Member's Forum What’s the most time-saving habit you’ve picked up? We are asking e14 in our Join, Share & Win Competition
  • Locked Locked
  • Replies 71 replies
  • Subscribers 626 subscribers
  • Views 13418 views
  • element14 community
  • win
  • element14 members
  • aske14
E14Alice
E14Alice 9 months ago
A new month means a new AskE14!
Engineers, makers, and problem‑solvers are always finding smarter ways to work. From optimising workflows to automating repetitive tasks, small habits can add up to serious time savings.
This month, AskE14 is all about sharing the habits that help you work more efficiently, whether you’re designing, prototyping, debugging, documenting, or managing projects.
Time for the question:
Time is a valuable resource in engineering. A simple habit — like better version control, smarter test setups, or clearer documentation. This can save hours down the line.
Competition Details
You'll have to be a member of the element14 Community to join in and take part in this “Join, Share & Win” challenge. It's simple, all you have to do is:
1. You need to make sure you are  Register  or Login
2. Then answer the following question by adding a reply or commenting!
This month, we are giving away:
The Community team will then select the best 3 answers to win the UNO R4 Minima!
Closing date: 1st March
Winners announced: 10th March
UNO R4 Minima
Terms and Conditions
imagePDF
The winners!
dang74
wolfgangfriedrich
skruglewicz
E14Alice will be reaching out to you soon to confirm contact details
  • Arnovsharma
    Arnovsharma 9 months ago in reply to Aniket_kumar_raj
    I'm also Ai Wink
  • battlecoder
    battlecoder 9 months ago in reply to rsc
    If its not the connector shell it's the heatshrink, isn't i? At this point I should put that on a sticker and place it right in front of me on my bench.
  • battlecoder
    My biggest time-saving habit is organizing projects better; breaking them into smaller steps on a board; separated by "pending", "in progress" and "completed".
    Now, maybe this is different for other people, but this saves me a lot of time because normally trying to "reconnect" and resume a project is a very slow process for me (reviewing where I was with the schematic, or the code, or the prototyping, etc). This is specially true when I'm working on more than one project at a time (which is sometimes unavoidable) or when I can't work on a project for an entire week. Having a quick, immediate way of knowing where I was and what comes next helps me resume my work almost immediately.
    This also helps me figure out ahead of time what things can be done immediately, and what steps can't be tackled right now or have requirements that need to be met first (like ordering parts), further assisting me in making better use of my time.
    Generally speaking, planning and "thinking ahead"; writing down lists of steps, decisions, requirements, etc (and crossing off those that are completed, done, etc) has become an invaluable habit in working efficiently, both at home as well as at work.
  • rsc
    rsc 9 months ago
    The most time-saving habit I've picked up is to add the date/revision to a filename when I save it.  ...and remembering to put the connector shell on the cable before soldering it.....
  • Aniket_kumar_raj
    Aniket_kumar_raj 9 months ago in reply to wolfgangfriedrich
    Woh, that's what I need to, what's the simulation software is called,I used tinkercad but that for limited
  • Aniket_kumar_raj
    Aniket_kumar_raj 9 months ago in reply to Arnovsharma
    I am sure it's AI generated
  • Aniket_kumar_raj
    Aniket_kumar_raj 9 months ago in reply to dang74
    That's too relatable, I think almost everyone here does this
  • wolfgangfriedrich
    wolfgangfriedrich 9 months ago
    Simulate critical parts of the design. If the simulation works, chances are that you saved one iteration of design and the likelihood of the 1st prototype working increased by a lot. If the simulation fails, the hardware will fail for sure.
    • Vote Up +5 Vote Down
  • Aniket_kumar_raj
    The most time saving thing ever done in my life was organising all stuffs cuz as a tech guy there is a mess really on cupboard and table,which makes it harder to find things, like if I say you to find a male to male jumper wire then you won't be able to without a deep adventure in the abyss
  • Arnovsharma
    The habit that has been most valuable to me is to document my work as I do it, rather than later.
    This includes:
    • Maintaining a simple project log (even in a notebook or text file).
    • Recording why I made a particular design decision.
    • Recording pin connections, jumper settings, and test results.
    • Saving versions of schematics, code, and PCB files with descriptive names.
    Why this saves time:
    When I return to a project after several weeks or months, I don’t have to try to figure out what I did. I can simply pick up where I left off.
