Legacy Personal Blogs 4 Bit Accumulator - Adder
  • Author Author: timswift
  • Date Created: 1 Nov 2016 1:20 AM Date Created
  • Views 1727 views
  • transistor
  • computer
  • adder
  • cpu
  • accumulator
timswift
timswift
1 Nov 2016
I have recently constructed a 4 bit adder and accumulator.
The input of the adder is set by switches and the other input comes from the accumulator, the output is fed back into the accumulator.
The contents of the accumulator is displayed on four LED's and the carry out from the adder is displayed on one LED.
Some photographs;
The accumulator - adder:
One bit adder board:
The devise uses 144 transistors.
  Tim
  • timswift
    timswift over 9 years ago in reply to jc2048 +1
    I have considered using the ALU to increment the program counter but that would use two more clock tick's. I have not looked into relative branches that much, but if they add that much benefit I may consider…
  • 4-bitcomputernerd
    4-bitcomputernerd over 1 year ago
    Do you happen to have a schematic?
  • timswift
    clock tick's.
    I have not looked into relative branches that much, but if they add that much benefit I may consider adding them.
    Tim
    jc2048 over 9 years ago
    In your previous blog post, you talked about the program counter [as a counter] and extended that to using a simple adder. If you were to use this ALU (that you're working towards) to instead manipulate the program counter then you'd be able to add relative branches almost for free.
  • timswift
    timswift over 9 years ago in reply to DAB
    Thanks!
    I will soon be using this in my 4 bit test ALU if that works I'll upgrade to 8 bit's.
    Tim
    DAB over 9 years ago
    Nice, it takes me back to my bit slice days in the 1970's when we began making special digital control devices from basic computer components.
