Legacy Personal Blogs Arduino: R-2R: Setting the Signal Amplitude
  • Author Author: jc2048
  • Date Created: 30 Apr 2018 2:33 PM Date Created
  • Views 4005 views
  • Comments 7 comments
  • arduino uno project
jc2048
jc2048
30 Apr 2018
I'm back again with the resistor DAC on an Arduino Uno as a simple audio generator. I'm not clear how I came to do so many blogs on it, but this is going to be the last one.
Here's the latest sketch with commands for setting the output level as well as the frequency. This sketch is for a Uno, so may need adaption for other boards. I've changed the command to be 'FUNCtion' rather than 'SOURce' simply because I can (though I probably ought to read the SCPI spec and see what you should use, in case they recommend command usage).
#include <scpiparser.h>
#include <Arduino.h>
#include
#include
struct scpi_parser_context ctx;
float frequency;
float voltage;
scpi_error_t identify(struct scpi_parser_context* context, struct scpi_token* command);
scpi_error_t get_frequency(struct scpi_parser_context* context, struct scpi_token* command);
scpi_error_t set_frequency(struct scpi_parser_context* context, struct scpi_token* command);
scpi_error_t get_voltage(struct scpi_parser_context* context, struct scpi_token* command);
scpi_error_t set_voltage(struct scpi_parser_context* context, struct scpi_token* command);
unsigned int tableOffset = 0;             // output count
unsigned int tableStep = 5120;
unsigned char amplitudeSelect = 0;
//  --- Sine table - generated by sineTable.exe
unsigned int sineTable[512] = {
   0x8000,0x8192,0x8324,0x84b6,0x8647,0x87d9,0x896a,0x8afb,0x8c8b,0x8e1b,0x8fab,0x9139,0x92c8,0x9455,0x95e2,0x976d,
   0x98f8,0x9a82,0x9c0b,0x9d93,0x9f19,0xa09f,0xa223,0xa3a6,0xa528,0xa6a8,0xa826,0xa9a3,0xab1f,0xac98,0xae11,0xaf87,
   0xb0fb,0xb26e,0xb3de,0xb54d,0xb6ba,0xb824,0xb98c,0xbaf2,0xbc56,0xbdb8,0xbf17,0xc073,0xc1ce,0xc325,0xc47a,0xc5cd,
   0xc71c,0xc869,0xc9b4,0xcafb,0xcc3f,0xcd81,0xcebf,0xcffb,0xd133,0xd269,0xd39b,0xd4ca,0xd5f5,0xd71d,0xd842,0xd964,
   0xda82,0xdb9d,0xdcb4,0xddc7,0xded7,0xdfe3,0xe0ec,0xe1f1,0xe2f2,0xe3ef,0xe4e8,0xe5dd,0xe6cf,0xe7bd,0xe8a6,0xe98c,
   0xea6d,0xeb4a,0xec24,0xecf9,0xedca,0xee96,0xef5f,0xf023,0xf0e2,0xf19e,0xf255,0xf307,0xf3b5,0xf45f,0xf504,0xf5a5,
   0xf641,0xf6d9,0xf76c,0xf7fa,0xf884,0xf909,0xf98a,0xfa05,0xfa7d,0xfaef,0xfb5d,0xfbc5,0xfc29,0xfc89,0xfce3,0xfd39,
   0xfd8a,0xfdd6,0xfe1d,0xfe5f,0xfe9d,0xfed5,0xff09,0xff38,0xff62,0xff87,0xffa7,0xffc2,0xffd8,0xffe9,0xfff6,0xfffd,
   0xffff,0xfffd,0xfff6,0xffe9,0xffd8,0xffc2,0xffa7,0xff87,0xff62,0xff38,0xff09,0xfed5,0xfe9d,0xfe5f,0xfe1d,0xfdd6,
   0xfd8a,0xfd39,0xfce3,0xfc89,0xfc29,0xfbc5,0xfb5d,0xfaef,0xfa7d,0xfa05,0xf98a,0xf909,0xf884,0xf7fa,0xf76c,0xf6d9,
   0xf641,0xf5a5,0xf504,0xf45f,0xf3b5,0xf307,0xf255,0xf19e,0xf0e2,0xf023,0xef5f,0xee96,0xedca,0xecf9,0xec24,0xeb4a,
   0xea6d,0xe98c,0xe8a6,0xe7bd,0xe6cf,0xe5dd,0xe4e8,0xe3ef,0xe2f2,0xe1f1,0xe0ec,0xdfe3,0xded7,0xddc7,0xdcb4,0xdb9d,
   0xda82,0xd964,0xd842,0xd71d,0xd5f5,0xd4ca,0xd39b,0xd269,0xd133,0xcffb,0xcebf,0xcd81,0xcc3f,0xcafb,0xc9b4,0xc869,
   0xc71c,0xc5cd,0xc47a,0xc325,0xc1ce,0xc073,0xbf17,0xbdb8,0xbc56,0xbaf2,0xb98c,0xb824,0xb6ba,0xb54d,0xb3de,0xb26e,
   0xb0fb,0xaf87,0xae11,0xac98,0xab1f,0xa9a3,0xa826,0xa6a8,0xa528,0xa3a6,0xa223,0xa09f,0x9f19,0x9d93,0x9c0b,0x9a82,
   0x98f8,0x976d,0x95e2,0x9455,0x92c8,0x9139,0x8fab,0x8e1b,0x8c8b,0x8afb,0x896a,0x87d9,0x8647,0x84b6,0x8324,0x8192,
   0x8000,0x7e6d,0x7cdb,0x7b49,0x79b8,0x7826,0x7695,0x7504,0x7374,0x71e4,0x7054,0x6ec6,0x6d37,0x6baa,0x6a1d,0x6892,
   0x6707,0x657d,0x63f4,0x626c,0x60e6,0x5f60,0x5ddc,0x5c59,0x5ad7,0x5957,0x57d9,0x565c,0x54e0,0x5367,0x51ee,0x5078,
   0x4f04,0x4d91,0x4c21,0x4ab2,0x4945,0x47db,0x4673,0x450d,0x43a9,0x4247,0x40e8,0x3f8c,0x3e31,0x3cda,0x3b85,0x3a32,
   0x38e3,0x3796,0x364b,0x3504,0x33c0,0x327e,0x3140,0x3004,0x2ecc,0x2d96,0x2c64,0x2b35,0x2a0a,0x28e2,0x27bd,0x269b,
   0x257d,0x2462,0x234b,0x2238,0x2128,0x201c,0x1f13,0x1e0f,0x1d0d,0x1c10,0x1b17,0x1a22,0x1930,0x1842,0x1759,0x1673,
   0x1592,0x14b5,0x13db,0x1306,0x1235,0x1169,0x10a0,0x0fdc,0x0f1d,0x0e61,0x0daa,0x0cf8,0x0c4a,0x0ba0,0x0afb,0x0a5a,
   0x09be,0x0926,0x0893,0x0805,0x077b,0x06f6,0x0675,0x05fa,0x0582,0x0510,0x04a2,0x043a,0x03d6,0x0376,0x031c,0x02c6,
   0x0275,0x0229,0x01e2,0x01a0,0x0162,0x012a,0x00f6,0x00c7,0x009d,0x0078,0x0058,0x003d,0x0027,0x0016,0x0009,0x0002,
   0x0000,0x0002,0x0009,0x0016,0x0027,0x003d,0x0058,0x0078,0x009d,0x00c7,0x00f6,0x012a,0x0162,0x01a0,0x01e2,0x0229,
   0x0275,0x02c6,0x031c,0x0376,0x03d6,0x043a,0x04a2,0x0510,0x0582,0x05fa,0x0675,0x06f6,0x077b,0x0805,0x0893,0x0926,
   0x09be,0x0a5a,0x0afb,0x0ba0,0x0c4a,0x0cf8,0x0daa,0x0e61,0x0f1d,0x0fdc,0x10a0,0x1169,0x1235,0x1306,0x13db,0x14b5,
   0x1592,0x1673,0x1759,0x1842,0x1930,0x1a22,0x1b17,0x1c10,0x1d0d,0x1e0e,0x1f13,0x201c,0x2128,0x2238,0x234b,0x2462,
   0x257d,0x269b,0x27bd,0x28e2,0x2a0a,0x2b35,0x2c64,0x2d96,0x2ecc,0x3004,0x3140,0x327e,0x33c0,0x3504,0x364b,0x3796,
   0x38e3,0x3a32,0x3b85,0x3cda,0x3e31,0x3f8c,0x40e8,0x4247,0x43a9,0x450d,0x4673,0x47db,0x4945,0x4ab2,0x4c21,0x4d91,
   0x4f04,0x5078,0x51ee,0x5367,0x54e0,0x565c,0x57d9,0x5957,0x5ad7,0x5c59,0x5ddc,0x5f60,0x60e6,0x626c,0x63f4,0x657d,
   0x6707,0x6892,0x6a1d,0x6baa,0x6d37,0x6ec6,0x7054,0x71e4,0x7374,0x7504,0x7695,0x7826,0x79b8,0x7b49,0x7cdb,0x7e6d};
void setup()
  struct scpi_command* scpiCommand;
  /* First, initialise the parser. */
  scpi_init(&ctx);
   * After initialising the parser, we set up the command tree.  Ours is
   *  *IDN?         -> identify
   *  :FUNC
   *    :FREQuency  -> set_frequency
   *    :FREQuency? -> get_frequency
   *    :VOLTage  -> set_amplitude
   *    :VOLTage? -> get_amplitude
  scpi_register_command(ctx.command_tree, SCPI_CL_SAMELEVEL, "*IDN?", 5, "*IDN?", 5, identify);
  scpiCommand = scpi_register_command(ctx.command_tree, SCPI_CL_CHILD, "FUNCTION", 8, "FUNC", 4, NULL);
  scpi_register_command(scpiCommand, SCPI_CL_CHILD, "FREQUENCY", 9, "FREQ", 4, set_frequency);
  scpi_register_command(scpiCommand, SCPI_CL_CHILD, "FREQUENCY?", 10, "FREQ?", 5, get_frequency);
  scpi_register_command(scpiCommand, SCPI_CL_CHILD, "VOLTAGE", 7, "VOLT", 4, set_voltage);
  scpi_register_command(scpiCommand, SCPI_CL_CHILD, "VOLTAGE?", 8, "VOLT?", 5, get_voltage);
  frequency = 1e3;
  // set the pins used as outputs:
  PORTD = 0;
  pinMode(0, OUTPUT);
  pinMode(1, OUTPUT);
  pinMode(2, OUTPUT);
  pinMode(3, OUTPUT);
  pinMode(4, OUTPUT);
  pinMode(5, OUTPUT);
  pinMode(6, OUTPUT);
  pinMode(7, OUTPUT);
  pinMode(A0, OUTPUT);
  pinMode(A1, OUTPUT);
  pinMode(A2, OUTPUT);
  pinMode(A3, OUTPUT);
  digitalWrite(A0, HIGH);
  digitalWrite(A1, HIGH);
  digitalWrite(A2, HIGH);
  digitalWrite(A3, LOW);
  // timer 2 set up
  cli();                  // disable interrupts
  TCCR2A = 0;             // control register all 0
  TCCR2B = 0;             // control register all 0
  TCNT2 = 0;              // set count to 0
  OCR2A = 159;            // period = 160 x 1/16MHz = 10uS
  TCCR2A |= (1 << WGM21); // mode is clear on match
  TCCR2B |= (1 << CS20);  // no prescaler
  TIMSK2 |= (1 << OCIE2A);  // enable interrupt on match
  sei();                  // enable interrupts
  Serial.begin(9600);
// timer 2 interrupt routine
ISR(TIMER2_COMPA_vect) {
  tableOffset = tableOffset + tableStep;
  PORTD = (sineTable[tableOffset >> 7]) >> 8;
// main loop
void loop()
//  char line_buffer[256];
  char line_buffer[128];
  unsigned char read_length;
  while(1)
    /* Read in a line and execute it. */
    read_length = Serial.readBytesUntil('\n', line_buffer, 256);
    if(read_length >0)
      if(line_buffer[read_length-1]=='\r')
        read_length = read_length - 1;
    if(read_length > 0)
      scpi_execute_command(&ctx, line_buffer, read_length);
 * Respond to *IDN?
  scpi_free_tokens(command);
  Serial.println("E14,Arduino Audio Signal Generator,1,10");
  return SCPI_SUCCESS;
 * Read the current frequency setting.
//  float voltage;
  Serial.println(frequency,4);
 * Set the audio output frequency.
  struct scpi_token* args;
  struct scpi_numeric output_numeric;
//  unsigned char output_value;
  args = command;
  while(args != NULL && args->type == 0)
    args = args->next;
  output_numeric = scpi_parse_numeric(args->value, args->length, 1e3, 20, 2e4);
  if(output_numeric.length == 0 ||
    (output_numeric.length == 2 && output_numeric.unit[0] == 'H' && output_numeric.unit[1] == 'z'))
    tableStep = (unsigned int)(65536.0 * output_numeric.value / 100000.0);
    frequency = (unsigned long)constrain(output_numeric.value, 20, 2e4);
  else
    scpi_error error;
    error.id = -200;
    error.description = "Command error;Invalid unit";
    error.length = 26;
    scpi_queue_error(&ctx, error);
 * Read the current voltage setting.
  Serial.println(voltage,4);
 * Set the audio output amplitude.
  float testLevel;
  args = command;
    args = args->next;
  output_numeric = scpi_parse_numeric(args->value, args->length, 0.4, 0.050, 0.8);
    (output_numeric.length == 1 && output_numeric.unit[0] == 'V'))
 //   tableStep = (unsigned int)(65536.0 * output_numeric.value / 100000.0);
    voltage = constrain(output_numeric.value, 0.05, 0.8);
    testLevel = 0.05;
    while(amplitudeSelect < 16) {
      if(voltage <= testLevel)
        break;
      testLevel = testLevel + 0.05;
      amplitudeSelect = amplitudeSelect + 1;
    voltage = testLevel;
    amplitudeSelect = 15 - amplitudeSelect;
  else
    scpi_error error;
    error.id = -200;
    error.length = 26;
  digitalWrite(A0, (amplitudeSelect & 0x01));
  digitalWrite(A1, (amplitudeSelect & 0x02)>>1);
  digitalWrite(A2, (amplitudeSelect & 0x04)>>2);
  digitalWrite(A3, (amplitudeSelect & 0x08)>>3);
Here it is working with PuTTY:
The output level is in volts and is constrained to the range 50mV to 800mV in steps of 50mV. That's the peak-to-peak voltage; here's what 2kHz and 800mV looks like on the 'scope:
The firmware will take the next highest level - you can see that in the line where I try to set it to 23mV and it returns 50mV for the current level.
I had one problem with doing all this. Initially, when I put in the two new commands, it didn't work and the firmware locked up - it didn't even respond to the IDN request. That turned out to be because the SCPI library uses a fair amount of memory when the program runs; with my sine table (which uses up half of the processor's RAM) in there it was running out of space. I've temporarily cured that by reducing the line buffer from 256 to 128 characters. The sine table doesn't have to be ints (I made it int originally because I was thinking I might be scaling the values) and so reducing that to unsigned chars would be a better solution, but I didn't want to have to redo the table at this stage. If you use the library keep an eye on the dynamic memory allocated - it's a bit confusing to debug if you don't realise what's going on.
I'm going to leave this here, rather than finish it off as a full project. If you wanted to take it further, issues to think about include:
a) Power rails - using the +5V rail from the Arduino Uno leaves the resulting waveforms somewhat noisy.
b) There is some frequency variation evident on the higher frequency waveforms. I haven't investigated further, but it probably means either that there's something with a higher priority than the timer 2 interrupt or something is disabling all interrupts for short periods.
c) Trying to use an LM324 wan't very inspired.
Part one: Arduino: R-2R Experiment
Part two: Arduino: R-2R: Sine On You Crazy Diamond
Part three: Arduino: R-2R: Buffer, Attenuate, and Filter
Part four: Arduino: R-2R: "We Interrupt This Programme..."
Part five: Arduino: R-2R: "Resistance is..."?
Part six: Arduino: R-2R: Setting the Output Frequency
Part seven: Arduino: R-2R; "A Sweep is as Lucky, as Lucky Can Be..."
    Jan Cumps over 8 years ago in reply to shabaz +3
    In the c++ libraries, there is a nice tokeniser for the command line attributes. It's been since the late 90's that I used it though. I moved on
    shabaz over 8 years ago +2
    Hi Jon, It is very neat you got all that to function on an Uno, including amplitude adjustments and parsing the interace in real-time. It is fairly complete already! Nice feature/performance mix. I too…
    Jan Cumps over 8 years ago in reply to shabaz +2
    shabaz wrote: ... I still found it hard to get the parsing all sorted (I'm not using SCPI, but the concept was similar). The advantage of SCPI is that there are capable open sourced parsers for grabs.…
    Hi Jon,
    I too have been working on a frequency generator (a work in progress for an awfully long time), but the coding was easier since I used an external IC to do the actual signal generation, and I still found it hard to get the parsing all sorted (I'm not using SCPI, but the concept was similar).
    Hi Jon,
    The one that's used on the Arduino is basic (given the memory) but smart enough to serve an application like Jon's.
    The parser we used for the electronic load (on a MSP432 microcontroller and that I'm now trying on a Pi) is magnificent. SCPI compliance out of the box, including the error handling. Easy to add new SCPI commands.
    Someone managed to get that compiled for the UNO, but not with using the bootloader and Arduino environment. And with virtually no place for the instrument code image.
    Anyways, what I wanted to say is that if you use an existing standard, the parser is often already built and debuged for you.
  • jc2048
    jc2048 over 8 years ago in reply to shabaz
    I wouldn't have even tried this if Jan hadn't pointed us to the open-source SCPI library that we're using. The other thing that helped me was finding out, towards the end of last year, that you could program the Uno directly in C - somehow, up until then, I'd thought that it was limited to the commands in the reference.
    Did you have reasons for not wanting to use SCPI (just wondering about the pros and cons since I'm not very familiar with automated test equipment)?
    shabaz over 8 years ago in reply to jc2048
    Hi Jon, Jan,
    Sorry I should have been clearer, I had no issue with SCPI for automation, just in my use-case I wasn't doing automation, the parser was for human-machine interface, i.e. a user interface like a command prompt.
    It is awesome that there is a SCPI parser for Arduino.
    Definitely for machine to machine (M2M) and controlling and co-ordinating multiple instruments a structured interface like SCPI is handy.
    Darn command prompts!
    There are some good parsers for those too, in particalar for unix style parameter parsing. But everyone knows that's a G2M (geek-machine) interface.
    shabaz over 8 years ago in reply to Jan Cumps
    Hehe yeah indeed, more G2M. I explored reusing the source code to one of the Linux shells (maybe csh, I can't recall), but in the end wrote something very cut-down, but with some features like tab-completion and help, otherwise it is a pain using command lines. It functions, but I'll have to tidy it up and finish the project sometime!
