Member's Forum Who's in the UK and has caved in and bought air conditioning?
  • Replies 93 replies
  • Subscribers 624 subscribers
  • Views 3197 views
  • air conditioning
  • heatwave
stanto
stanto 5 months ago
I picked up something like this about three years ago. No regrets.
Though I can't help but feel like I'm also adding to the climate problem.
  • stanto
    stanto 4 months ago in reply to beacon_dave
    Something I've been considering is a design of hooking fans into the window opening to either force air to move out of the room or suck air in.
    I've seen designs for this for american windows, but nothing for the typical swing out english windows.
  • Andrew J
    Andrew J 4 months ago in reply to beacon_dave
    We've also started looking at external shutters as well.
  • beacon_dave
    beacon_dave 4 months ago in reply to Andrew J
    Andrew J said:
    Opening windows does nothing, neither does closing curtains.
    I'm experiencing the same here. Ideally need window shutters on the outside that can be closed during the day.
    I conducted a crude airflow observation test yesterday evening as the bedroom was back up to 30C at midnight with windows open and the forecast suggested it should be a more pleasant 23C outside.
    Even though I could hear a stiff breeze outside, there was surprisingly little noticeable movement of air by the open window. Very occasionally the tell-tale tissue indicator would be sucked outward and then return to vertical.
    I was thinking that perhaps an 8" air mover something like:
    https://cpc.farnell.com/clarke-international/3230442/cam200b-8-ventilator-blue/dp/HG01469
    or a fan tray using something like:
    https://cpc.farnell.com/sunon/a2259-mbt-tc-gn/fan-ac-230v-254x89/dp/MF67639
    attached to a window vent might be enough to get some air exchange happening.
    Andrew J said:
    Jokingly I say ‘you can have it hot or you can have it hot with bugs” in reference to opening windows at night where it might be a bit cooler outside.
    A mosquito mesh over the window opening might help reduce the number of bugs on the inside.
    michaelkellett 4 months ago in reply to Andrew J
    You could install a split unit yourself. It's not hard - I did a cheap one a few years ago and it was designed for DIY installation - came pre-filled with instructions about how to join the two units without losing all the gas !
    The prices at the usual places are a bit of rip off but there are cheaper on line suppliers - https://www.aircondirect.co.uk/ct/heating-and-air-conditioning/air-conditioners for example (I have no connection with them and haven't bought anything from them).
    I bought mine from CPC ( a branch of Farnell) but they don't seem to do them any more.
  • Andrew J
    Andrew J 4 months ago in reply to ralphjy
    Yes, our ages are catching up with us and we're struggling now after a month of this!  I am aware of multi-split units but my concern as noted is routing through the walls - the trades here just don't seem to understand the requirements.  If it could route UP through the bedroom ceiling into the loft and then out and down to the outside unit that would work.  I would think having a unit that could supply, say, 3 units would be ideal although I'm not sure where I would put the outdoor unit.
    We're an all electric house with solar, battery, ASHP and a £0 bill last year so we have capacity to run AC during the summer weeks it is needed.
  • ralphjy
    ralphjy 4 months ago in reply to Andrew J
    Wow, I grew up on Pacific islands so I was accustomed to 30C temps and high humidity but I don't think I could tolerate that anymore. I don't sleep well when temps are above 25C.
    You might want to consider a mini-split AC unit to at least cool off your bedroom.  They seem to do a good job and don't require ducting, although you still need a hole for the refrigerant lines.  A lot of apartments buildings in my area (Portland, Oregon) have been installing them.  They really work well if you have a well insulated room.  My sister-in-law in Hawaii has a couple installed and they manage to do okay even with her poorly insulated house (she has solar to offset the energy inefficiency).
  • dang74
    dang74 4 months ago in reply to stanto
    LOL not exactly what I had in mind when I was thinking of a green but yeah, sometimes you have to respect the resilience of weeds.
  • Andrew J
    I seriously consider it every year but the costs for what is typically a few days a few times a year puts me off.  Our house is timber framed and well insulated so he typical temperature inside has been around 30c consistently for some time now; the bedroom gets up to 32c.  Opening windows does nothing, neither does closing curtains.  Jokingly I say ‘you can have it hot or you can have it hot with bugs” in reference to opening windows at night where it might be a bit cooler outside.  Anyway opening windows does very little.  However, having a timber framed house I’m very worried about letting people punch ducting holes through the external walls as most/all tradies seem to have little to no knowledge of how to deal with this type of construction.  Bizarrely, as it isn’t new; I’d assume it would be better in Scotland.
    We were on a road trip in Europe from 10th June to 4th July.  First 3 days were 18c/19c and drizzly; 4th day was the right side of hot; 5th day onwards was blazing hot and we were unable to do very much as we really struggled with the heat.  Unfortunately, the heatwave reappeared in the UK when we got back so we’ve not been comfortable since something like the 14th June.  It’s very wearing trying to sleep in 30c-32c temps.  Definitely back to seriously thinking about it: best would be ceiling mounted units that could be ducted in via the loft and thus pipework is outside the protected timber frame.  That worked great for installing the ASHP.  Speaking of which, I would seriously recommend people consider an air-to-air heat pump if they are looking to move in that direction as that does cooling and heating, potentially at 400%+ efficiency.
    michaelkellett 4 months ago in reply to dang74
    In SW Scotland (Dumfries and Galloway) this year we've had a LOT of rain and it's been warm but not as hot as further south in the UK.
    As a result the green stuff has grown like mad. Not looking parched yet.
    But it's getting away from me on my land because it's alternated between being too wet to cut anything or too hot. The willow loves it.
  • beacon_dave
    beacon_dave 4 months ago in reply to stanto
    I suspect that the paving will likely slow down the rate of evaporation from the soil below but the weed roots will be able to extend under the paving and access the moisture.
    Likewise, plants with deeper roots will likely be able to last longer than those with shallower surface spreading roots.
    The next heatwave is underway here, so trying to keep the garden alive with the watering can, without wasting too much water in the process. The 'drumstick' Alliums have just come into flower and the bumblebees are relying on them.
