Legacy Personal Blogs Arduino: R-2R: Setting the Output Frequency
  • Author Author: jc2048
  • Date Created: 25 Apr 2018 2:23 PM Date Created
  • Views 5872 views
  • Comments 15 comments
  • r2r
  • arduino uno project
jc2048
jc2048
25 Apr 2018
I've made a bit more progress. I now have my test code connected to the SCPI parser. That was very easy to do: I simply copied their generator example, took out the lines specific to the chip they were using, and adapted it slightly to calculate the table step. Much to my amazement it works and I can now program the output frequency.
Here's the sketch. The two includes that the highlighting wipes out are:
#include <scpiparser.h>
#include <Arduino.h>
#include
#include
struct scpi_parser_context ctx;
float frequency;
scpi_error_t identify(struct scpi_parser_context* context, struct scpi_token* command);
scpi_error_t get_frequency(struct scpi_parser_context* context, struct scpi_token* command);
scpi_error_t set_frequency(struct scpi_parser_context* context, struct scpi_token* command);
unsigned int tableOffset = 0;             // output count
unsigned int tableStep = 5120;
//  --- Sine table - generated by sineTable.exe
unsigned int sineTable[512] = {
   0x8000,0x8192,0x8324,0x84b6,0x8647,0x87d9,0x896a,0x8afb,0x8c8b,0x8e1b,0x8fab,0x9139,0x92c8,0x9455,0x95e2,0x976d,
   0x98f8,0x9a82,0x9c0b,0x9d93,0x9f19,0xa09f,0xa223,0xa3a6,0xa528,0xa6a8,0xa826,0xa9a3,0xab1f,0xac98,0xae11,0xaf87,
   0xb0fb,0xb26e,0xb3de,0xb54d,0xb6ba,0xb824,0xb98c,0xbaf2,0xbc56,0xbdb8,0xbf17,0xc073,0xc1ce,0xc325,0xc47a,0xc5cd,
   0xc71c,0xc869,0xc9b4,0xcafb,0xcc3f,0xcd81,0xcebf,0xcffb,0xd133,0xd269,0xd39b,0xd4ca,0xd5f5,0xd71d,0xd842,0xd964,
   0xda82,0xdb9d,0xdcb4,0xddc7,0xded7,0xdfe3,0xe0ec,0xe1f1,0xe2f2,0xe3ef,0xe4e8,0xe5dd,0xe6cf,0xe7bd,0xe8a6,0xe98c,
   0xea6d,0xeb4a,0xec24,0xecf9,0xedca,0xee96,0xef5f,0xf023,0xf0e2,0xf19e,0xf255,0xf307,0xf3b5,0xf45f,0xf504,0xf5a5,
   0xf641,0xf6d9,0xf76c,0xf7fa,0xf884,0xf909,0xf98a,0xfa05,0xfa7d,0xfaef,0xfb5d,0xfbc5,0xfc29,0xfc89,0xfce3,0xfd39,
   0xfd8a,0xfdd6,0xfe1d,0xfe5f,0xfe9d,0xfed5,0xff09,0xff38,0xff62,0xff87,0xffa7,0xffc2,0xffd8,0xffe9,0xfff6,0xfffd,
   0xffff,0xfffd,0xfff6,0xffe9,0xffd8,0xffc2,0xffa7,0xff87,0xff62,0xff38,0xff09,0xfed5,0xfe9d,0xfe5f,0xfe1d,0xfdd6,
   0xfd8a,0xfd39,0xfce3,0xfc89,0xfc29,0xfbc5,0xfb5d,0xfaef,0xfa7d,0xfa05,0xf98a,0xf909,0xf884,0xf7fa,0xf76c,0xf6d9,
   0xf641,0xf5a5,0xf504,0xf45f,0xf3b5,0xf307,0xf255,0xf19e,0xf0e2,0xf023,0xef5f,0xee96,0xedca,0xecf9,0xec24,0xeb4a,
   0xea6d,0xe98c,0xe8a6,0xe7bd,0xe6cf,0xe5dd,0xe4e8,0xe3ef,0xe2f2,0xe1f1,0xe0ec,0xdfe3,0xded7,0xddc7,0xdcb4,0xdb9d,
   0xda82,0xd964,0xd842,0xd71d,0xd5f5,0xd4ca,0xd39b,0xd269,0xd133,0xcffb,0xcebf,0xcd81,0xcc3f,0xcafb,0xc9b4,0xc869,
   0xc71c,0xc5cd,0xc47a,0xc325,0xc1ce,0xc073,0xbf17,0xbdb8,0xbc56,0xbaf2,0xb98c,0xb824,0xb6ba,0xb54d,0xb3de,0xb26e,
   0xb0fb,0xaf87,0xae11,0xac98,0xab1f,0xa9a3,0xa826,0xa6a8,0xa528,0xa3a6,0xa223,0xa09f,0x9f19,0x9d93,0x9c0b,0x9a82,
   0x98f8,0x976d,0x95e2,0x9455,0x92c8,0x9139,0x8fab,0x8e1b,0x8c8b,0x8afb,0x896a,0x87d9,0x8647,0x84b6,0x8324,0x8192,
   0x8000,0x7e6d,0x7cdb,0x7b49,0x79b8,0x7826,0x7695,0x7504,0x7374,0x71e4,0x7054,0x6ec6,0x6d37,0x6baa,0x6a1d,0x6892,
   0x6707,0x657d,0x63f4,0x626c,0x60e6,0x5f60,0x5ddc,0x5c59,0x5ad7,0x5957,0x57d9,0x565c,0x54e0,0x5367,0x51ee,0x5078,
   0x4f04,0x4d91,0x4c21,0x4ab2,0x4945,0x47db,0x4673,0x450d,0x43a9,0x4247,0x40e8,0x3f8c,0x3e31,0x3cda,0x3b85,0x3a32,
   0x38e3,0x3796,0x364b,0x3504,0x33c0,0x327e,0x3140,0x3004,0x2ecc,0x2d96,0x2c64,0x2b35,0x2a0a,0x28e2,0x27bd,0x269b,
   0x257d,0x2462,0x234b,0x2238,0x2128,0x201c,0x1f13,0x1e0f,0x1d0d,0x1c10,0x1b17,0x1a22,0x1930,0x1842,0x1759,0x1673,
   0x1592,0x14b5,0x13db,0x1306,0x1235,0x1169,0x10a0,0x0fdc,0x0f1d,0x0e61,0x0daa,0x0cf8,0x0c4a,0x0ba0,0x0afb,0x0a5a,
   0x09be,0x0926,0x0893,0x0805,0x077b,0x06f6,0x0675,0x05fa,0x0582,0x0510,0x04a2,0x043a,0x03d6,0x0376,0x031c,0x02c6,
   0x0275,0x0229,0x01e2,0x01a0,0x0162,0x012a,0x00f6,0x00c7,0x009d,0x0078,0x0058,0x003d,0x0027,0x0016,0x0009,0x0002,
   0x0000,0x0002,0x0009,0x0016,0x0027,0x003d,0x0058,0x0078,0x009d,0x00c7,0x00f6,0x012a,0x0162,0x01a0,0x01e2,0x0229,
   0x0275,0x02c6,0x031c,0x0376,0x03d6,0x043a,0x04a2,0x0510,0x0582,0x05fa,0x0675,0x06f6,0x077b,0x0805,0x0893,0x0926,
   0x09be,0x0a5a,0x0afb,0x0ba0,0x0c4a,0x0cf8,0x0daa,0x0e61,0x0f1d,0x0fdc,0x10a0,0x1169,0x1235,0x1306,0x13db,0x14b5,
   0x1592,0x1673,0x1759,0x1842,0x1930,0x1a22,0x1b17,0x1c10,0x1d0d,0x1e0e,0x1f13,0x201c,0x2128,0x2238,0x234b,0x2462,
   0x257d,0x269b,0x27bd,0x28e2,0x2a0a,0x2b35,0x2c64,0x2d96,0x2ecc,0x3004,0x3140,0x327e,0x33c0,0x3504,0x364b,0x3796,
   0x38e3,0x3a32,0x3b85,0x3cda,0x3e31,0x3f8c,0x40e8,0x4247,0x43a9,0x450d,0x4673,0x47db,0x4945,0x4ab2,0x4c21,0x4d91,
   0x4f04,0x5078,0x51ee,0x5367,0x54e0,0x565c,0x57d9,0x5957,0x5ad7,0x5c59,0x5ddc,0x5f60,0x60e6,0x626c,0x63f4,0x657d,
   0x6707,0x6892,0x6a1d,0x6baa,0x6d37,0x6ec6,0x7054,0x71e4,0x7374,0x7504,0x7695,0x7826,0x79b8,0x7b49,0x7cdb,0x7e6d};
void setup()
  struct scpi_command* source;
  struct scpi_command* measure;
  /* First, initialise the parser. */
  scpi_init(&ctx);
   * After initialising the parser, we set up the command tree.  Ours is
   *  *IDN?         -> identify
   *  :SOURCE
   *    :FREQuency  -> set_frequency
   *    :FREQuency? -> get_frequency
  scpi_register_command(ctx.command_tree, SCPI_CL_SAMELEVEL, "*IDN?", 5, "*IDN?", 5, identify);
  source = scpi_register_command(ctx.command_tree, SCPI_CL_CHILD, "SOURCE", 6, "SOUR", 4, NULL);
  scpi_register_command(source, SCPI_CL_CHILD, "FREQUENCY", 9, "FREQ", 4, set_frequency);
  scpi_register_command(source, SCPI_CL_CHILD, "FREQUENCY?", 10, "FREQ?", 5, get_frequency);
  frequency = 1e3;
  // set the pins used as outputs:
  PORTD = 0;
  pinMode(0, OUTPUT);
  pinMode(1, OUTPUT);
  pinMode(2, OUTPUT);
  pinMode(3, OUTPUT);
  pinMode(4, OUTPUT);
  pinMode(5, OUTPUT);
  pinMode(6, OUTPUT);
  pinMode(7, OUTPUT);
  pinMode(A0, OUTPUT);
  pinMode(A1, OUTPUT);
  pinMode(A2, OUTPUT);
  pinMode(A3, OUTPUT);
  digitalWrite(A0, HIGH);
  digitalWrite(A1, HIGH);
  digitalWrite(A2, HIGH);
  digitalWrite(A3, LOW);
  // timer 2 set up
  cli();                  // disable interrupts
  TCCR2A = 0;             // control register all 0
  TCCR2B = 0;             // control register all 0
  TCNT2 = 0;              // set count to 0
  OCR2A = 159;            // period = 160 x 1/16MHz = 10uS
  TCCR2A |= (1 << WGM21); // mode is clear on match
  TCCR2B |= (1 << CS20);  // no prescaler
  TIMSK2 |= (1 << OCIE2A);  // enable interrupt on match
  sei();                  // enable interrupts
  Serial.begin(9600);
// timer 2 interrupt routine
ISR(TIMER2_COMPA_vect) {
  tableOffset = tableOffset + tableStep;
  PORTD = (sineTable[tableOffset >> 7]) >> 8;
// main loop
void loop()
  char line_buffer[256];
  unsigned char read_length;
  while(1)
    /* Read in a line and execute it. */
    read_length = Serial.readBytesUntil('\n', line_buffer, 256);
    if(read_length > 0)
      scpi_execute_command(&ctx, line_buffer, read_length);
 * Respond to *IDN?
  scpi_free_tokens(command);
  Serial.println("E14,Arduino Audio Signal Generator,1,10");
  return SCPI_SUCCESS;
 * Read the current frequency setting.
//  float voltage;
  Serial.println(frequency,4);
 * Set the audio output frequency.
  struct scpi_token* args;
  struct scpi_numeric output_numeric;
//  unsigned char output_value;
  args = command;
  while(args != NULL && args->type == 0)
    args = args->next;
  output_numeric = scpi_parse_numeric(args->value, args->length, 1e3, 20, 2e4);
  if(output_numeric.length == 0 ||
    (output_numeric.length == 2 && output_numeric.unit[0] == 'H' && output_numeric.unit[1] == 'z'))
    tableStep = (unsigned int)(65536.0 * output_numeric.value / 100000.0);
    frequency = (unsigned long)constrain(output_numeric.value, 20, 2e4);
  else
    scpi_error error;
    error.id = -200;
    error.description = "Command error;Invalid unit";
    error.length = 26;
    scpi_queue_error(&ctx, error);
Here are the results for the following SCPI messages
:SOUR:FREQ 20Hz
:SOUR:FREQ 1234Hz
:SOUR:FREQ 2e4Hz
The frequencies are fairly accurate, being within a few Hertz of those requested.
This is the line that does the real work (line 158)
it takes the frequency from the parser (a float in Hertz) and calculates the table step necessary to generate it. The 100k is the sample rate, the 65536 is the number of intervals one complete cycle is divided into.
There are a couple of issues I've identified from doing this:
1/ The amplitude dimishes at high frequencies. That means that either I've got my filter values wrong or that the variable gain section is a mess. To look at that I'm going to go back to my test code and rework it to do a frequency sweep - then I'll be able to see directly the frequency response on the 'scope. It also looks like there might be other problems with the 20kHz one.
2/ The serial side seems a bit fragile. I can't seem to talk to it with PuTTY (probably just me not being able to get the settings right), but have also once got it into a state where it wouldn't talk to the Arduino serial tool either, so maybe the error recovery isn't very good.
However, it's looking quite promising as a very low cost way to generate waveforms.
The original blog by Jan, where he introduced us to the SCPI library that he'd found, is here: Arduino in Test Instrumentation - Part 1: SCPI Lib
This is the SCPI parser library on GitHub: https://github.com/LachlanGunn/oic
Part one: Arduino: R-2R Experiment
Part two: Arduino: R-2R: Sine On You Crazy Diamond
Part three: Arduino: R-2R: Buffer, Attenuate, and Filter
Part four: Arduino: R-2R: "We Interrupt This Programme..."
Part five: Arduino: R-2R: "Resistance is..."?
Part six: Arduino: R-2R: Setting the Output Frequency
Part seven: Arduino: R-2R; "A Sweep is as Lucky, as Lucky Can Be..."
Part eight: Arduino: R-2R: Setting the Signal Amplitude
  • fmilburn
    fmilburn over 8 years ago +3
    A nice well documented series - I have enjoyed following along.
    Jan Cumps over 8 years ago +3
    for the PuTTY settings, you may have to turn on local echo, so that you see what you type, and maybe CR + LF. it works reliable with the Arduino Serial Monitor if you have the speed setting correct.
    Jan Cumps over 8 years ago in reply to jc2048 +3
    I’ll check tomorrow, when I’m back in the country. it may also be related with the cpu reset that happens on an Arduino UNO when you start up a serial communication over the USB.
  • jc2048
    jc2048 over 8 years ago in reply to Jan Cumps
    I turned on local echo. I also turned off 'XON/XOFF', but I wasn't very sure about the CR and LF settings - I'll give it another go; it should to be possible to make it work.
    The time that it failed on the Arduino monitor I had had it working, shut down the monitor and tried using PuTTY, and then tried the Arduino monitor again. It didn't pick up again on the Arduino serial monitor, so PuTTY had got it into a mess that it couldn't recover from. Perhaps that doesn't matter - serial over USB is going to be very robust - but I still like to see things recover for themselves.
    I also can't get it to work with PuTTY. It works ok with the Arduino monitor and LabVIEW.
    No idea what's happening ...
    I got it working.
    set No CR/LF extra's -  leave all default.
    Set local echo ON, local edit OFF.
    serial settings: <your baud>, 8, 1, 0, N
    Have a notepad file with the command, example:
    *IDN?
    Copy the *IDN? - just that, and then right click on putty to paste it. Don't press the enter button.
    That's it.
    It works like that for all commands. It seems that our lib doesn't like individually typed characters, and doesn't like CR/LF
    It's not related to PuTTY. It has the same behaviour in Ubuntu using the screen terminal (screen /dev/ttyACM0 38400,cs8)
    edit:
    It's not really the library. It's the code stolen from the example:
      while(1)   {
        if(read_length > 0)     {
    I got it working.
    *IDN?
    That's it.
    edit:
      while(1)   {
  • jc2048
    That works for me too. So what's the Arduino Serial Monitor doing? Does it just send a LF and no CR?
    It's actually the way we read the serial string, not the lib itself. I stole it from the example that came with the lib:
      while(1)   {
    I'll check if I can fix it and still have it working with  LabVIEW lib.
    Jan Cumps over 8 years ago in reply to Jan Cumps
    This one works with putty (carriage return instead of newline):
    void loop() {
      while(1)   {
    //    read_length = Serial.readBytesUntil('\n', line_buffer, 256);
        read_length = Serial.readBytesUntil('\r', line_buffer, 256);
    It doesn't work with my LabVIEW driver (because I'm using '\n' in all my SCPI commands image ). Not hard to change though ...
  • jc2048
    I've just tried stripping off the return if it's there and it works fine with PuTTY now
        if(read_length >0)
          if(line_buffer[read_length-1]=='\r')
            read_length = read_length - 1;
        if(read_length > 0)
    That's nice. That works in PuTTY, Arduino monitor and my LabVIEW lib. image
