Legacy Personal Blogs Arduino Starter Kit
  • Author Author: willygeek
  • Date Created: 17 Aug 2017 3:43 AM Date Created
  • Views 5037 views
  • Likes 8 likes
  • Comments 29 comments
  • arduino_starter_kit_projects
  • stemtlc
Arduino Starter Kit
willygeek
willygeek
17 Aug 2017
Well, the Arduino Starter kit I won from  you guys has arrived.
I plan to keep everyone up to date on my progress through the projects in the book accompanying the kit, but progress may be a bit slow as I also plan to use this as a means of introducing my 13 year old granddaughter to electronics and programming.  As she doesn't live with me progress will be dictated by the time she can spend here with me and on her progress.  So this is just a beginning and I will add to this, with photos and video as progress is made along the way.
  • willygeek
    willygeek over 8 years ago +4
    Arduino Projects book Zoetrope Project 10: This will be my last project this year, A: it is getting too hot to sit at a PC or workbench. 2. Other projects and Christmas etc are calling to me. You will…
  • willygeek
    willygeek over 8 years ago +3
    Well an update at long last.... My granddaughter has proven very difficult to pin down. I think becoming a teenager, concentrating of finding the right High School to suit her etc. etc. So, I thought I…
  • willygeek
    Project 8 Digital Hour Glass; Works well, except that I had to solder legs onto the Tilt Switch that came in the kit, so that it would plug into the breadboard. luckily I have the kit needed and know how…
  • willygeek
    willygeek over 8 years ago in reply to mcb1
    Hello mcb1,
    You are correct, It is unusual for us down here to complain about the heat.  In fact we seem to have an undeserved reputation of being cold and wet, which can be true from time to time.
    However we do have some extremely good spells of weather.  But Friday 1st was, for us, too hot.  In my work/play room it was 29 C and no breeze whatsoever.
    Yesterday was worse, 32 C ans still no breeze.  So by 3:00 pm I gave up and went to the house and blobbed out.
    Apparently it is predicted that we are in for a long hot summer.  The hottest that I have seen it here was 39 C.
    I also lived in Auckland for 19 years, and while the temperatures rarely got to 30 c, the humidity was horrible, 27 c with approaching 90% humidity is horrible, especially at night.
    At lease we are have humidity of under 40% here, so the heat is much more bearable
    mcb1 over 8 years ago in reply to willygeek
    That's not a comment you hear often from Dunedin image
    jw0752 over 8 years ago in reply to willygeek
    Hi William,
    I think what you are hearing is the PWM at work. The drum puts quite a bit of load on the motor and the inertial energy of the drum is slightly diminished before the next pulse pulse arrives. This causes the motor to pulse more strongly and hence the noise. In addition the drum itself acts like a sound board to amplify the noise. Pretty cool experiment.
  • willygeek
    You will notice a lot of noise from the weight of the Zoetrope causing the brass bearings of the motor to be stresses and protesting.
    So, merry Christmas to you all.  Have a great New Year.
    William Glendenning
  • willygeek
    A comment for the website Gurus.
    I have discovered that if I start a post, thyen click Add Comment button, then go back and edit the post I do not get the problem of scrolling to the top of the page.
