Member's Forum NZ Earthquake
  • Replies 36 replies
  • Subscribers 632 subscribers
  • Views 2874 views
NZ Earthquake
mcb1
mcb1 over 9 years ago
Guys/Gals
Just a quick update on the major Earthquake that struck NZ north of Christchurch just after midnight.
They have decided that there was two quakes and they are still deciding if it was along the Hope faultline which runs SW to NE and forms the hills that are between the Southern Alps and the east coast.
It would seem that this triggered many others right up the North Island so the effects were felt widespread.
I'm in Chch and was up at the time. It went on for 2-3 mins which is much longer than the previous ones.
The closest place is Kaikoura and it has caused some damage to houses, but has currently cut the road link that goes up the east coast (State Highway 1), and damaged other roads that could form an alternative route.
There was a Tsuanami warning issued, but got downgraded to a coastal warning.
Unfortunately these warnings end up much less than predicted, so if we actually get a real one, then I'm afraid many will ignore it.
For those that haven't experienced Earthquakes, they can be very disturbing to some people.
There is often little/no warning and while it might be a little bit of shaking at first, you have no idea how long it will last, or if it will get worse.
NZ sits on the junction of two plates and one is going under the other. The movement is constant, but various bits get stuck and then suddenly release as the stress overcomes the friction.
This release often results in extra loading on another part and triggers an aftershock which can be almost as large.
So far there have been 50 or more aftershocks in and around the area, so you get no rest from them.
GeoNet - Quakes
As you can imagine you lose power, your house gets trashed and you get no rest, so it's quite stressful in the affected are.
The christchurch event in 2010 had around 14,000 aftershocks varying down to only just detectable without instruments.
So this will last for some days and it may trigger more events.
If you have friends and relatives in NZ, do try to make contact but appreciate that cellphone systems get overloaded and texts are the best way to contact them.
Cheers
    DAB over 9 years ago in reply to mcb1
    Actually, fracking could be a great way to keep these faults moving with little quakes instead of the periodic big quakes.
    There have been some very interesting USGS studies on the potential benefits to lubricating the big faults like the San Andreas so that they move more often but with less damage.
    The problem is that there is so much pent up movement, they are afraid to try it for fear of triggering the big quake.
    You also have to understand that in Oklahoma, they have pumped a huge volume of water out of the Aquafier under the state.  So fracking is only part of the quake generation.
    mcb1 over 9 years ago in reply to dougw
    And they wanted to do fracking here in canterbury ... duuh we already have enough without making them.
    dougw over 9 years ago in reply to DAB
    Be thankful you don't live in Oklahoma. Look what is going on there in the last few years since fracking began - 1000 major man-made quakes per year ....
    DAB over 9 years ago in reply to COMPACT
    I am not sure that mars has quakes unless it get hits by sizeable asteroids or comets.
    I believe that Venus is still active and we know a number of Jupiter and Saturn moons experience intense geological dynamics.
    So some days you are just going to feel the earth move under your feet.  If you are lucky, you can just say what was that?  If you are really close, then you are in greater danger.
    I still remember the first earthquake I experienced here in Ohio.  If felt like someone was shuffling the bricks in the house as it shook and rocked.  I cannot image a large quake, but I do sympathize with those who do.
  • COMPACT
    COMPACT over 9 years ago in reply to mcb1
    I won't hear a Baa of it!
    mcb1 over 9 years ago in reply to COMPACT
    As I understand the Australian plate is buckling to NZ's domination and going under us.
    This means the West Coast is meant to rise 8m if the Alpine Fault goes off.!
    I'm not so sure our sheep want to meet your sheep, so if you have one of those ground anchors, now would be a good time to deploy it. image
    Cheers
  • COMPACT
    COMPACT over 9 years ago in reply to dougw
    Ahhh, The Ring of Fire with Hawaii in the middle!
    That plate is apparently moving West North West in line with the co-linear Hawaiian islands.
    I don't know about NZ but Australia is moving northward pushing into Papua/New Guinea.
    Interestingly when I was visiting New York City a few years ago it had an Earthquake, followed by massive flooding.
    Maybe I'll have to tread lighter.
    dougw over 9 years ago in reply to mcb1
    You can find a lot of info on quakes at the USGS....
    ... a lot of red dots around NZ ....
    Good thing you guys are tough ...
    Is NZ getting closer to the Americas or further away?
  • COMPACT
    COMPACT over 9 years ago in reply to DAB
    Only on Earth...
    I assume they have Marsquakes on Mars and Venusquakes on Venus.
    I suppose when building electrical equipment for these planets you'll have to have safety Mars and Venuses.
  • Instructorman
    Instructorman over 9 years ago in reply to ntewinkel
    Nico,
    I'm in Edmonton.  Pretty much the most northerly major city in North America.
    Every January I wonder why a million people chose to live at 53 degrees North latitude.
    Then again, every June I think, wow, it sure is great to have sunlight at 10 pm, so I'm kind of conflicted.
    Mark A
