Legacy Personal Blogs ArduTrx Update: new HF modules and better documentation
  • Author Author: bernhardmayer
  • Date Created: 17 Mar 2019 9:59 AM Date Created
  • Views 3217 views
  • ardutrx
  • arduinoday2019
  • transceiver_module
  • ham radio
bernhardmayer
bernhardmayer
17 Mar 2019
During the last months I updated my project ArduTrx which was introduced here: ArduTrx - a 2-meter-band ham radio transceiver with Arduino
New HF modules
The Chinese manufacturer NiceRF (https://www.nicerf.com/ ) produces HF modules which are pin and software compatible to the ones from Dorji. They are called SA818 (https://www.nicerf.com/product_151_104.html ), produce 1W of HF output and there exists a VHF and a UHF version just like the DRA818 modules. Additionally they also have a compatible module called SA868 (https://www.nicerf.com/product_151_295.html ) which produces 2W output.
These modules also offer enhanced software functions. For example you can read out the receiver signal strength (RSSI). I tested both modules and updated the software to make use of the new functions. In the source code you can define which module you use and if it is a SA818 you have more functions in the menu. The software is on github: https://github.com/generationmake/ArduTrx
Better documentation
I also updated the documentation on my project website ArduTrx - Open Source Hamradio Transceiver for Arduino
Following this image there is a description of each part of the circuit on my website. I also described the software and how it works on the display and with the menu. Additionally I referred to parts of the source code and how to manipulate them.
Furthermore I added a detailed bill of material with manufacturer and part number for each part and links where you can order the parts. Most parts are available at Farnell / Newark.
Project Website
You can find all documents, schematics, links to software and documentation on my project website:
