Member's Forum Introduction and MP730027
  • Replies 7 replies
  • Subscribers 624 subscribers
  • Views 487 views
microknight
microknight over 1 year ago
It's been a while since I last logged in and not even sure if I've ever posted on here before.
So hi, my name is Graeme and I'm an engineer (fast approaching retirement age) residing on the south coast of the UK.
I've been using the above since the beginning of 2023 without any issues. But on Friday I noticed that the DCI function (60mA range) "appeared" to lock up after a 2 or 3 minutes whilst doing a trend graph. I tried a few obvious front panel buttons, but it appeared to have locked up completely and only a power cycle would recover it. Then it would functioned for an hour with no problem. This morning it did it again whilst just on the DCI display and again, after a power cycle it's been OK for nearly an hour now.
Correction: as I was constructing this post it's done it again after c1hr.
Just wondering if anyone else has seen anything like this. I certainly never have since I've had it. It's just being used as a stand alone instrument with no other connections other than power and the measurement connections.
Regards
Graeme
    genebren over 1 year ago
    I have searched for any firmware updates for the MP730027 and so far, I have not found any.  My instrument has V2.10.0.
  • microknight
    microknight over 1 year ago in reply to kmikemoo
    Thanks. I did say retirement age, that was quite deliberate LOL. I for one have no intention of actually retiring :-)
    G
  • microknight
    Thanks for the replies ALL.
    Not really used to this forum UI so replying to my OP rather than individually. I knew that it was just a rebrand, but not what of, so thanks for the pointer to the Owon instrument.
    Ye, I thought the same about the trending function, but as I said. It then happened whilst just in bog standard measurement mode.
    I tried to find a firmware update, but couldn't find anything yesterday searching for the MP number. Maybe I'll have more luck with the Owon site. I was a bit busy and needed to crack on. So I just had to power cycle it when it locked up :-(
    Thanks again
    G
    dougw over 1 year ago
    If you want more info on this product it may be worth checking out Owon XDM30515, since this is likely a rebranded Owon product.
  • kmikemoo
    kmikemoo over 1 year ago
    Welcome, microknight .  Good luck on your upcoming retirement.  I also don't own that bench meter.  It does look like you can download the software from Farnell so maybe there is a newer edition than the one you are running.  Just a thought.
  • dang74
    dang74 over 1 year ago
    Welcome Graeme.  I don't have this instrument.  Howwver, since you are using a data logging function it makes me wonder if this is the result of memory filling up.  Of course the product should handle things more smoothly than locking up.
    Welcome to the element14 community.  I have the same instrument, but I have not seen this problem.  I have not used the storage/graphing function much, so I may not have stumbled onto this particular issue.
