year ago
    I think the E series indicates how many values are between each order of magnitude and the relationship between each is an exponential progression.
    For example E12 has 12 values between 1 and 10 or between 10 and 100 etc. whare the next value is equal to the previous value multiplied by 10^(1/12) (and rounded to the nearest tolerance value) For E24 the next value = previous value x 10^(1/24).
    Music uses a similar relationship where each octave has 12 notes but octaves only double in frequency so each note  equals the previous frequency multiplied by 2^(1/12)
    If you remember the equation, you don't need a chart, but you may need a calculator...Relaxed
    If you just remember the values for one order of magnitude, they simply get multiplied by 10 in the next decade. If you stick to E12, you only need to remember 11 numbers.
  • Robert Peter Oakes
    Robert Peter Oakes over 1 year ago
    Here is a nice write up that explains a lot of the background etc and many other E series concepts.
    https://en.wikipedia.org/wiki/E_series_of_preferred_numbers
    shabaz over 1 year ago
    It's just called a E-series, it's not really a chart, it's just a list of numbers. From Wikipedia, it is (for E24, which are the most popular generally):
    E24 values
    (5% tolerance)
    1.0, 1.1, 1.2, 1.3, 1.5, 1.6, 1.8, 2.0, 2.2, 2.4, 2.7,
    3.0, 3.3, 3.6, 3.9, 4.3, 4.7, 5.1, 5.6, 6.2, 6.8, 7.5, 8.2, 9.1
    From that short list, you have all the detail required; for instance, since (say) the value 3.3 is there, then that means that standard resistor values will include 3.3 ohm, 33 ohm, 330 ohm, 3.3 kohm, 33 kohm, 330 kohm, and so on.
    All you need to do is save that list on you phone, or print it out or write it in a notebook.
    There are other E series, but E24 resistor values are low-cost and easy to find.
