Andy Clark's Blog USB Keyboard / HID
  • Author Author: Workshopshed
  • Date Created: 24 May 2020 4:48 PM Date Created
  • Views 5561 views
  • Likes 11 likes
  • Comments 8 comments
  • arduino mkr zero
  • hid
  • usb
  • samd21
USB Keyboard / HID
Workshopshed
Workshopshed
24 May 2020
I've been experimenting with the Arduino MKR Zero board and wanted it to act as a USB keyboard. This board is based on the SAMD21 processor core which has a native USB wired to one of the sercom peripherals. But when I tried it out the keyboard was not sending data to the PC.
I swapped to the simplest example I could find but still no luck. I also tried the https://github.com/NicoHood/HID library to see if that worked any better than the Arduino one but no luck.
Looking in device manager, the keyboard was not showing up and the MKZero was reporting an error.
On the advice of one of the forums, I downloaded USBDeview. That showed a bit more detail as to what was going on.  The Arduino was reporting as a HID device but it was hooked up to a serial driver. That did not seem right.
I did a bit more searching and found that someone else had also had problems with this device. https://github.com/arduino/ArduinoCore-samd/issues/423
Looks like the problem is complicated because the board is a composite device supporting multiple USB devices e.g. a CDC (virtual com port), a HID and also a real serial port.
As the original commenter had reported that this issue started with a specific version of the boards package, I rolled back to the one before that version and that seems to have resolved the issue. Now sending keystrokes to the host does what it should.
The follow up on the forum is interesting in that Arduino have reversed the order of USB enumeration in the firmware. So to get the keyboard to work on the MKR Zero with Windows 10 you need to do the upgrade then remove the old drivers. Windows 10 can use it's own drivers apparently. I'll give that a try after finishing this little project.
    DAB over 6 years ago in reply to Fred27 +5
    This is a true story, back when I was just getting into computers, one of the top bosses came around looking for anyone who could program a PDP-11. I told them that I could and they asked if I was willing…
  • Workshopshed
    Workshopshed over 6 years ago in reply to DAB +2
    "2's compliment"
    DAB over 6 years ago +1
    Easy fix, though hard to find. DAB
  • Fred27
    Fred27 over 6 years ago in reply to DAB
    Is it always the way. I've spent a week once trying to find a bug in someone else's complicated convoluted code. The fix was changing true to false.
  • Fred27
    I told them that I could and they asked if I was willing to do a trip to Huntsville, Alabama to help them solve a computer problem.
    This was my first airplane trip and first business trip.
    So I flew in the next day.
    In the morning I went with our local engineer to the lab and started looking at the problem. They were trying to read a magnetic tape, but all of the values were weird. I took one look at the data and replied, it looks like it is in 2's compliment. The programmer immediately smacked his forehead, ran to his desk, pulled out the format book for the tape, and sure enough, it was in 2's compliment.
    So I solved their problem in about five minutes of work, got a nice dinner and flew out the next morning.
    Sometimes, you just need a fresh pair of eyes to see the obvious.
    • Vote Up +5 Vote Down
  • Workshopshed
    "2's compliment"
    dubbie over 6 years ago in reply to DAB
    DAB,
    Sometimes it is just your presence that fixes things. I have noticed that at work and home that when I simply walk into the room, all the problems in that room people are having resolve themselves, quite often without any intervention from me! Is it just coincidence, or is it something special about me.
    Dubbie
