Member's Forum Introducing a New Member
  • Replies 50 replies
  • Subscribers 635 subscribers
  • Views 3666 views
  • new_member
jw0752
jw0752 over 8 years ago
I recently met a new friend. He was working on a medical device and was referred to me as someone who could help him find some parts he needed. His name is Von Wolff. As I learned about him and his background in Electronics I felt he would make a good member for the element 14 Forum. I recommended that he join and I was really pleased when he followed through and signed up. vwolff Von has for over 30 years been a Design and Verification Engineer in the field of integrated circuit design and function. He has been involved in designing complex ICs for aerospace and commercial industrial applications. He has experience with many of the specialized hardware and software tools used in the design and verification process. He has completed contract projects with over 20 major companies but some of his best stories are from his beginnings working for Walt Disney, designing the ride control systems for Disneyland, Disney World, and the Epcot Center. He also spent a time designing spacecraft monitoring systems for NASA at the Jet Propulsion Lab. Von retired in 2017 and recently he has been working on some bio-electronic projects. I am looking forward to continuing my friendship with Von and I hope my friends on element 14 give him a nice welcome. As we have all experienced, the forum can be a little challenging to figure out and navigate on first contact so any hints and tips will probably be appreciated.
    jw0752 over 8 years ago in reply to genebren
    Hi Gene,
    Von and I spent a couple hours today testing the MOSFET circuit that you recommended. We are using a TC2320 chip which has one N Ch and one P Ch chip in an SOIC 8 package. This allows us to put one driver circuit on each bread board adapter. I was also able to pull the other peripheral passives up onto the little adapter board. We will be able to drive one each of Von's 16 channels with each module and all we will have for external connections are power rails and one input and one output. We both want to thank you for the good solution to increasing the output of the device.
    The blue is the signal from the generator and the yellow is the output from the MOSFET module.
  • e14phil
    e14phil over 8 years ago
    Welcome vwolff
    genebren over 8 years ago in reply to jw0752
    John,
    The N-Channel MOSFET acts as an open drain inverter, so replacing it with an open collector inverter works fine.  Or, you could leave out the 7406 and drive an N-channel MOSFET directly (as shown in the initial reply).  Either way should work fine.
    Gene
    Is there any advantage to the two stages using the P Ch as a switch and the N Ch as a driver? I have some TC2320 chips which house one of each.
    John,
    Here is a quick sketch of how you could do this with a 7406 (open collector) to switch the high-side MOSFET.  Shown is a single channel.
    Gene
    Hi Gene,
    I am trying to set up a bread board of the circuit you proposed using the BSD 223.  If I am using the output of a 7406 for the input how do I interface. Do I have one channel or do I have two with the 2 inputs and 2 outputs. Von may understand but I don't and I am trying to set up the experiment before he comes in the next few days.
  • fmilburn
    fmilburn over 8 years ago in reply to jw0752
    Great!
    jw0752 over 8 years ago in reply to fmilburn
    Hi Frank,
    An extra thank you as Von and I were able to collaborate to fix the power supply in large part to having the schematics and parts list.
  • vwolff
    vwolff over 8 years ago in reply to fmilburn
    Thanks Frank.  I downloaded them.  That is a good site.
    Von
    Thanks Frank,
    I down loaded them for Von.
