Member's Forum Top Tech Voices Podcast S2 E6: Smart Cities & Urban Tech
  • Replies 23 replies
  • Subscribers 627 subscribers
  • Views 1197 views
  • top-tech-voices
  • top tech voices podcast
  • podcast
  • smart cities
  • ttv2
  • TOP TECH VOICES 2
JoRatcliffe
JoRatcliffe 5 months ago
It is time for the final episode of Top Tech Voices Season 2 and we are ending on a high with engineer and architect Carlo Ratti as the guest.
Tune in for an episode covering:
  • Why Carlo finds waste management fascinating
  • How technology is making Venice more resilient to climate change
  • Creating cyber-physical systems where real-time data triggers physical responses across a city
 Click the banner below to watch the podcast video or listen on your favorite platform.
Or you can watch straight away here:
Leave a comment and be in the running to win a prize!
All you have to do is the following:
  1. You have to either Register or Login
2. Leave a comment or reply below!
Comments should include constructive discussion on the episode's topics (for example, making cities more adaptable with technology, designing cities with multiple generations of people in mind, future-proofing against climate change), or useful feedback that helps improve future podcasts.
Separate to the contest, I am also interested to know how you like to watch Top Tech Voices. Do you listen while you work or do you watch it on your TV? Let me know!
The Community team will select the best 5 comments to each win an Arduino Uno Q 4GB!
Learn More
 Terms and Conditions
The Winners
  • Akansha
  • beacon_dave
  • gordonmx
  • jelektro
  • kmikemoo
  • Qbit
    Qbit 5 months ago in reply to beacon_dave
    That is a phenomenal breakdown, and you’ve highlighted a terrifyingly realistic point about 'data cross-linking' . It’s exactly like metadata analysis in cybersecurity—even if an Edge AI node strips out a citizen's MAC address or name at the sensor level, a third party can easily reconstruct identities just by cross-referencing timestamps from an automated traffic camera with local smart-meter spikes. The anonymity completely breaks down in a centralized cloud.
    ​Your point about municipal authorities filtering or 'smoothing out' peak readings (like long-term averaging pollution data to avoid legal negligence) is an incredible insight into why top-down smart systems inevitably face public skepticism.
    ​If policy is lagging so far behind the hardware rollout, do you think the only way to enforce true transparency is through immutable edge logging? For instance, if an open-source environmental sensor cryptographically signs and publishes its raw data directly to a public ledger or distributed network the moment it captures it, the authorities couldn't manipulate the averages retrospectively to hide defects or pollution spikes.
    ​It seems like until we build systems where the hardware itself prevents data tampering, citizen trust will remain at zero.
  • beacon_dave
    beacon_dave 5 months ago in reply to Qbit
    Qbit said:
    I plan to use the Arduino Uno R4 to build an open-source, edge-computing nodes array for micro-climate and localized air quality tracking—directly mirroring the philosophy behind his 'City Scanner' project.
    I recall that there was a study by University of Surrey involving the use of sensor box devices fitted to prams in order to sample the air quality as they were pushed around urban areas.
    https://www.surrey.ac.uk/news/when-are-babies-prams-most-exposed-air-pollution
    https://www.sciencedirect.com/science/article/pii/S0160412019345593#s0010
    I think Bristol may have done something similar as part of their Smart Cities project. It was featured in a documentary programme but can't recall which one. I recall members of the public were invited to fit them to prams to build up a wider picture of daily  pollution exposure in urban areas.
  • beacon_dave
    beacon_dave 5 months ago in reply to beacon_dave
    beacon_dave said:
    At the time, I recall that there were quite a few interesting TV programmes about the type of stuff they were doing
    This was one: The Joy of Data
  • beacon_dave
    I think that citizen trust probably has already been lost with the number of historical cases of data leaks and data being sold onto private companies without any citizen approval.
    Not only that, there is a problem that 'data x' may appear to be safe to openly share now but when combined with new 'data y' in the future, then it may not have been such a great idea to have shared 'data x'. Equally data processing and analytics has now become powerful enough to combine multiple large data sets and it could end up too late for the citizen to do anything about it retrospectively.
    Policy and governance may be reluctant to openly share data as it could start to be used against them. One example might be the condition of the road network. If citizens can openly access data that shows that the authorities had access to information about the location of a defect in the road prior to an accident or damage, then this data could potentially be used in law to support a claim of negligence resulting in compensation pay-outs. Similar with air quality monitoring if it can be shown that it was known that pollution levels regularly exceeded safe limits, then a sensor network originally for safeguarding the community then it could become a weapon in the hands of the legal system. With that being the case, then any open data may end up being filtered or manipulated (e.g. filter out peak readings or use a long term averages to round off them off), causing distrust.
    A lot of data is already held centralized on municipal servers and is openly made available already (if you know where to look) but it tends to be anonymized summary data rather than raw live data, and often with little information on how exactly it has been collected and processed.
    In some cases, I think the line has probably already been crossed. With the likes of forced roll-out of 'smart' utility meters, then data is already being collected and probably not being securely stored and may already being shared with partner companies without the knowledge of the citizen. Often there is also no clarity on what data is actually being captured, transmitted, stored, shared. Similar with the likes of data from traffic cameras.
    Edge processing requires trust in the person that is providing the product to ensure that the data is strictly anonymized both in normal use and can remain so even after an unexpected device security breach. Also need to consider the integrity of anonymity when multiple devices are in use and a third party has access to multiple data sets which can be cross-linked.
    I think the issue is perhaps that the technology is developing at a far faster rate than the policy required to protect the citizen being exposed to it.
  • Qbit
    Qbit 5 months ago in reply to kmikemoo
    @kmikemoo Exactly! I really liked the segment around 21:30 where they discussed 'Technology vs. Community.' If a smart city is just a sterile, top-down surveillance matrix built by big corporations, it loses its soul. The real magic happens when open data empowers independent makers and community developers to build hyper-localized hardware tools—like a custom neighborhood air quality monitor or transit tracker—tailored directly to their own streets. It keeps the community at the center of the tech.
  • Qbit
    ​@beacon_dave You've hit on the core dilemma Carlo brought up around the 13-minute mark regarding privacy and trust. When we move tracking from the digital space to physical urban infrastructure, the stakes skyrocket. From a hardware perspective, do you think the solution to building that citizen trust relies on moving entirely toward decentralized, local Edge processing where data is strictly anonymized at the sensor node before hitting any municipal servers, or is it fundamentally a policy and governance problem that hardware can't fix?
  • beacon_dave
    Interesting the views on architecture bringing more nature back into the urban environment, however this appears to be the exact opposite of what is currently happening here. The architects / urban planners if anything are increasing the density of the built environment at every opportunity. A lower density house with garden space is more likely to be refused a planning application than a higher density block of flats. Greenbelt land is being built upon at an increasing rate. Allocating / retaining space for nature is unlikely to provide the same income streams as high-density accommodation.
    Perhaps the only realistic chance of incorporating nature into the new builds and public spaces now would be rooftop / vertical gardens and perhaps have skywalks between them.
    Also interesting the views on using nature to drive reactive systems, but given that architects currently appear to struggle to design new energy efficient homes with heating/cooling systems that just work, then this sounds rather ambitious and fraught with problems down the line.
    In the 80's architects experimented with mechanical iris shutters on the likes of the Institut du Monde Arabe building in Paris, to create a kinetic façade to control light entering the building
    https://www.youtube.com/watch?v=gq6x3x3YXFY
    very nice, both aesthetic and functional but over time it stopped working resulting in expensive repairs
    https://www.youtube.com/watch?v=kEI4wml0F78
    which raises the question of how today's world of built in obsolescence would impact reactive systems.
    "Your house isn't compatible with the latest upgrade, you'll need a new one..."
    At least they had the foresight to allow the reactive panel to be accessed from the inside for ease of repair/replacement.
    As for making the urban environment more resilient to climate change, then architects don't appear to have a handle yet on the current climate judging by the amount of damage every year caused by wind, rain and flooding. It appears that around two-thirds of homes in the UK fail to meet the current efficiency standards with only around two-fifths of new builds meeting current standards. Perhaps better monitoring of actual performance as opposed to relying upon predicted performance, could help steer design choices.
  • Qbit
    Qbit 5 months ago
    Carlo Ratti’s discussion on open-source architecture and treating environments as responsive, living organisms is a masterclass for hardware developers. His point that 'you can only change what you know' is the ultimate argument for deploying localized edge-sensing.
    ​I plan to use the Arduino Uno R4 to build an open-source, edge-computing nodes array for micro-climate and localized air quality tracking—directly mirroring the philosophy behind his 'City Scanner' project. By leveraging the Uno's processing power to handle real-time sensor data loops without relying on heavy external libraries, we can prototype the exact low-cost, decentralized cyber-physical systems needed to make our communities more adaptive. Exceptional interview, Farnell team!
  • beacon_dave
    beacon_dave 5 months ago in reply to dougw
    Here they designate green belts but then just appear to go on to concrete over them regardless, then wonder why they now have issues with surface water run-off.
    dougw 5 months ago
    Interesting perspective on bringing nature back into cities as population decreases, although I expect my city will be growing for the rest of my life. On the other hand my city has a massive "green belt" (over 200 square kilometers) purposely reserved for natural vegetation - no buildings. It is already the largest green space in any city in the world. (which means it has the lowest population density of any city with over 1M people <370 per sq km)
    I would like to hear more about how to obtain more useful city data with less infrastructure and less instrumentation.
