Member's Forum Learning FPGA
  • Replies 15 replies
  • Subscribers 626 subscribers
  • Views 1046 views
  • fpga
Learning FPGA
danielpgleason
danielpgleason 6 months ago
Does anyone know of any good learning resources about how to start learning FPGA? I've been a software engineer for several years and the FPGA world is quite new to me. I'm trying to implement RMII but have been struggling a lot. I purchased a logic analyzer but I don't know what I'm looking at. I need something that will tell me how to properly understand and read datasheets, know how to debug signals, how to understand what VHDL is good and what is bad. How to read RTL generations..Etc
I'm starting from the beginning. Any resources or materials are greatly appreciated.
  • danielpgleason
    danielpgleason 6 months ago in reply to shabaz
    Do you know of any places I could learn how to implement SPI? or RMII?
  • danielpgleason
    danielpgleason 6 months ago in reply to dhmarinov
    What do you think about Altera FPGAs? Are they also well documented?
  • dhmarinov
    dhmarinov 6 months ago
    Hi, it's great that you are looking into FPGAs. It's a steep learning curve, there area a lot of topics to cover and depending on the FPGA vendor you might have easier/hard time with the tools.
    I'd recommend starting with Xilinx/AMD devices as the tools are a bit "easier" to navigate, and the documentation is ample.
    1. I'd suggest downloading Vivado from the AMD website and start exploring it a bit by writing some simple VHDL code, making a test bench for it and synthesizing the design.
        This is a good starting point as you can see how your code works, without wasting time of HW debugging.
    2. While doing 1, explore the VHDL language, the best resource is the "VHDL golden reference guide", also sites like vhdlwhiz.
         It is quite different from the programming languages in a sense that you have to think "hardware", and not just a list of commands.
    3. Once you get the basic idea of the language you can start with some simple designs - UART, SPI, etc.
         At this point, you can implement the design on your FPGA and observe it with your logic analyser to test whether it works as expected.
    4. Finally, there are also plenty of IPs  (intellectual Property, i.e. like a library) provided by the vendors, including virtual probes and analysers and ever RMII.
        To ge to know these, you simply read through the manuals for the respective IP.
    Good luck with it, don't hesitate to ask questions Slight smile
  • beacon_dave
    beacon_dave 6 months ago in reply to shabaz
    shabaz said:
    You may wish to read up on digital electronics too, since with HDLs you're describing digital logic.
    This might be one to add to the reading list as it covers both camps.
    Video accompaniment for the book "Introduction to Logic Circuits & Logic Design with VHDL" by Brock LaMeres.
    https://www.youtube.com/watch?v=HLM2epN9C2I&list=PL643xA3Ie_Et2uM4xu1yFk-A5ZQQ8gQ5e&index=47
    Unfortunately the audio recording quality isn't great.
    There is a matching book on Verilog if there is a need to flip between the two HDLs.
    shabaz 6 months ago
    There isn't any single comprehensive resource/book for complete beginners. You could try checking out the resources mentioned here:
    The Art of FPGA Design - Post 3
    You'll also need to plan in advance what software apps you need, because some of them can take a day to download, and others may require licenses to be obtained (which may also take days). Some have particular operating system, processor and memory requirements. After you've read up a bit, you could purchase an FPGA board to try things on.
    You will need to invest a fair bit of time, and be prepared that things move differently in the FPGA world than for software development; unlike software where you can rapidly compile and just try it out, generally, for FPGAs, things need a lot more planning, you'd try to write test cases, and try it out virtually before trying it for real; plus, the entire "build" process takes a lot longer than running gcc hello_world.c.
