Legacy Personal Blogs 1870's Programmable Clock Project...
  • Author Author: jonivanart
  • Date Created: 11 Jan 2016 2:03 AM Date Created
  • Views 2023 views
  • imbedded
  • robotics
  • collectable
  • horology
  • old
  • clocks
  • art
  • electronics
  • programmable
  • opensource
jonivanart
jonivanart
11 Jan 2016
First off, I have no idea how to do a blog so if this goes tot he wrong place then sorry in advance. LOL!
I am working on my 4th art project in a series called "TIME". Everything is in #steampunk style art. I have built a Violin, a lamp and a Guitar. (#JonIvanArt) The latest and No. 4 is a clock dated around 1870 or earlier. I'm calling it the "#ExplodedClock" because it will be as if the top right exploded and the steam generator grew out of it.
When I received the clock it was in the case that was damaged and the mechanics was in terrible shape. I had to tear it down and clean and polish the whole mechanism. It will be driven by 2 Arduino's. The first #Arduino has the tasks of moving the clock drive gear train with a stepper, the LCD display, and a solenoid that will engage every half second. I have a video that shows the operation of the solenoid posted here and on YouTube under my Jon Ivan channel. The second Arduino will operate the chimes which will be vibrating cell phone motors with Haptic drivers. It will also operate the chime side of the drive gears with a stepper. On top of this there will be a couple vaccum tubes lit with LED's from whichever source I can control it from, Arduino1 or 2.
At the moment I have removed the clock for the wooden mount I built and am building the case. This is the front of the clock with it's crack built in but not the final color.
Here is a picture of it mounted and the #solenoid cover installed.
    jw0752 over 10 years ago +1
    Hi Jon, It looks like you are off to a great start. I like to see the mixture of art and technology. I look forward to following your project. By the way your blog post turned out perfect. John
    balearicdynamics over 10 years ago +1
    Great idea ! Wait to see how the stuff proceed Enrico
  • jonivanart
    jonivanart over 10 years ago +1
    I'm guessing that I just add updates in the comment section so here goes! :-) I've got most of the mounting frame work cut to shape, the glass in it's frame and fitted to the clock face. In the picture…
  • jonivanart
    I've got most of the mounting frame work cut to shape, the glass in it's frame and fitted to the clock face. In the picture it shows the water tank to the right in what I think will be the final position but not yet mounted.
    The center of the face that is light colored will be removed later after the case is more stable without it. You will be able to see the clock movement from the front through the glass. I'm working on the trim pieces at the moment. Much more to go before the programming process but at least theres progress! ;-)
    jw0752 over 10 years ago in reply to jonivanart
    I like to see art that is created out of technology. I have even tried a couple times but I am sure my talent, what little there is, lies on the technology side of the equation.
