Member's Forum What’s the most time-saving habit you’ve picked up? We are asking e14 in our Join, Share & Win Competition
  • Locked Locked
  • Replies 71 replies
  • Subscribers 626 subscribers
  • Views 13410 views
  • element14 community
  • win
  • element14 members
  • aske14
E14Alice
E14Alice 9 months ago
A new month means a new AskE14!
Engineers, makers, and problem‑solvers are always finding smarter ways to work. From optimising workflows to automating repetitive tasks, small habits can add up to serious time savings.
This month, AskE14 is all about sharing the habits that help you work more efficiently, whether you’re designing, prototyping, debugging, documenting, or managing projects.
Time for the question:
Time is a valuable resource in engineering. A simple habit — like better version control, smarter test setups, or clearer documentation. This can save hours down the line.
Competition Details
You'll have to be a member of the element14 Community to join in and take part in this “Join, Share & Win” challenge. It's simple, all you have to do is:
1. You need to make sure you are  Register  or Login
2. Then answer the following question by adding a reply or commenting!
This month, we are giving away:
The Community team will then select the best 3 answers to win the UNO R4 Minima!
Closing date: 1st March
Winners announced: 10th March
UNO R4 Minima
Terms and Conditions
imagePDF
The winners!
dang74
wolfgangfriedrich
skruglewicz
E14Alice will be reaching out to you soon to confirm contact details
  • lightwoheat
    lightwoheat 9 months ago
    I would say working with tools have contributed to my efficiency. On the Hardware side tools like USB Bridges like i2cdriver and spidriver by excamera great. Tie that tool in with software tools that work with those USB bridge hardware like UXB from labs16’s and it’s made debugging hardware and development efficient.
    on the Firmware side AI like Claude has been great.
    curious what USB bridges others are using?
  • veluv01
    veluv01 9 months ago
    I'd say adding proper comments (block wise instead of just at the top of the file) throughout my code. It kinda sounds basic, but saves my time for the future me trying to understand the stuff I wrote a few weeks ago and also my coworkers don't have to haunt me with the questions about it.
  • BigG
    BigG 9 months ago in reply to wolfgangfriedrich
    I certainly need to do this more often. I've had a case where hardware did fail and on close inspection of the design had identified an issue, but could not quite explain the why. Other engineers had other ideas. It was most satisfying when the LTspice simulation was completed, and it was able to not only mimic the failure but was also able to show why the attempted fixes did not work. It then proved the hunch.
    These days you can simulate directly via KiCAD. So no excuses.
  • robogary
    robogary 9 months ago
    Keeping tbe workshop, parts, and tools organized.
    There was a previous E14 discussion post on this topic. I continue to refine the workshop and workbench areas,  in fact, I have just ordered an "Pack Over Door Organizer with 5 Large Pockets 10 Mesh Side Pockets, 44 lbs Weight Capacity Hanging Storage Organizer with Clear Window Kids Toys, Shoes, Diapers, Dark Grey, 5 Layers" People often use these for baby supplies or bathroom supplies.
    Im going to use this organizer to put DVMs, handheld scopes, usb scopes, bags of sorted usb cables,  crimpers and strippers,  markers, pencils and pens - stuff that gets buried on my workbench , that needs to be quickly accessed and kept nearby. Im also running out of floor space for shelves and drawers.
    I waste too much time looking for parts and meters when getting into the heat of battle.
    dougw 9 months ago
    I use many methods to save time such as organizing tools and components during a build so that I can access everything from where I sit without standing up, but the one that saves the most time is structuring my workflow so that I can order long lead components as early in the project as possible.
    michaelkellett 9 months ago in reply to wolfgangfriedrich
    LT Spice is one of very few things which is both good and free. It does rather push you towards the Analog Devices part for any given job (assuming they make one) because it only includes ready to use models for their chips (although you can use spice models from other manufacturers with a little bit of effort (although they don't always work)).
  • battlecoder
    battlecoder 9 months ago in reply to wolfgangfriedrich
    I've been doing some simulations in LTSpice lately, and it's made so much easier and faster to test stuff out. They also help me figure out if something works or not before even hitting the breadboard so I agree!
  • wolfgangfriedrich
    wolfgangfriedrich 9 months ago in reply to Aniket_kumar_raj
    LTspice for discrete circuits and ModelSim for VHDL design.
    And then there is QSpice which claims to be able to simulate digital (C, VHDL) and discrete components in the same design, but I did not have time to try it out properly.
    And for simple stuff there is always a handheld calculator and Brain1.0
  • dang74
    dang74 9 months ago in reply to Aniket_kumar_raj
    Perphaps... but what I see is that many people discuss using AI for code generation... but not so much for verification... so I posted this to benefit those that are not doing this... there is still a caveat though in terms of privacy and one should be mindful of their company's IP policies before pasting code into something like ChatGPT.
  • bradfordmiller
    bradfordmiller 9 months ago
    When writing code I generally work bottom up and, I also write the test cases for that code (based on the spec), which can be commented out (or in a separate file not normally loaded). Then I can test each module separately which saves a lot of time during integration (higher level testing) as the lower level parts are known to meet their specification. Additionally some of these tests (e.g., type validation of arguments) can be added directly into the code but suppressed for higher optimization levels (i.e. for delivery).
    Design by contract languages may help with this as well, though I'm not currently using one. I suppose this would be the moral equivalent of using SystemVerilog for testbenches, but something that can be carried around in code that is actually being executed on the target rather than only in simulation.
