Legacy Personal Blogs 4 Bit ALU
  • Author Author: timswift
  • Date Created: 5 Nov 2016 12:33 AM Date Created
  • Views 1913 views
  • Comments 10 comments
  • 4 bit
  • transistor
  • alu
  • computer
  • diy
  • cpu
4 Bit ALU
timswift
timswift
5 Nov 2016
This is my 4 bit test ALU.
It has 6 functions, Add with carry, Subtract with carry, Shift Right with carry fill, AND, OR, and XOR.
While assembling the ALU I made some errors two of them being with the adder carry chain being wired backwards (MSB to LSB)
And the same with the shifter; wired to left shift instead of right shift.
It uses 181 transistor's and I am currently constructing the full 8 bit ALU which will contain 346 transistor's.
A photograph with labels:
   The small Mux is to select the carry out from ether the adder, shifter, or the carry In.
   The inverter mux selects between invert or pass (used to select subtraction/addition).
Tim
  • phoenixcomm
    phoenixcomm over 9 years ago +3
    I LOVE IT.. somebody with more patience than I. I worked for Interdata 76 - 78. In 1980 I built a 16bit Z-80 out of AMD-2901 4bit slices. I also added more register sets. Back in 68 I also did something…
  • phoenixcomm
    phoenixcomm over 9 years ago in reply to timswift +1
    timswift ts a piece of cake! You just have to have the right tools, and wire for that matter. Don't try and wire wrap without a wire wrap gun. You just have to practice a few times. Wire: 30 AWG (very…
  • phoenixcomm
    Back in 68 I also did something cruder than what you are doing with RTL my memory was just 8 bits but I think I used like 12 relays for each word  8data + 4control
    I used a Rotary Stepping Switch for addressing and it could add and subtract a multiplication was done the hard way  ie no barrel shifter.
    By the way If you are curious I have a copy of the Mick and Brick book (how to build a 370) if you would like to have a copy just em me.
    GUTS!!
  • phoenixcomm
    GUTS!!
    clem57 over 9 years ago in reply to phoenixcomm
    You have a book on building a 370??? Oh that would be a great read...
    Clem
  • timswift
    timswift over 9 years ago in reply to clem57
    The 370 is a 32 bit IBM mini-computer... Right?
    Tim
    clem57 over 9 years ago in reply to timswift
    No, it is an IBM mainframe in the late 70's.
    Clem
