Member's Forum Using an LED as Light Detector
  • Replies 10 replies
  • Subscribers 626 subscribers
  • Views 1000 views
FreeBird
FreeBird over 1 year ago
An article I read in Popular Electronics magazine from the 1980's inspired this experiment.  The article was authored by Forrest Mims, renowned citizen scientist.  In it he mentioned that he had discovered during the 1970's that LED's not only emitted light, but could detect light. This got my curious mind wondering if I could use the LED's I had aquired through Amazon from some far off foreign manufacturer extremely cheap.  Like less than $5.00 for 100 each of 5 different colors could be used to detect light.  It would appear they can.
Procedure: My lab (office) is on the second story of my home in S.W. Missouri, it has only one window facing due East.I waited until mid afternoon when the sun was in the western sky. Turned off the one artificial light in the room. Using the small bread board (about 2" square) that came with my Arduino Kit years ago, I inserted an LED and a couple of short pieces of wire to connect my DMM test leads too.  I then instructed the DMM to collect 500 sample voltage readings and export the collected data to .csv files. I then suspended a small LED flashlight about an inch from the LED and ran another 500 samples.  I repeated this process for all 5 colors of LED's, white, red, yellow, green and blue that came with this kit. The attached PDF files is a report of the raw findings.
Hope you enjoyed this, feel free to ask questions in the comments.  I look forward to hopefully starting a discussion around this, maybe talk about how we can use this to discover life in far off galaxies (probably not), but maybe use it to have fun with our hobby is a more attainable goal.
Charlie (Freebird)
  • FreeBird
    FreeBird over 1 year ago in reply to michaelkellett
    Per your suggestion, I created a transimpedance amplifier, using a 741 op amp.  This morning I am (well was, until a need for more coffee struck) experimenting with that circuit and trying to understand it better prior to re-running my experiment with all 5 LED's. I also intend to add a photo diode into the mix and see how that compares.  By the way, thank you for your input.
    dougw over 1 year ago in reply to jc2048
    Plastic fibre communications can work up to 100 m, although as you point out, Toslink systems aren't generally designed to go that far.
  • jc2048
    jc2048 over 1 year ago in reply to dougw
    Might be wrong, but don't the audio TOSlink ones usually have drivers integrated, to make them easy to interface to logic. Certainly, the Cliff Electronics ones that I've recently bought to use with an FPGA do.
    Something like this one is just a LED (you need to look carefully at the datasheets to make sure, because many in this range of parts also have drivers):
    https://uk.farnell.com/broadcom-limited/hfbr-1521z/fiber-optic-transmitter-5mbd/dp/1173128
    That's designed to work with 1mm plastic fibre (there's a separate plastic item that clamps around the fibre end to guide it into the tx/rx part). The range is fairly limited (10 to 20 metres, or so, depending on how hard you drive the LED, the bandwidth you're trying for, and what you've got at the receiving end) - that's ulitmately down to the lossiness of the plastic fibre, not inherent to these particular parts.
  • FreeBird
    FreeBird over 1 year ago in reply to dougw
    Had to go look up what SPDIF/Toslink is, but that is interesting. According to what I read by using a fiber optic connection to transmit sound it eliminates Electro Magnetic interference. Now I need to get some fiber optic cable, that sounds like fun to tinker with.
    dougw over 1 year ago in reply to michaelkellett
    SPDIF / Toslink audio uses red LEDs over plastic fiber
    michaelkellett over 1 year ago in reply to FreeBird
    I got to thinking about this and looking for articles on LEDs optimised for photo detection, so you might make a low cost plastic fibre bi-drectional.
    Then I found this:
    https://physicsopenlab.org/2020/02/27/using-led-as-a-single-photon-detector/
    Which might suggest a way of doing it - SPADing with a cheap LED might be quite fun - I'll just need to get hold of a single photon pulser !
    There are plastic fibres that work with red LEDs.
  • FreeBird
    FreeBird over 1 year ago in reply to FreeBird
    Also, I forgot to mention this in my initial response, but one of the uses Mr. Mimms found for this was he was able to use a fiber optic fiber to transmit the light emited by the led then place an led as an receiver on the other end.  ie: by then modulating the light signal a message could be sent, then turn off the sending led and the receiver can send an response signal back in the same manner.
  • FreeBird
    By the way I also have some photo diodes and now I believe my next step in tinkering with this may be to compare test and compare light detection results of cheap  LED's to cheap photo diodes.  Thanks for the suggestion.
  • FreeBird
    So what's gained by using an LED as a bad photo detector ?
    Well I have already gained something far more valuable then being able to detect light, thanks to your response, I have learned that my method of testing this is questionable,
    there is something called a transimpedance amplifier, I will following your link and looking that up in the near future (first the honey do list).
    This isn't the best way to use an LED as a detector (or a photo diode).
    You would do much better to measure the photo current using a transimpedance amplifier.
    https://ultimateelectronicsbook.com/op-amp-transimpedance-amplifier/
    This will be much less affected by external noise and independent of the input impedance of the meter.
    But the real question is - why bother - photo diodes are quite cheap.
    (You could buy 700 for £8.61 from Aliexpress = £0.0123 each
    https://www.aliexpress.com/item/1005006783218523.html
